RV.Net Open Roads Forum: Tech Issues: Electrical Question
 > Electrical Question
lmpres
New Hampshire
Posted: 10/14/19 05:15am Link  |  Quote  |  Print  |  Notify Moderator
On my last trip this year, when I got to the campground, I noticed my C02 alarm chirping. I had already plugged in to shore power when I noticed it. Thought nothing of it.
I got home, plugged in, and same thing. Again, wasn't sure why that was happening.
Went out yesterday to move the trailer for winter storage. Hooked up to my truck, plugged into my truck, and no power in unit to raise the landing gear. I re-plugged into shore power and landing gear raised with no problem. (also, noticed c02 alarm chirping again.)
Could this be because of a dead battery? Was thinking last night and it is the original battery that came with the unit.
Any help is appreciated!
RJsfishin
Winston Or.
Posted: 10/15/19 12:08pm Link  |  Quote  |  Print  |  Notify Moderator
All I know is that most all alarms will sound if low voltage is detected
Rich
'01 31' Rexall Vision, Generac 5.5k, 1000 watt Honda, PD 9245 conv, 300 watts Solar, 150 watt inv, 2 Cos 6v batts, ammeters, led voltmeters all over the place, KD/sat, 2 Oly Cat heaters w/ ox, and towing a 2012 Liberty, Lowe bass boat, or a Kawi Mule.
2oldman
New Mexico
Posted: 10/15/19 12:57pm Link  |  Quote  |  Print  |  Notify Moderator
CO alarm.
Alarms chirp with batteries going dead.
fj12ryder
Platte City, MO
Posted: 10/15/19 01:05pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, certainly could be a dead battery. You don't say what year your trailer is so no way of knowing how old the original battery is. But signs point to that as the problem. Easy way to find out is to check it with a multi-meter. Anything else and you're just guessing.
Howard and Peggy
"Don't Panic"
BFL13
Victoria, BC
Posted: 10/15/19 01:16pm Link  |  Quote  |  Print  |  Notify Moderator
Your converter is working (you have 12v on shore power) but your house battery is low (no 12v without shore power) but the alarm still chirps even though you have 12v on shore power.
Your alarm might be one with its own little batteries that are low.
Meanwhile your house battery is low even though the converter works. So the converter charging is not reaching the battery or else it just can't be recharged anymore.
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
See Profile for House electronics set-up.
sayoung
Tx
Posted: 10/15/19 01:44pm Link  |  Quote  |  Print  |  Notify Moderator
2oldman wrote:
CO alarm.
It has timed out, replace.
bukhrn
Lanexa, Va
Posted: 10/15/19 02:01pm Link  |  Quote  |  Print  |  Notify Moderator
For the price of a 9v battery, replace it, if it stops chirping, you're all set, if not replace the alarm unit, they have an age limit, but right now i don't remember exactly what it is, 5 maybe 8 years, look on the back of it, it should have a sticker, suggesting when to replace it.
2007 Forester 2941DS
2014 Ford Focus
Wherever I happen to park
Posted: 10/15/19 04:31pm Link  |  Quote  |  Print  |  Notify Moderator
"Chirping" generally means it has a system issue.. Possible issues are:
Low battery
Checksum error or other system error
More than 5 years old time out.
Home is where I park it.
CFerguson
on the road
Posted: 10/17/19 04:46pm Link  |  Quote  |  Print  |  Notify Moderator
Yeah, the units do go bad and I'd immediately replace one that acted squirrely. I've had one go bad and so has another family member. They're inexpensive.
time2roll
Posted: 10/17/19 05:10pm Link  |  Quote  |  Print  |  Notify Moderator
Get out your voltmeter and post the battery voltage.
675w Solar pictures back up
