RV.Net Open Roads Forum: Keep using Eternabond until entire roof is covered?
 > Keep using Eternabond until entire roof is covered?
noteven
Turtle Island
Posted: 10/17/19 08:35am Link  |  Quote  |  Print  |  Notify Moderator
pianotuna wrote:
EternaBond can be ordered in a roll that is four feet wide.
piano - why do I see the person stuck to the roof like flypaper...? [emoticon]
solismaris
Massachusetts
Posted: 10/17/19 08:55am Link  |  Quote  |  Print  |  Notify Moderator
Yeah. A piece that big would be hard to manage. And mistakes could be very costly!
But that suggests to me that the the manufacturers may well intend it to be used for large jobs, possibly including a complete roof recover.
David Kojen
ScottG
Bothell Wa.
Posted: 10/17/19 09:58am Link  |  Quote  |  Print  |  Notify Moderator
beemerphile1 wrote:
solismaris wrote:
...after 15 years the rubber roof itself is starting to go; the white is wearing off in places and the black shows through....
Purely cosmetic, you don't have to do anything with it.
While the white is cosmetic, it keeps the UV off the black rubber that would otherwise break it down very quickly.
So it is important to keep something over the black part.
Scott, Grace and Wesly
2018 Silver Fox 32A.
H0NDA eu2000i
pianotuna
Regina, SK, Canada
Posted: 10/17/19 10:05am Link  |  Quote  |  Print  |  Notify Moderator
Having used the 4 foot wide EternaBond I was surprised that it was not too difficult to apply.
Regards, Don
chuckbear
Posted: 10/17/19 10:20am Link  |  Quote  |  Print  |  Notify Moderator
We recoated ours 4 years ago and it is just fine. I agree with others that this is your best and easiest option. Probably the least expensive also. Chuck
beemerphile1
Ohio
Posted: 10/18/19 07:22pm Link  |  Quote  |  Print  |  Notify Moderator
I retired from commercial building management. There are millions of commercial roofs using the same EPDM roofing that RVs are using. The white layer is purely cosmetic.
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
minnow
Upstate South Carolina
Posted: 10/18/19 07:41pm Link  |  Quote  |  Print  |  Notify Moderator
Will that Hengs adhere to Eternabond ?
chuckbear
Posted: 10/18/19 08:10pm Link  |  Quote  |  Print  |  Notify Moderator
If you buy the correct one. Chuck
