RV.Net Open Roads Forum: Fifth-Wheels: Rodent???
 > Rodent???
ipeltier
St. Albert, Alberta
Posted: 10/15/19 08:59pm Link  |  Quote  |  Print  |  Notify Moderator
We recently put our 5th wheel in storage on a farm field in southern British Columbia. The owner warned us that mice were a problem, so we set out four trays of blue poison mouse pellets. A week later, we returned to find two of the trays completely empty, and a stash of the pellets in a corner of a pantry basket, and a dozen pellets in the underbelly underneath the upstairs bedroom. We inspected the trailer thoroughly, found a dozen mouse turds, and a small hole on the kitchen slide which we plugged with steel wool. We're now living in the trailer, and haven't found any dead rodents, so I assume it (they) escaped through the slide hole before we plugged. Would this have been a mouse? A rat? Do mice transport food to a hiding spot?
blofgren
Surrey, B.C.
Posted: 10/15/19 09:10pm Link  |  Quote  |  Print  |  Notify Moderator
Rats have considerably larger droppings and WAY more urine than mice. So if the droppings are quite small, it was probably mice.
I would clean everything very well and set some good old fashioned traps to get any that may still be in there. I made the mistake of leaving poison bait out in one of my trailers years ago and a rat ended up dying somewhere in a furnace duct. The smell was absolutely horrible and we never could get rid of it. From that point on, I concentrate on keeping rodents out and trapping any that may get in.
Good luck and let us know how you make out.
2013 Ram 3500 Megacab DRW Laramie 4x4, 6.7L Cummins, G56, 3.73, Maximum Steel, black lthr, RAM 20k sliding hitch, Retrax, Linex, and a bunch of options incl. cargo camera
Scottiemom
South Dakota/Indiana
Posted: 10/16/19 04:58am Link  |  Quote  |  Print  |  Notify Moderator
We prefer to trap as well for the occasional rodent that gets in. Also, I don't like poison because of it killing owls and other wildlife that will feed on the poisoned mice.
I don't want to take the chance that a rodent will crawl into a space I can't reach and die.
Dale Pace
Wife to Terry (Teacher's Pet)
2006 Tiffin Phaeton 40'(Phaeton Place)
2014 Ford Flex
2004 R-Vision Trail-lite 213 (MinnieMee)
Fulltiming since 2005
http://www.skoolzoutforever.blogspot.com/
Where are we?
schlep1967
Harrisburg, PA
Posted: 10/16/19 05:36am Link  |  Quote  |  Print  |  Notify Moderator
Used the blue pellets in my garage once. They emptied the tray in one night. The next week we grabbed our bowling ball bags and headed to the alley for our weekly league night. It was quite comical when I pulled the bowling ball out and had blue pellets all over the floor.
I now use snap traps.
A very important part of storing a camper is getting every bit of food out of the camper. With no food or water they may visit but most likely will not set up camp. And it never hurts to set a trap right inside the door where it is easily checked.
2008 Dodge Ram 2500 Diesel
2009 Open Range 385RLS
Pull-Rite Super Glide
Tvov
CT
Posted: 10/16/19 05:46am Link  |  Quote  |  Print  |  Notify Moderator
Many times the mouse poison causes the mice to be thirsty, and they leave the area (or camper) to find water and hopefully die out there somewhere. So if you don't have dead mouse smell in your camper than that is what happened. Dcon and Tomcat poison pellets are very weak and sometimes don't work. Try Ramik (green packaging), and especially One Bite (yellow packaging) works well for me.
Avoid putting the bait in the camper - it will draw the rodents into the camper to get the bait. Use the outdoor bait containers (designed to prevent other animals from eating the bait). I put those next to the jack and wheels, where rodents can crawl up into the camper.
Rodent control is hard, and never ending. Try variations of all the advice you read about here. Eventually you find some combination that will work for you.
2008 F-250 CrewCab 5.4L,
midnightsadie
ohio
Posted: 10/16/19 08:43am Link  |  Quote  |  Print  |  Notify Moderator
buy a product called fresh cab at a farm store or on e bay and peppermint oil NO MICE for years.
janstey58
Glenwood, IA
Posted: 10/16/19 11:26am Link  |  Quote  |  Print  |  Notify Moderator
X2 on the PURE Peppermint oil soaked cotton balls. No MICE!
Jeff and Kim
2015 Fleetwood Discovery 40E
Freightliner Chassis 380HP DP
2012 Ford Escape Limited Toad
Lorne Coultman
Calgary
Posted: 10/16/19 11:37am Link  |  Quote  |  Print  |  Notify Moderator
Someone told me to use Irish spring soap and they won't come around.
Allworth
Orlando, FL
Posted: 10/16/19 12:48pm Link  |  Quote  |  Print  |  Notify Moderator
I order peppermint oil by the pint from Amazon Much cheaper than local suppliers who consider it aroma therapy.
Formerly posting as "littleblackdog"
Martha, Allen, & Blackjack
2006 Chevy 3500 D/A LB SRW, RVND 7710
2008 Titanium 30E35SA; EZ-Lube axles; wet bolts; spring hanger gussetts; BFG Commercial TAs
"Real Jeeps have round headlights"
ipeltier
St. Albert, Alberta
Posted: 10/16/19 08:31pm Link  |  Quote  |  Print  |  Notify Moderator
"Avoid putting the bait in the camper - it will draw the rodents into the camper to get the bait. Use the outdoor bait containers (designed to prevent other animals from eating the bait). I put those next to the jack and wheels, where rodents can crawl up into the camper."
Tvov--what outdoor bait containers would you recommend? We are in Canada, so our products may be different but I'm sure I can find comparable items.
Good advice about not putting the bait in the trailer, and about the consequences of poisoned mice and their predators. I'm also amazed that the mouse had the energy to stash all that food in two different places.
Will also look up peppermint oil. Thanks, everyone.
 > Rodent???
