RV.Net Open Roads Forum: Technology Corner: Cellphone boosters
 > Cellphone boosters
swimmer_spe
Sudbury, Ontario, Canada
Posted: 10/13/19 09:58pm Link  |  Quote  |  Print  |  Notify Moderator
I have a great site. It is a waterfront site. The problem is, no cell service. It is weird, but some areas have some service but we have none. Anyone know of cell phone boosters that will work where no service exists?
MrWizard
Traveling
Posted: 10/13/19 11:08pm Link  |  Quote  |  Print  |  Notify Moderator
no signal
OR
too weak to work
boosters .. boost a weak signal
a booster with a directional "YAGI" antenna Might help
you get a signal and boost it
but NO guarantees the only way is to try it
Radiate The Happy
1997 F53 Bounder 36s
Wherever I happen to park
Posted: 10/14/19 07:42am Link  |  Quote  |  Print  |  Notify Moderator
Amplifying on what the other person said.. If you can go up on the roof. No signal = No Signal and some places that's all you get.
Very weak signal the booster may work..
Also remember that HEIGHT IS MIGHT Which is why Is said to go up on the roof to check (You need not get off the ladder) a 20 foot pole (or taller flagpole) is a great place for the "outside" antenna on a booster.
Home is where I park it.
Dutch_12078
Winters south, summers north
Posted: 10/14/19 07:46am Link  |  Quote  |  Print  |  Notify Moderator
As Mr Wizard said, a cell booster has to have at least a minimal signal to boost. That signal may be below the threshold that your cell phone detects, but it does have to be there. Various boosters have different levels of minimum threshold themselves, so finding one that works where you need it can be a difficult task in a deep fringe area.
Dutch
2001 GBM Landau 34' Class A
rhagfo
Portland, OR
Posted: 10/14/19 08:13am Link  |  Quote  |  Print  |  Notify Moderator
We host in a site that has extremely poor cell signal ore WeBoost will gives us three bars of LTE in the 5er and a couple near the outside.
ktmrfs
Portland, Oregon
Posted: 10/14/19 09:27am Link  |  Quote  |  Print  |  Notify Moderator
first, which carrier? between verizon and ATT (and the others that use either verizon or ATT signalling) we often find one or the other will give a good signal, but not both when we are in remote locations. easiest solution is if one gives a good signal use that carrier. That's why our cell phones are Verizon and our car is on ATT.
Second, boosters require a minimum signal level to be able to get you a useable signal. Signal level needs to be around -140/150db or better for a booster to work. -140db with a booster will get you a signal around -110db which is adequate for voice and text. -140db will generally not give you a useable signal w/o a booster.
And you may find a booster will give you good voice but not data. In one spot we visit signal level is around -130db, booster gets it to -90db or so, but signal is only voice (1x) no data other than messaging.
And "bars" is generally not a good indicator of actual signal strength. use a app that gives you actual signal strength for voice and data channels.
We have a weboost system that I can use with either an omnidirectional antenna or a directional yagi. Does it work everywhere? NOPE. Does it give me a useable voice/text signal in very marginal conditions or when there is no service w/o a booster? YES in many cases, but not all.
Finally I've found that if I need a booster for data, even with a booster data rate is generally much slower than areas that don't need a booster.
2011 Keystone Outback 295RE
swimmer_spe
Posted: 10/16/19 06:24pm Link  |  Quote  |  Print  |  Notify Moderator
I am with Bell, up here in Canada.
I have an iPhone; which app would you recommend?
Fizz
Ottawa, Canada
Posted: 10/17/19 04:48am Link  |  Quote  |  Print  |  Notify Moderator
This app will help you find a signal. It simply points to the cell tower. If you don't see an arrow you won't get coverage and a booster won't help.
Open Signal
swimmer_spe
Posted: 10/17/19 09:15am Link  |  Quote  |  Print  |  Notify Moderator
Open Signal
Thank you. Next time I am out where I have no service, I will give it a try to see what it is out there.
ktmrfs
Portland, Oregon
Posted: 10/17/19 09:34am Link  |  Quote  |  Print  |  Notify Moderator
Open Signal
good app, but I disagree with the no arrow booster won't help. Many a time I've been in places with no service, so the app won't point to a tower and once I hook up the weboost I get a useable signal and the app points to nearby tower(s) and the booster gives me at least voice service.
For cell service to work, the PHONE must have enough power to ping a nearby tower, and the tower must be able to then give enough signal for the phone to recieve. The PHONE output power is the weak link in the system in almost all cases. That's where the booster comes into play.
And in car phones such as onstar ATT have more output power than a handheld, IIRC the same power as a booster will give you. so at times while folks with ATT have no service my onstar phone gives nice service and internet access.
Get far enough away from a tower and yes, booster won't solve the problem.
