RV.Net Open Roads Forum: Technology Corner: weak antenna signal
 > weak antenna signal
dockmasterdave
florida
Posted: 10/20/19 05:15pm Link  |  Quote  |  Print  |  Notify Moderator
OK, I posted the other day looking for info on an aftermarket antenna booster. My Wineguard from 2009 DOES NOT have the internal boost, at least , there is no switch and no 12v plug and no 12v wiring anywhere near it.
I took apart my connections today, put dielectric grease on them and made sure all were tight.
I discovered that from my antenna to the ceiling plate is RG59.
Would it help to switch it to RG6, and does it really just pull all the way through the ceiling to install the new?
I have visions of it disconnecting somewhere mid ceiling and requiring ripping the ceiling down to re connect.
It is in an Amerilite 21MBLE
Thanks again
2014 F 150 ecoboost
2010 F 150 4.6L
2007 ranger
09 Amerilite 21 (modified)
2013 Bendron 14' enclosed cargo
2011 4x8 open cargo
ScottG
Bothell Wa.
Posted: 10/20/19 05:28pm Link  |  Quote  |  Print  |  Notify Moderator
For that short of distance, no.
I have seen the ends put togther totally wrong. They cut all the shielding off and just used the center conductor.
I would check for continuity from end to end and between coductors.
Scott, Grace and Wesly
2018 Silver Fox 32A.
H0NDA eu2000i
CA Traveler
The Western States
Posted: 10/20/19 05:39pm Link  |  Quote  |  Print  |  Notify Moderator
The switch could be anywhere if it exists and they are normally hard wired so no plug. Replace the antenna with one that has a amplifier, add the switch etc. No need to replace RG59 unless it's defective. And no splitters between the wall plate and antenna.
Unlikely you can pull a new coax with the old. If you need new coax just reroute it like on the roof, closet, walls etc as needed.
2014 Grand Cherokee Overland
Bob
edbehnke
North America (from Michigan)
Posted: 10/21/19 05:25am Link  |  Quote  |  Print  |  Notify Moderator
I hate it that they still use RG59 cabling. But that isn't the issue.
You need to call winegard to find out what antenna you have. I suspect you do have an amplified antenna...but? Winegard does have great support.
https://winegard.com/products/hdtv-digital-antennas/outdoor-antennas
eddie and sandie
3402 Montana 2013
Ford F350 2015
BarneyS
S.E. Lower Michigan
Posted: 10/21/19 07:33am Link  |  Quote  |  Print  |  Notify Moderator
Move to Technology forum from DIY.
RLS7201
Posted: 10/21/19 10:28am Link  |  Quote  |  Print  |  Notify Moderator
You could step up to the good stuff.
Sensar IV amplified antenna. About $52.00
Sensar Pro secondary amp, signal finder. About $60.00.
95 Bounder 32H F53
460/528 stroker
Web Master
MWPSchooners.com
First brake job
1941 Hudson
Wherever I happen to park
Posted: 10/21/19 03:00pm Link  |  Quote  |  Print  |  Notify Moderator
2009 it most likely DOES have an amp.. Where the switch is I do not know.
There are 3 popular types of switches
1: the famous wall plate (and the Sensar Pro upgrade.. I'll count them as one)
2: Box of many buttons (Matrix switch) two switches (Power and ANT) need to be pushed
3: A plain switch. nothing else, may be on a full size wall plate or a small cube, most anywhere.. This is used with a POWER INSERTER another cube) somewhere on the power line.
NOTE blown fuses will prevent 12 volt from reaching antenna.
Home is where I park it.
Lynnmor
Red Lion
Posted: 10/21/19 04:11pm Link  |  Quote  |  Print  |  Notify Moderator
Winegard still makes antennas without an amplifier. All an amplifier can do is overcome signal loss downstream from the antenna. For a single TV that is close to the antenna, an amplifier will only help a small amount. For multiple TVs using splitters and long cable runs is where an amplifier will show the most gain.
RLS7201
Posted: 10/24/19 06:50pm Link  |  Quote  |  Print  |  Notify Moderator
Just so you know, many trailers are built with no amp. in the antenna. I hate to say "low budget" but..........
Tom_M
New Hope, MN
Posted: 10/25/19 07:43am Link  |  Quote  |  Print  |  Notify Moderator
2010 I replaced my un-amplified antenna with an un-amplified Winegard Sensar III. The amplifier is in the wall plate. If you suspect that your wall plate is defective you can purchase an amplified wall plate. Here's one on Amazon:
Winegard 18-9847 RA-7296 Wall Plate Signal Amplifier-White
Tom
2005 Born Free 24RB
Towing 1978 VW Bug convertible
Minneapolis, MN
