RV.Net Open Roads Forum: Fifth-Wheels: Different kind of Jack-knife
 > Different kind of Jack-knife
happycamper1942
Vancouver Island, British Columbia, Canada
Posted: 10/17/19 02:32am Link  |  Quote  |  Print  |  Notify Moderator
I did this a few days ago. I was making a sharp left turn out of a narrow driveway onto the highway and the wheels of my fiver went down the ditch resulting in the bed area twisting and digging into the side of the truck bed. Very little damage to the 5th wheel.
2008 Ford F350 crew cab short box PSD, 2005 28 foot Gulfstream Innsbruck 5th wheel.
alexleblanc
Shediac N.B
Posted: 10/17/19 04:34am Link  |  Quote  |  Print  |  Notify Moderator
That plain sucks, I’ve seen that damage many times before though, so clearly you aren’t the only one that’s had this happen to over the years.
TV - 17 F350 CCSB SRW Platinum 6.7 + 5er - 15 Durango 296BH + B&W Companion
others - 17 Shelby GT350 | 17 Explorer Sport | 14 Mustang GT | 87 Regal GN | 37 Plymouth Coupe | 19 Yamaha Wolverine X4 SE | 12 John Deere 1023E
MFL
Midwest
Posted: 10/17/19 04:39am Link  |  Quote  |  Print  |  Notify Moderator
That could happy easily, when a FW is put in a off camber maneuver. Sometimes, even good cab, and bed rail clearance, just isn't enough, but takes takes a very alert/aware driver in extreme situations. We all make mistakes, things happen...the good news...usually easier to get the TV repaired, than the trailer.
Thanks for sharing, and helping us to be more aware.
Jerry
valhalla360
No paticular place.
Posted: 10/17/19 05:20am Link  |  Quote  |  Print  |  Notify Moderator
It sucks but not really a "jack knife"
Also not a new issue. Plenty of discussion about minimum clearance between truck bed and 5er overhang...though not many will have enough to handle falling into the ditch.
Tammy & Mike
Ford F250 V10
2008 Copper Canyon 5er
Catalac Catamaran 34'
Full Time spliting time between boat and 5er
Roger10378
Goodrich, MI.
Posted: 10/17/19 06:08am Link  |  Quote  |  Print  |  Notify Moderator
I drove through the ditch getting my 5er home for the first time. It didn't hit the truck but the steps of the 5er took a beating. I ended up widening the driveway 4 ft so that I can get in and out of it.
2005 Cardinal 30TS
2007 Chevy 2500HD D/A
wanderingaimlessly
SOBOVA
Posted: 10/17/19 06:48am Link  |  Quote  |  Print  |  Notify Moderator
With it appearing that all the truck makers are building them taller from the factories with 18-20 inch wheels and taller off road suspensions, this will continue.
How many now have a problem of not being able to lift full profile 5ers any farther without going above the 13'6" mark? Folks either are already are or soon will be forced to reduce side rail clearance to stay lower overall.
blofgren
Surrey, B.C.
Posted: 10/17/19 08:51pm Link  |  Quote  |  Print  |  Notify Moderator
X2. I’ve seen this type of damage as well and wondered how it happened.
It doesn’t take much of a glitch with a truck and fifth wheel to make for a very bad day.....
2013 Ram 3500 Megacab DRW Laramie 4x4, 6.7L Cummins, G56, 3.73, Maximum Steel, black lthr, RAM 20k sliding hitch, Retrax, Linex, and a bunch of options incl. cargo camera
SDcampowneroperator
South Dakota
Posted: 10/17/19 09:18pm Link  |  Quote  |  Print  |  Notify Moderator
Your hich should not have allowed more that a 7 deg. side to side tilt. If you have the minimum recommended 6" bed to overhead clearance, the hich would limit the roll between tow and towed, making the truck tilt with the trailer when that limit is reached.
Should you also encounter a high point vs a low point dip, the risk of bed to trlr. increases.
Raise the trucks 5er hitch, or lower the pin box to give better clearance.
valhalla360
No paticular place.
Posted: 10/17/19 10:15pm Link  |  Quote  |  Print  |  Notify Moderator
One side of the 5er dropped into a ditch...a couple inches more clearance likely wouldn't have solved the issue.
lee worsdell
elmvale
Posted: 10/18/19 05:08am Link  |  Quote  |  Print  |  Notify Moderator
Did the same thing but not as bad. Leaving a sloped driveway didn't notice until I got to my destination 12hrs later. I thought I had heard a weird noise but didn't think nothing of it.
