RV.Net Open Roads Forum: General RVing Issues: Those with portable surge protector
 > Those with portable surge protector
Old-Biscuit
Verde Valley
Posted: 10/13/19 09:20pm Link  |  Quote  |  Print  |  Notify Moderator
Yep.........50A portable PI unit
It is plugged in FIRST regardless....at CG, at home, at friends place etc.
I have NO control over what the Power Company does.
So kinda silly to have it and NOT use it.
ScottG
Bothell Wa.
Posted: 10/13/19 09:30pm Link  |  Quote  |  Print  |  Notify Moderator
Some of us are just silly that way.
Scott, Grace and Wesly
2018 Silver Fox 32A.
H0NDA eu2000i
DutchmenSport
Indiana
Posted: 10/13/19 09:32pm Link  |  Quote  |  Print  |  Notify Moderator
2X. Power at home fluxes a lot more than you think.
bikendan
Camano Island, Wash.
Posted: 10/14/19 03:41am Link  |  Quote  |  Print  |  Notify Moderator
Don't use it at home nor with my generator. only for campground pedestals.
Dan- Firefighter, Retired">, Shawn- Musician/Entrepreneur">, Zoe- Faithful Golden Retriever(RIP">), 2014 Ford F150 3.5 EcoboostMax Tow pkg, 2016 PrimeTime TracerAIR 255 w/4pt Equalizer and 5 Mtn. bikes and 2 Road bikes
edatlanta
Jennings Ferry Campground-Camp Host, Akron, AL
Posted: 10/14/19 03:52am Link  |  Quote  |  Print  |  Notify Moderator
cougar28 wrote:
While plugged in at your home do you always use your surge protector?
I can see why to always use at campgrounds because of lots of things there. High demand on power causing low voltage- high voltage-bad wiring-etc etc. But at home those are not near as likely to happen. Just curious what other do.
I NEVER plug in anywhere without my PT50X. At my home I have been saved by a power company transformer failure that sent high voltage to my rig - 132v+. I had power spikes a different time, again the power company's fault. My next door neighbor had blown light bulbs with each of these issues, I had no damage at all even to my two 120v light bulbs (all others are 12v).
Electrical power is electrical power IMHO and even from a major utility problems can and do occur. I have the PT50X so why not use it all the time. I sleep better when I do.
Ed
KM4STL
2006 GMC 2500HD CCSB 4x4 Duramax/Allison, Titan 52 gallon fuel tank, Prodigy Controller, B&W Companion Hitch, Progressive Industries EMS-PT50C, TST Systems 507 TPMS
2010 Jayco Designer 35RLTS,Cummins/Onan RV QG 5500 EVAP
Fulltime since 2010
Campinghoss@51
Windsor NC
Posted: 10/14/19 04:53am Link  |  Quote  |  Print  |  Notify Moderator
Always use mine at home. This summer I happened to be outside near the fiver when I heard the a/c cut off. I walked over to the fiver and saw an error code on incoming voltage drop. It was so low I reported it. In a few mins a Dominion rep pulled up to check out the problem. I showed him the incoming voltage on the display and he knew what the trouble was. It had to do with solar panels a few miles from my home. He told me it if I had not noticed the drop it may have messed up some household appliances. So yes, if you have it then use it.
Camping Hoss
2017 Open Range 3X 388RKS
2017 F-350 6.7 with hips 8'bed
Lucky & Lucie
WTP-GC
FL
Posted: 10/14/19 04:54am Link  |  Quote  |  Print  |  Notify Moderator
I don’t see why you wouldn’t use it at home too...???
Mine is hardwired, so it’s always used, but power surges, voltage drops, lightning strikes...those things happen anywhere. If you have it, use it. It’s not as if the process of connecting it is somehow prohibitively difficult. You plug your TV, computer, and other electronics into surge protectors at home, so why not the RV too.
Duramax + Grand Design 5er + B & W Companion
SBGTF
georgelesley
Tennessee
Posted: 10/14/19 04:58am Link  |  Quote  |  Print  |  Notify Moderator
Yes we use ours at home as well since the rv is not plugged in at home very much.. BTW, we also have a whole house surge protector at home we pay a bit for every month and it sometimes cycles on and off for no obvious reason. Better safe than sorry.
George & Lesley
2014 Itasca Sunova 33C, 2019 Jeep Cherokee Lattitude Plus toad, Demco/SMI towing system
MetalGator
Posted: 10/14/19 05:50am Link  |  Quote  |  Print  |  Notify Moderator
Yes, I use our portable at home.
2018 Miramar 35.3
2005 Dodge Ram Quad Cab 1500
3 fur kids (Monty, Lola and Pinto)
Rainbow bridge (Murphy)
SusanDallas
Dallas
Posted: 10/14/19 07:41am Link  |  Quote  |  Print  |  Notify Moderator
I use mine when plugged in at home. I don't see any reason to take a chance. I live in a rural area & the power has gone off at least 5 times this summer. I really appreciate the advice from others to unplug during a lightning storm. I always thought I was safe since I was using a surge protector. From now on, I am going to unplug during a storm.
