RV.Net Open Roads Forum: Jeep towed discharged when towing. This is new.
Search only in Dinghy Towing
 > Jeep towed discharged when towing. This is new.
RJL
Manahawkin, New Jersey
Posted: 10/13/19 06:57pm Link  |  Quote  |  Print  |  Notify Moderator
We've towed this Jeep for a few years now without any problems until this trip. We run the Falcon 2 tow bar and the braek buddy system. I followed the Jeep's owners manual, put the transfer case in Neutral, auto trans in park and switched the ignition key to the "ACC" position. We pulled into the campground yesterday after 570 miles and about 11 hours of driving to find the Jeep completely dead. I had a neighbor ask if I wanted a jump and accepted. Got it started after awhile and let it run about 30 minutes. Shut her down and checked a few times before I hit the rack and when I got up this morning. Started no problem. Figured it was operator error or just one of those things that happen on trips. I double checked everything before I left this morning, stopped after a few hours for a snack and it started right up again. Ok, fixed. Drove for another 400 miles or so, stopped for the night and it's dead. What gives? What do I check and how do I check it? I have a battery charger on her now provided by a nice fella in the campground, and I'm gonna charge it all night but need this fixed for my return trip to NJ next month.
Never had this type of problem before.
Thanks for any suggestions.
Bob
* This post was last edited 10/13/19 07:23pm by RJL *   View edit history
2010 Damon Challenger 368, F-53 Chasis
2010 Jeep Wrangler Rubicon unlimited, Toad
1996 Ford F250 XLT 4x4-work in progress
2019 Dodge Challenger Scat Pack Wide Body.
dodge guy
Bartlett IL
Posted: 10/13/19 07:05pm Link  |  Quote  |  Print  |  Notify Moderator
I don’t believe you need the key on. I don’t think the column lock the wheel with the key off.
Also do you have a batt. Charge wire running from the MH to the Jeep to keep the batt charged? Most vehicle need to have one to avoid this issue!
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
RJL
Posted: 10/13/19 07:07pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, we have the charge wire. I should have been more specific.
ScottG
Bothell Wa.
Posted: 10/13/19 07:18pm Link  |  Quote  |  Print  |  Notify Moderator
First thing I would check is the charge wire.
Scott, Grace and Wesly
2018 Silver Fox 32A.
H0NDA eu2000i
chuckftboy
Fleming Island, Florida
Posted: 10/13/19 07:30pm Link  |  Quote  |  Print  |  Notify Moderator
You say you towed this jeep for a few years with no problem, maybe your battery is failing. If a cell is shorted, it will run a your battery down. Most auto parts stores will load test it for no charge.I once had a battery that that would start my coach and I could drive all day until I turned the coach off. After a while the battery would cool down and start the coach again. The charge circuit was heating the plates and causing one to seperate but only while driving.
2019 Horizon 42Q Maxim Chassis w/tag
Cummins L-9 450 HP / Allison 3000
2006 Jeep TJ and 2011 Chevy Traverse Tows
RJL
Posted: 10/13/19 07:35pm Link  |  Quote  |  Print  |  Notify Moderator
It looks fine. Fairly new. Maybe 2 seasons now. No damage. How would I test if it's operating properly?
RJL
Posted: 10/13/19 07:37pm Link  |  Quote  |  Print  |  Notify Moderator
Always something
RJL
Posted: 10/13/19 07:41pm Link  |  Quote  |  Print  |  Notify Moderator
I was thinking that too. When we get to our place in Cape Coral I'll run over to advance auto or similar. This has me stumped though. Of course I have THREE battery chargers at home, one is even a battery re conditioner that will tell me if there's a problem cell, and that's where they are now that I need them, at home. Sheesh
ScottG
Bothell Wa.
Posted: 10/13/19 08:23pm Link  |  Quote  |  Print  |  Notify Moderator
Looks dont mean anything. You need to check it while the coach is running and make sure it's delivering power to the towed.
JimR 1
Brandon, South Dakota
Posted: 10/13/19 08:27pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 1999 Wrangler and I do not turn the key to the ACC.
Mine goes one click to unlock the steering wheel.
I do know that Jeep changed up things over the years.
JimR
