RV.Net Open Roads Forum: Truck Campers: Recommendations for quiet portable generator
 > Recommendations for quiet portable generator
Page of 10
2oldman
AZ
Posted: 10/20/19 03:17pm Link  |  Quote  |  Print  |  Notify Moderator
Another OP never to be heard from again.
Reality Check
North Bend
Posted: 10/20/19 05:26pm Link  |  Quote  |  Print  |  Notify Moderator
pianotuna wrote:
I'd buy a Harbor Freight 3500 with an extended warranty. I'd buy a champion 3400 with remote electric start.
lol... and you would severely limit the people who would camp with you.
Seriously, friends don't let friends drive drunk or buy noisy generators. It's just plain rude.
What happened to the OP? no thanks for the wonders of brilliant internet knowledge...I'm surprised.
'07 F550 with Link Ultraride air under an '11 AF 1150. It's either a fishing boat, snowmobiles or dual sports; something is always being towed.
Switching over to a 2016 F550 with new Ultraride air...just need to get the flatbed built.
burningman
Seattle, WA USA
Posted: 10/20/19 10:17pm Link  |  Quote  |  Print  |  Notify Moderator
I have two Honda EU2000s, and I often run both even though one will handle what I’m doing, just because two barely off idle sound nicer than one throttled up.
It’s a whole lot easier to lift and carry a couple of 50 pound sets than one 140 pound EU3000.
And together they make more power too. You also get the option of running just one when your load is very light.
The EU3000 is a terrific unit, but it’s size and weight make it not perfectly suited to use with a truck camper.
2017 Northern Lite 10-2 EX CD SE
99 Ram 4x4 Dually Cummins
A whole lot more fuel, a whole lot more boost.
4.10 gears, Gear Vendors overdrive, exhaust brake
Built auto, triple disc, billet shafts.
Kelderman Air Ride, Helwig sway bar.
valhalla360
No paticular place.
Posted: 10/20/19 11:58pm Link  |  Quote  |  Print  |  Notify Moderator
ardvark wrote:
Kayteg1 wrote:
jimh425 wrote:
From the Honda website. All are way below US Forest Service and National Park requirements although they also have generator hours which are not at night.
Dry weight of the quiet Honda 3000 is 131 lbs. 57 dB(A) @ rated load, 50 dB(A) @ 1/4 load
Dry weight for the light Honda 3000 Handi is 78lbs. 58 dB(A) @ rated load, 52 dB(A) @ 1/4 load
Dry weight of a Honda 2200 is 48 lbs. 57 dB(A) @ rated load 48 dB(A) @ 1/4 load.
That's a tricky way to give noise ratings.
Other way to present it is that at
750 W Honda 3000 will make 50 dB when
1800 W Honda 2200 will make 57 db
No direct comparison available, while 7 dB difference is day to night how humans hear it.
Man, for sure. Small numbers, huge difference!!
What would be nice is if they provided graphs of wattage output vs noise level. Even better would be a 3 dimensional graph that includes distance.
No it wouldn't be hard to produce but probably not in the advertisement divisions best interests.
I would be interested to see if they've optimized for 1/4 load, knowing that is what goes into the marketing material and once they get to 26% load, all bets are off. This is quite possible as much of the sound deadening is not due to insulation but via resonance which can be tailored to specific engine rpm.
Tammy & Mike
Ford F250 V10
2008 Copper Canyon 5er
Catalac Catamaran 34'
Full Time spliting time between boat and 5er
Kayteg1
California > Nevada
Posted: 10/21/19 09:09am Link  |  Quote  |  Print  |  Notify Moderator
I pay attention to those things at campgrounds and my observation is that I can sit on Honda 3000 at small load and talk with normal voice.
3000 will get louder when running AC, but still quieter than AC itself.
When neighbour runs 2 of 2000's to power AC, I don't hear AC over generator noise.
Than 1 time 1 of neighbour's 2000 stop, likely for end of the fuel and whole set went up in smoke.
jimh425
Western MT
Posted: 10/21/19 10:06am Link  |  Quote  |  Print  |  Notify Moderator
All ACs aren’t the same noise level. It’s hard for me to believe the RV and generators went up in smoke. Generally, the overload circuit would immediately trip. Are you exaggerating again? [emoticon]
burningman
Seattle, WA USA
Posted: 10/21/19 10:27am Link  |  Quote  |  Print  |  Notify Moderator
OK sorry but I have to call BS on that.
Honda EUs do not “go up in smoke” when they overload.
All they do is return to idle speed and shut down the electricity.
You just stop it and restart it and it’s on again.
That’s how they work.
I’ve owned six of ‘em, over the last almost-20 years.
I’d have fried all of them if that story was true.
ardvark
Bristol, TN.
Posted: 10/21/19 11:56am Link  |  Quote  |  Print  |  Notify Moderator
Ditto the Yamahas and I expect all others. Overloading small gennies occasionally is too commonplace to not cover that liability risk in design. [emoticon]
Steve
time2roll
Posted: 10/21/19 12:12pm Link  |  Quote  |  Print  |  Notify Moderator
If there was a fire I would think this internal malfunction started the fire.
Can't imagine the shut down from lack of fuel started the fire.
675w Solar pictures back up
Kayteg1
California > Nevada
Posted: 10/21/19 12:35pm Link  |  Quote  |  Print  |  Notify Moderator
Aren't we all exaggerating here?
I did not ask for details on the incident, but what I observe was that when 1 of Honda2000 generators quit, the other was running for some time before what I think was oil splash smoke show and it died.
That was in 110F heat and on 5-ver so likely 15K AC.
The neighbours did not run 2 generators again.
* This post was edited 10/21/19 12:51pm by Kayteg1 *
Page of 10
