RV.Net Open Roads Forum: Fifth-Wheels: Replacing drum brakes ???
 > Replacing drum brakes ???
ilvtravln
Calif.
Posted: 10/14/19 05:50pm Link  |  Quote  |  Print  |  Notify Moderator
Need to replace brakes on my 5er, it has Lippert axles, drums are 12". Can I just replace the brake shoes or do I replace the entire backing plate, brakes, magnet all of it. Where do I go for parts?
Thanks
Art
ford truck guy
Pennsylvania
Posted: 10/14/19 05:52pm Link  |  Quote  |  Print  |  Notify Moderator
If it were me and I was NOT able to upgrade to the electric/hydraulic disc system, I would take the 4 bolts off and replace the entire backing plate... Just make sure you get 2 left and 2 right
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
ScottG
Bothell Wa.
Posted: 10/14/19 06:50pm Link  |  Quote  |  Print  |  Notify Moderator
The magnets wear down too and don't last through two sets of shoes.
I agree with the PP, I'd replace the backing plates as an assembly.
FWIW, I am very pleased with the automatic forward adjsuting units on my trailer.
Scott, Grace and Wesly
2018 Silver Fox 32A.
H0NDA eu2000i
wrgrs50s
Scurry, Tx
Posted: 10/14/19 06:51pm Link  |  Quote  |  Print  |  Notify Moderator
Etrailer.com has everything you need. It's best and easiest to change the entire brake assembly.
Walter and Janie Rogers
2012 Sundance 277RL
TV 2006 Silverado 2500 6.0
azdryheat
Tucson, AZ
Posted: 10/14/19 07:13pm Link  |  Quote  |  Print  |  Notify Moderator
Sounds as though you've never done this before. Find a friend to help you through it as you'll also have to do the bearings.
2013 Chevy 3500HD CC dually
2014 Voltage 3600 toy hauler
2011 Harley Ultra Limited
2016 RZR 900
edbehnke
North America (from Michigan)
Posted: 10/14/19 07:20pm Link  |  Quote  |  Print  |  Notify Moderator
replace the whole things with self adjusting.
eddie and sandie
3402 Montana 2013
Ford F350 2015
Roger10378
Goodrich, MI.
Posted: 10/15/19 06:36am Link  |  Quote  |  Print  |  Notify Moderator
You also need to inspect the drums for wear on both the braking surface and the magnet surface. You can get parts at most anyplace that has trailer parts.
2005 Cardinal 30TS
2007 Chevy 2500HD D/A
frizfreleng
Aleutians West
Posted: 10/15/19 06:52am Link  |  Quote  |  Print  |  Notify Moderator
I replaced the brake assemblies and bearings last winter on my 2004 Keystone Cougar. If you have any mechanical ability it is fairly easy.
Dexter 10' electric brake assemblies (4): $175
Wheel bearings for 4 wheels: $54
This time I used a company named Sturdy Built Trailer (online). I believe they were cheaper than etrailer for the same brand assemblies.
colliehauler
Mc Pherson KS USA
Posted: 10/15/19 07:43am Link  |  Quote  |  Print  |  Notify Moderator
Agree with others replace the entire assembly.
fj12ryder
Platte City, MO
Posted: 10/15/19 09:53am Link  |  Quote  |  Print  |  Notify Moderator
I planned on replacing just the brake shoes on my toyhauler when necessary, but the price for brake shoes is ridiculous. You could easily spend $400 for the brake shoes for a double axle trailer. Of course the the whole brake kit could easily set you back $600. Or go cheap and get by for about the same as just the shoes would cost.
Howard and Peggy
"Don't Panic"
