RV.Net Open Roads Forum: Tech Issues: Battery (really solar panel) Disconnect Question
 > Battery (really solar panel) Disconnect Question
Powertour
Nevada
Posted: 10/16/19 07:19am Link  |  Quote  |  Print  |  Notify Moderator
Would like to put a simple battery disconnect switch between my charge controller & the house batteries vs between the rooftop solar panel & the charge controller.
Any potential issues doing it this way?
Back Story: Solar was installed prior to me owning the coach & the way it was done leaves me no good access to put a disconnect switch between the solar panel & the controller, at least not without turning this want into a major project, which I'd like to avoid if I can.
2015 Itasca 25b Ford E350 V10
BFL13
Victoria, BC
Posted: 10/16/19 07:29am Link  |  Quote  |  Print  |  Notify Moderator
Some controllers can be damaged by leaving them connected to the array side and disconnecting the battery side. Check the controller's manual on that. Eg, Morningstar warns about it.
1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
See Profile for House electronics set-up.
2oldman
Ca
Posted: 10/16/19 07:45am Link  |  Quote  |  Print  |  Notify Moderator
I would try to avoid that.
phemens
Montreal, Canada
Posted: 10/16/19 07:46am Link  |  Quote  |  Print  |  Notify Moderator
I installed battery disconnects between the array and the controllers, and a single disconnect switch between a busbar serving accessories (MPPT, inverter, etc) and the battery bank. That gives me full flexibility.
2012 Dutchman Denali 324LBS behind a 2006 Ford F-250 V10 out of Montreal
1 DW, 1 DD, 1 DS, 2 HD (Hyper Dogs)
1Kw solar, 500 AH LIFePO4, Yamaha EF2000 gen, Samlex 3000w Inverter
Sam Spade
North Central Florida
Posted: 10/16/19 08:03am Link  |  Quote  |  Print  |  Notify Moderator
OK, gotta ask.
Under what conditions would you need or want to disconnect the solar charging equipment from the batteries.....except for maintenance maybe ??
Well designed equipment should cause no problem if left connected 24/7.
'07 Damon Outlaw 3611
CanAm Spyder in the "trunk"
ajriding
st clair
Posted: 10/16/19 09:00am Link  |  Quote  |  Print  |  Notify Moderator
You will likely ruin the charge controller. I have not seen a controller that does not warm to not have a battery hooked up before connecting the solar panel.
That said, I have accidentally hooked up the panel with no battery with no damage to the controller. I do not know what the issue is or what can go wrong, but imagine without a battery there that the voltage levels can spike too high. The battery is able to absorb any stray voltages or odd voltages into its storage capacity rather than all that spike go into the electronics.
You will have to either put the switch between the panel and the controller, or not put any switches in.
Another option is to put cardboard or plywood over the panel (give it a few mins to depower) and then it should be safe to disconnect, or do this at night when there is no sun to power the panel. Don't let the cover blow off though.
I have a truck camper with the batteries on the truck, not the camper. When I would remove the camper then there were no batteries, so I put in a small exit sign battery that I could switch over to that the panel had a battery still connected, this was a post-controller switch.
Since then I have replaced the little battery with a regular marine battery, but still use the switch for the panel that is not usually connected to that camper battery.
MDKMDK
Canada
Posted: 10/16/19 09:19am Link  |  Quote  |  Print  |  Notify Moderator
I just replaced my dying factory FLA batteries with 2 X 100Ah LiFePO4 units. To do this, I had to disconnect the batteries while the controller was up and running and it was a sunny day. I actually considered pulling the 3 rooftop panel connectors out of the 3 way combiner, but after consulting Winnebago Tech Support, they said no need.
My system is a factory installed Zamp Solar setup, 3 X 100W panels and the ZS-30A PWM controller. When all was reconnected, everything is up and running with no apparent ill effects. So, I'm going to *assume* this charge controller doesn't care if you disconnect the batteries, either at the battery terminals manually, or with an added disconnect switch. Which I didn't add. Never ocurred to me to add one.
Just in case you've got the same, or similar, setup.
Mike.
2018 (2017 Sprinter Cab Chassis) Navion24V + 2016 JKU (sold @ ????)
2016 Sunstar 26HE, V10, 3V, 6 Speed (sold @ 4600 miles)
2002 Roadtrek C190P (sold @ 315,000kms)
Powertour
Nevada
Posted: 10/16/19 09:54am Link  |  Quote  |  Print  |  Notify Moderator
Yeah the charge controller I inherited with this setup is a Chinese LMS unit.
I don't see anything in the sparse (key word) documentation that says to avoid having panels wired to the controller unit if you don't have a battery bank wired up/connected at the same time.
BFL13
Victoria, BC
Posted: 10/16/19 10:09am Link  |  Quote  |  Print  |  Notify Moderator
From the LMS manual:
Caution: For secure installation, must follow below connect sequence: First battery, second load, and the last photovoltaic panel.
Powertour
Nevada
Posted: 10/16/19 10:26am Link  |  Quote  |  Print  |  Notify Moderator
Appreciate you pointing that out.... the only manual I'd found online didn't reference that.
