RV.Net Open Roads Forum: General RVing Issues: Covering up holes in paneling
 > Covering up holes in paneling
Powertour
Nevada
Posted: 10/17/19 11:28am Link  |  Quote  |  Print  |  Notify Moderator
Moron that had my coach before me installed a TV/TV mount in an asinine position at the foot of the rear bed (super low just off the bed surface). In addition to having to strain your next to watch any TV back there the TV itself was right in the way of pretty much everything & we were constantly making contact with it.
So, I moved everything up high now but was left with about a 1/2 dozen holes in the wall that are probably around 5/16ths - 3/8ths in diameter.
We can't do the obvious & 'hang a picture over them' b/c again, the holes where the TV mount was is super low on the wall.
Any other suggestions on how to plug/cover/patch would be appreciated. Push come to shove I'll just leave them but they're kind of an eye sore given what the previous owner did & how it did it.
Thanks in advance!
2015 Itasca 25b Ford E350 V10
ScottG
Bothell Wa.
Posted: 10/17/19 11:37am Link  |  Quote  |  Print  |  Notify Moderator
Mirror? [emoticon] [emoticon] [emoticon] [emoticon]
Scott, Grace and Wesly
2018 Silver Fox 32A.
H0NDA eu2000i
corvettekent
Marysville, WA
Posted: 10/17/19 11:44am Link  |  Quote  |  Print  |  Notify Moderator
The hardware store may have some plastic or wood plugs to full the holes. Then try to paint them to match the wallboard. I know this will not be perfect but it would look better than the holes.
2007.5 GMC Dually EC/LB, LMM. Banks IQ, Speed Brake, Six Gun. B&W Turnover Ball, Companion Hitch, Amp power steps. Hadley Air horns.
2004 32' Carriage 5th wheel. 480 watts of solar MPPT and four 6 volt batteries. Samlex 2,000 watt Pure Sine Wave Inverter.
Dutch_12078
Winters south, summers north
Posted: 10/17/19 11:49am Link  |  Quote  |  Print  |  Notify Moderator
One easy fix if the holes aren't too spread out is to attach a blank 2-gang wall plate over the holes using small wood screws instead of the screws that come with it. Use a plate color that matches your outlets and the wood screws can be painted to match with nail polish, etc.
One example:
2-Gang Midway Blank Nylon Wall Plate, White
Dutch
2001 GBM Landau 34' Class A
ependydad
Here and there
Posted: 10/17/19 01:21pm Link  |  Quote  |  Print  |  Notify Moderator
One example:
I like that. I might have a friend paint something on it so that it's a small decorative piece.
2017 Spartan 1245 by Prime Time
2018 Ram 3500 Crew Cab DRW w/ 4.10 gears and 8' bed
FW Hitch: TrailerSaver TS3
Learn to RV- learn about RVing - Towing Planner Calculators - Family Fulltiming FB page
DrewE
Vermont
Posted: 10/17/19 02:57pm Link  |  Quote  |  Print  |  Notify Moderator
Maybe you could mount some sort of a cargo net stuff holder gizmo there to stash your pajamas and, well, whatever other random stuff needs stashing.
Dick_B
Palos Heights, IL USA
Posted: 10/17/19 08:16pm Link  |  Quote  |  Print  |  Notify Moderator
Stay with the picture idea but leave out the frame. Just glue or velcro it to the wall.
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
One wife, two electric bikes (both Currie Tech Path+ models)
JimR 1
Brandon, South Dakota
Posted: 10/17/19 10:07pm Link  |  Quote  |  Print  |  Notify Moderator
Go buy some fake stick on bullet holes and stick them on the wall.
May not look good but the conversation may be good. [emoticon]
JimR
PastorCharlie
NC
Posted: 10/18/19 07:51am Link  |  Quote  |  Print  |  Notify Moderator
Wallpaper the room.
DutchmenSport
Indiana
Posted: 10/18/19 08:23am Link  |  Quote  |  Print  |  Notify Moderator
Cover them with a small chalk board. At night, write on it your current location, and campground site number. When you wake up in the morning and have that instantaneous, "Um... where am I?" moment, you can look at the chalk board and remember immediately. It might also come in handy in the event of an emergency, if you are in a panic and need to call 911.
Well... it's just an idea...
