RV.Net Open Roads Forum: Truck Campers: Lance Camper charging system
 > Lance Camper charging system
SS_Sean
Canby, OR
Posted: 10/19/19 05:09pm Link  |  Quote  |  Print  |  Notify Moderator
Ive got a 2008 lance 1181. When I plug the camper to shore power over the winter does that trickle charge the batteries and keep them topped off for the winter? I killed two deep cycle batteries over last winter and spring by not attending to them. I got so busy with work and a move across state some of my maintenance suffered. I want to ensure this next pair will live a happy long life...
2019 Chevrolet 3500HD LTZ LBCC DRW
2008 Lance 1181
1993 Reinell Offshore 23'
jimh425
Western MT
Posted: 10/19/19 05:43pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, if you are plugged in, the batteries should stay charged. You can also remove the batteries and maintain them with a battery tender or similar. Also, keep in mind that batteries don’t last forever.
SS_Sean
Canby, OR
Posted: 10/19/19 06:42pm Link  |  Quote  |  Print  |  Notify Moderator
Ok. Yes. I know i can put them on my battery tenders but sasnt sure if the camper actually had a trickle charger. Yes, they were only 2 years old. I fried them y not paying attention. I ended up working 874 hours of o.t. if you can believe it. Lol...
time2roll
Posted: 10/19/19 07:16pm Link  |  Quote  |  Print  |  Notify Moderator
OK so post the converter model number and measure the battery voltage for best answers.
Otherwise in general you can leave the camper plugged in 24/7 and the battery will be maintained just fine.
675w Solar pictures back up
Buzzcut1
Norcal
Posted: 10/19/19 09:28pm Link  |  Quote  |  Print  |  Notify Moderator
I have AGMs in my 2008 Lance 1055 they have been there since 2010. Plugged into a shore line when at home, solar on the road. You should be fine unless you are using wet cells and you don't maintain the water level.
2011 F350 6.7L Diesel 4x4 CrewCab longbed Dually, 08 Lance 1055, Torqlift Talons, Fast Guns, upper and lower Stable Loads, Super Hitch, 48" Super Truss, Airlift loadlifter 5000 extreme airbags
Kayteg1
California > Nevada
Posted: 10/19/19 10:45pm Link  |  Quote  |  Print  |  Notify Moderator
The technology those days change on weekly bases, so unless you post what kind of converter you have as suggested, we can only guess.
My 2002 Lance converter charges at 14.5 V, what on long run will boil battery dry.
If I leave battery in the camper, I charge it for a day every 2 months and then switch it off.
ardvark
Bristol, TN.
Posted: 10/20/19 04:49am Link  |  Quote  |  Print  |  Notify Moderator
Given that converters also have a limited lifespan this is an excellent strategy if the camper is going to sit for a prolonged period of time. [emoticon]
garym114
Bluff Dale, Texas
Posted: 10/20/19 08:55am Link  |  Quote  |  Print  |  Notify Moderator
Another option is to charge them fully, then disconnect the ground cable. There will be zero battery load and they will not freeze. No worries about water levels or overcharging.
Stored my MH and toad in Anchorage like this for four winters, eight batteries total with no problems.
SidecarFlip
SE Michigan
Posted: 10/20/19 10:01am Link  |  Quote  |  Print  |  Notify Moderator
+1 Do that with farm tractors. I use a knife switch disconnect on the NEGATIVE post. Sit all winter in an unheated barn. No issue. Parasitic loss on a flooded cell with no load is about 3% a month.
2015 Backpack SS1500
1997 Ford 7.3 OBS 4x4 CC LB
Kayteg1
California > Nevada
Posted: 10/20/19 10:21am Link  |  Quote  |  Print  |  Notify Moderator
When I had my conversion in no-power storage, I would just pull the clamps on batteries for winter storage. Even attached cables with some humidity will create small current leak.
The engine batteries do like recharge every 6 months, so I would take them home, but golf-cart batteries hold good charge even after 10 months.
Than the batteries from seasonal vehicles usually end along garage wall and hooked up to battery maintainers.
Even with current price at $9, there is no excuse not to have them.
