RV.Net Open Roads Forum: General RVing Issues: Covering up holes in paneling
 > Covering up holes in paneling
bpounds
Sophmore Brain...
Posted: 10/18/19 09:56am Link  |  Quote  |  Print  |  Notify Moderator
You said paneling, so I assume some kind of wood grain surface. They make peel and stick fake paneling in a wide variety of colors/species. Get a small piece, cut some circles, and stick them over the holes. Won't be perfect, but it is still a camper at the end of the day.
2006 F250 Diesel
2011 Keystone Cougar 278RKSWE Fiver
Lenny K
Vancouver Island or Quartzsite
Posted: 10/18/19 11:22am Link  |  Quote  |  Print  |  Notify Moderator
I would use wood filler crayons available at Home depot or Lowes or online.
Easy to use and if you take your time those holes will become almost invisible.
Lenny and Ros
2009 Chevrolet Silverado 3500 LTZ Duramax 4x4 CC Dually, Banks Speed Brake
2012 Montana 3400 RL 680 Watts Solar, 440 Amps of Batteries, GP-ISW2000-12 Inverter, Trimetric 2020, EMSHW50C, Sailun Tires
MURPHY55347
Savage, MINNESOTA
Posted: 10/18/19 03:46pm Link  |  Quote  |  Print  |  Notify Moderator
Buy a flat cold air return grill. They make them in many different sizes. They may only come in white but you could always paint it a color to blend in with the wall.
mobeewan
Hampton, Va
Posted: 10/18/19 05:25pm Link  |  Quote  |  Print  |  Notify Moderator
Wood grain paneling repair tape
Peel and stick hole covers. Also called peel and stick cover cap
The manufacturer gave me a couple sheets that matched my paneling when I had it in for warranty work.
* This post was edited 10/18/19 05:53pm by mobeewan *
B.O. Plenty
Minnesota
Posted: 10/18/19 06:15pm Link  |  Quote  |  Print  |  Notify Moderator
A piece of molding above and another below. Run these from corner to corner in the room. Fill in between them with a strip of wood in a contrasting color or wallper or tile or whatever.
B.O.
Former Ram/Cummins owner
2015 Silverado 3500 D/A DRW
Yup I'm a fanboy!
2016 Cedar Creek 36CKTS
SARGUY
North America
Posted: 10/18/19 09:38pm Link  |  Quote  |  Print  |  Notify Moderator
Get a sheet of decorative paneling something like they use in some RV ceilings,then cut it to fit and glue it to the existing panel.
CavemanCharlie
Storden,MN
Posted: 10/18/19 10:04pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, I owned a camper that had a grill like that mounted to the outside of the camper. It looked like a normal intake for something (Fan, fridge, etc.) I couldn't figure out why something like that was in that location. I removed it and found that the previous owner had poked a hole in the side of the camper. After filling the hole it still looked bad so he just covered it up with this.
No one ever suspected a thing or noticed it at all.
Powertour
Nevada
Posted: 10/22/19 07:13am Link  |  Quote  |  Print  |  Notify Moderator
Some great ideas, thanks much everyone!
2015 Itasca 25b Ford E350 V10
