RV.Net Open Roads Forum: Fifth-Wheels: Sumo Springs
 > Sumo Springs
gdweb
Posted: 10/14/19 01:55pm Link  |  Quote  |  Print  |  Notify Moderator
See some people are putting sumo springs on axles of their 5th wheels. wondering could that make a difference in handling. weren't they designed to help keep truck from squatting when loaded.
SEMPER FI
Gary & Diane
2020 F250 King Ranch 6.7l FX4
2013 Sundance 3270res
MFL
Midwest
Posted: 10/14/19 03:45pm Link  |  Quote  |  Print  |  Notify Moderator
Only reason I could see to put them on a FW suspension, is if you are over loading it, past the GVWR. Yes, they are better served to level the TV. For improved handling of FW, adding shocks would make more sense, if not already installed.
In most cases if you over load the FW suspension, you will likely be over the OEM tire rating also.
Jerry
Busdriver
Shepherdsville Ky 40165
Posted: 10/15/19 04:18am Link  |  Quote  |  Print  |  Notify Moderator
Put them on mine, smoothed the ride of the fith wheel , personal I feel they are better than shocks, mine are only compressed about one half of inch setting still
Busdriver 2019 2500 Chevy Duramax , - 2017 Grand Design 303 RLS
JIMNLIN
Oklahoma
Posted: 10/15/19 06:12am Link  |  Quote  |  Print  |  Notify Moderator
I can see the need with torsion suspension on a trailer as they start to sag but in some cases they do put more bounce in std leaf spring suspension.
Much depend on the suspension age/type on the trailer.
They will help squat on any type suspension.
Wood chip
Nor Cal
Posted: 10/16/19 08:39am Link  |  Quote  |  Print  |  Notify Moderator
What kit or part # worked with your rig and was there much issue with the install?
2017 Chevy HD 3500 Dually LTZ D/A combo crew cab / Bilstein 4600's / Ride Rite air bags w remote / 50 gal transfer flow Aux tank / Trailersaver BD5
2020 Arctic Fox 32-5m with most options + 17.5 wheel & tire combo
Busdriver
Posted: 10/17/19 03:11pm Link  |  Quote  |  Print  |  Notify Moderator
Install was simple , the ones I bought came with everything in the kit , also bought them from sumo got the to come off the listed price some, don’t remember the part number, still have the box but not home now
drb1251
Ohio
Posted: 10/20/19 02:30am Link  |  Quote  |  Print  |  Notify Moderator
I had two rear leaf spring failures. The first was out in Utah in 2017 and now on a local drive. I ordered two replacement sets from etrailer. China made and morride shackle kit. See how this holds up.
Crodad
Lafayette, LA
Posted: 10/21/19 07:32am Link  |  Quote  |  Print  |  Notify Moderator
I put Timbrens. Same principle. Some say the Timbrens are better for towing on trucks. And sumos are better for Motorhomes.
2008 F-250 PSD 4x2 Lariat
2016 Silverback 31RK
 > Sumo Springs
