RV.Net Open Roads Forum: Class A Motorhomes: Interior dash lights flickering
 > Interior dash lights flickering
howdy35
Athens, Texas
Posted: 10/19/19 10:45pm Link  |  Quote  |  Print  |  Notify Moderator
When I pull on the lights for night driving, my interior dash lights flicker. I'm wondering if I need to replace the light switch. Thoughts?
1999 National Tradewinds 7370
2014 Honda CR-V--Toad
Fulltime
pianotuna
Regina, SK, Canada
Posted: 10/20/19 12:14am Link  |  Quote  |  Print  |  Notify Moderator
More likely a bad ground from corrosion.
Regards, Don
Corkey05
Washington State
Posted: 10/20/19 06:26am Link  |  Quote  |  Print  |  Notify Moderator
It could possibly be your dimmer control.
I had that happen and turned the dimmer control to both limits (full bright to full dim) several times .... all was well and hasn't happened since.
2008 HR Endeavor PDQ - Ford Edge 4 Down
FMCA F374292
DFord
Near St Louis, MO
Posted: 10/20/19 07:53am Link  |  Quote  |  Print  |  Notify Moderator
What are your headlights doing while the dash lights are flickering? There may be a short in that circuit causing the interior lights to flicker. There's probably an auto reset circuit breaker trying to keep the headlights on.
Don Ford
'09 HHR 2LT or '97 Aerostar MiniVan (Remco driveshaft disconnect) for Towed vehicles
dougrainer
Carrolton, Texas
Posted: 10/20/19 08:12am Link  |  Quote  |  Print  |  Notify Moderator
Your model motorhome should have a FORD Headlight switch. IF the only lights that flicker are the Dash lights, odds are the rheostat for the dimmer in the Headlight switch is bad. The Ford switch is easy to replace. Doug
Wild Bill 888
Denver
Posted: 10/21/19 12:08am Link  |  Quote  |  Print  |  Notify Moderator
Could also be alternator/regulator. Led headlights are self regulating and may not flicker.
dougrainer
Carrolton, Texas
Posted: 10/21/19 06:10am Link  |  Quote  |  Print  |  Notify Moderator
His 20 year old motorhome does not have LED lights. Doug
howdy35
Athens, Texas
Posted: 10/22/19 07:34am Link  |  Quote  |  Print  |  Notify Moderator
My headlights are fine. I am going to replace the light switch. Thanks, Doug, I didn't know it might be a Ford switch. Will let you know the results.
