RV.Net Open Roads Forum: General RVing Issues: Winter Camping - Golf Cart
 > Winter Camping - Golf Cart
Mamakat35
lancaster County
Posted: 10/15/19 03:26pm Link  |  Quote  |  Print  |  Notify Moderator
Hello! I am new to seasonal camping and have one season behind me. This summer we purchased a club car golf cart, electric, and now that it is coming into the winter months I’m not sure how to proceed. Our campground is a 12 season campground and I enjoy going up to the mountains and camping in the dead of winter… I love the solitude! However, I’m on sure about the care of a golf cart over the winter months. Do I need to take the batteries out and store them? Or is it like A car that as long as I started up every couple of weeks I should be OK? I do go up to the campground approximately two Dash three times a month. I’m not sure whether people do anything with the golf courts over the winter months… Any advice?
~Heidi
Mojave, Kern County, California
Posted: 10/15/19 03:47pm Link  |  Quote  |  Print  |  Notify Moderator
“as long as I started up every couple of weeks I should be OK?“
Regarding the golf cart batteries, “starting” isn’t a concern. Keeping the battery charged is the key.
jkwilson
Indiana
Posted: 10/15/19 04:41pm Link  |  Quote  |  Print  |  Notify Moderator
If you keep the batteries fully charged they will be fine outside. If they discharge, they can be damaged by cold temperatures.
John & Kathy
2014 Grand Design Reflection 303RLS
2014 F250 SBCC 6.2L 3.73
Posted: 10/15/19 04:55pm Link  |  Quote  |  Print  |  Notify Moderator
“A 100 percent fully charged battery will not freeze until approximately minus 76 degrees Fahrenheit.”
That should cover most winter camping.
wildtoad
Blythewood, SC
Posted: 10/15/19 05:11pm Link  |  Quote  |  Print  |  Notify Moderator
After use plug the cart into a charger and keep a full charge. Nothing else to do except check water level in the batteries every now and then.
Tom Wilds
Blythewood, SC
2015 Jeep Wrangler 2dr HT
John&Joey
Summer-North,Winter-South
Posted: 10/15/19 06:17pm Link  |  Quote  |  Print  |  Notify Moderator
First question is it electric or gas. I’m assuming electric since you said batteries.
Next question is the year if in the 2000’s then your charger is setup to start automatically every 15 days as long as you don’t have a power outage. If that happens then you need to unplug everything to reset it.
Batteries love cold weather so that’s a good thing. Your cart more then likely has a run/tow switch. Make sure it’s in tow when not in use. Run will have a parasitic draw. If you don’t disconnect the batteries make sure you charge them after every use then after a couple of week of non use.
Cecilt
Page
Posted: 10/16/19 07:16am Link  |  Quote  |  Print  |  Notify Moderator
Is your charger a battery maintainer as well. My current charger will fully charge and after about 28 days will automatically click on and bring the batteries up to full charge. I leave my cart plugged in 24/7 when not using it for the few weeks I use it at the beach in the summer. If your charger is like this leave your switch in run not tow. If you leave it in tow it will not charge 100%.
tdiller
usa
Posted: 10/16/19 09:08am Link  |  Quote  |  Print  |  Notify Moderator
~Heidi
On my motorcycles I always plug the battery in to a battery tender when not using them. I don't remove the battery from the motorcycle. It seems to be working since I have had the one battery for almost 9 years now and still going strong. I know I'll probably have to replace it next season.
dodge guy
Bartlett IL
Posted: 10/16/19 01:09pm Link  |  Quote  |  Print  |  Notify Moderator
IDE be more concerned about the 12 seasons!!!! That sounds pretty bad.
Otherwise just keep them charged and check the water before it gets below freezing. Biggest things is don’t cook the batteries, that will boil the water out and shorten their life.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
pianotuna
Regina, SK, Canada
Posted: 10/16/19 03:40pm Link  |  Quote  |  Print  |  Notify Moderator
Hi,
Here is a thread on winter camping. It may save you lots of grief.
https://forums.goodsamclub.com/index.cfm/fuseaction/thread/tid/24160748.cfm
As to the golf cart batteries. Charge them once per month.
Regards, Don
