1320Fastback
Vista, Ca
We did exactly that with the wifes Tacoma. Hers is a 2010 model and I found brand new, less than 50 miles in total 2019 tires and rims for $500.00. At that price to get new factory rims and brand new name brand tires how could you go wrong.
I'd only switch to a higher load range OP if you tow quite a bit, otherwise stay at current load capacity and name brand.
1992 D250 Cummins, 5spd, 4"' straight piped, sensors deleted, airbags, DAP injectors, 18cm.
1320Fastback
Vista, Ca
Why does Android double post?
last
edited 10/19/19 12:19pm by 1320Fastback *
View edit history
dockmasterdave
florida
I have a 14 f 150 ecoboost that came with michelins.
When they wore out at about 40,000 miles I went to Continentals. I got a much more agressive tread pattern, no more noise or stiffer ride, and Da** these things stick.
I'm now about 60,000 miles and thinking it won't be long before I need new and I am certainly buying another set of the Conty's.
They always did make a good tire. I have the " terrain contacts ".
I tried to put them on my 2010 f 150 as well but they didn't have the size I needed.
I never knew this site wouldn't allow a minor cuss word. but it keeps editing it.
2014 F 150 ecoboost
2010 F 150 4.6L
2007 ranger
09 Amerilite 21 (modified)
2013 Bendron 14' enclosed cargo
2011 4x8 open cargo
philh
Belleville MI
continentals look interesting.
time2roll
Goodyear Wrangler All Terrain with Kevlar works great on mine.
Or do you want the lowest possible price?
675w Solar pictures back up
philh
Belleville MI
time2roll wrote: Goodyear Wrangler All Terrain with Kevlar works great on mine.
Best value
ls1mike
Bremerton
philh wrote: time2roll wrote: Goodyear Wrangler All Terrain with Kevlar works great on mine.
Best value
I just put Cooper Discoverer AT3 XLTs on my 2017 1 ton gasser.
I have about 4000 miles on them It was 1000 bucks all the way around. I really like them. It I had it to again they make a step below these that are similar but cheaper I would have went with those.
Mike
2017 Chevy 3500HD 6.0 Crew Cab Long bed
2012 Passport 3220 BHWE
Me, the Wife, two little ones and two dogs.
BarabooBob
Baraboo, WI
I also have the Goodyear All Terrain Kevlar tires. They are great in snow, mud and rain. I will get them again.
Bob & Dawn Married 31 years
2017 Viking 17RD
2011 Ford F150 3.5L Ecoboost 420 lb/ft
Retired
packpe89
NC
I just put Falken Wildpeak on my f150 and also had them on my chevy 2500. Load E, A/T tires that are affordable, last and are not nearly as loud as other similar tires.
IdaD
Idaho
ls1mike wrote: philh wrote: time2roll wrote: Goodyear Wrangler All Terrain with Kevlar works great on mine.
Best value
I'm going to do those or the new KO2 DT tires here in the next month or so. I have the standard KO2 on there now and they just wore too fast but the DT version is supposed to wear better on heavier trucks. Those Coopers look pretty nice though and they're a bit cheaper too. Leaning toward the Coopers at this point. $1000 installed for new diesel truck tires isn't a bad price at all.
2015 Cummins Ram 4wd CC/SB
