RV.Net Open Roads Forum: Fifth-Wheels: Can't find black and grey tanks.
 > Can't find black and grey tanks.
Lorne Coultman
Calgary
Posted: 10/15/19 01:14pm Link  |  Quote  |  Print  |  Notify Moderator
I just bought a 1989 Security Penthouse 32 trailer and have never had a trailer and want to do work on it.Of course there is no manual and I don't think the company is in business. So I cant find anything about it. It is getting cold in Calgary Canada and want to make sure the tanks are drained. I have lots of questions but this is the most important at this stage. Hope someone can help. would love to find a manual somewhere.
DutchmenSport
Indiana
Posted: 10/15/19 02:10pm Link  |  Quote  |  Print  |  Notify Moderator
I would think the handles are near the outlet. It's possible they fell off or were removed. Look for small holes near where the outlet is. You may have to get one of these. They screw back into the slide valve: click here.
garym114
Bluff Dale, Texas
Posted: 10/15/19 02:30pm Link  |  Quote  |  Print  |  Notify Moderator
Consider fresh water piping, the fresh water tank and and water heater.
wildtoad
Blythewood, SC
Posted: 10/15/19 03:26pm Link  |  Quote  |  Print  |  Notify Moderator
Who did you buy it from? Can they not tell you?
Tom Wilds
Blythewood, SC
cavie
Posted: 10/15/19 03:47pm Link  |  Quote  |  Print  |  Notify Moderator
To drain the black and gray tanks look for a 3" black pipe with 2 t-handle valves. You may have two lines. I do. You also need to find the FW tank drain. It will be a 1/2" line with a valve on the end. You also need to find 2 low point drains. One for hot and one for cold. They will have valves or caps on the ends.
You tube is your friend. You don't need a manual. They are generac anyway. All RV are basically the same.
* This post was edited 10/15/19 07:58pm by cavie *
Morro Bay, CA
Posted: 10/15/19 04:30pm Link  |  Quote  |  Print  |  Notify Moderator
Working on something you know little about (where are waste tanks?) can get expensive.
1492
Arlington, VA
Posted: 10/16/19 03:51pm Link  |  Quote  |  Print  |  Notify Moderator
Moved from Forum Posting Help and Support
Michelle.S
Western NY till fall, then Sebring, FL
Posted: 10/17/19 09:02am Link  |  Quote  |  Print  |  Notify Moderator
Is it possible the unit was setup on a seasonal site and the previous owner was plumbed directly and removed the holding tanks??
2018 Chevy 3500HD High Country Crew Cab DRW, D/A, 2016 Redwood 39MB, Dual AC, Fireplace, Sleep #Bed, Auto Sat Dish, Stack Washer/Dryer, Auto Level Sys, Disk Brakes, Onan Gen, 17.5" "H" tires, MORryde Pin & IS, Comfort Ride, Dual Awnings, Full Body Paint
bpounds
Sophmore Brain...
Posted: 10/17/19 09:16am Link  |  Quote  |  Print  |  Notify Moderator
+1
Might not have ever had any.
Get underneath and find the tanks, if they are there. You will likely need to pull down whatever cover they used under the frame. But you'll want to do that anyway for inspection and as you work on the trailer. Waste tanks, if there are any, will almost certainly be under the floor and between the frame rails. Keep in mind that a fresh water tank could be under there, but also is often inside the trailer, under a bed, or a dinette seat, or other cabinet.
2006 F250 Diesel
2011 Keystone Cougar 278RKSWE Fiver
