RV.Net Open Roads Forum: Tech Issues: Using water below freezing?
 > Using water below freezing?
swimmer_spe
Sudbury, Ontario, Canada
Posted: 10/21/19 11:28pm Link  |  Quote  |  Print  |  Notify Moderator
I hunt, and hunting season ends mid December. My current RV has a decent water system and a decent furnace. I am wondering, providing there is heat in the RV, and if I only use the holding tanks, would there be a risk of freezing?
valhalla360
No paticular place.
Posted: 10/21/19 11:56pm Link  |  Quote  |  Print  |  Notify Moderator
Maybe...maybe not.
Sudbury Ontario is pretty far north, so a cold snap could get pretty cold even in December.
Also, we don't know what model RV you have. Some have tanks largely enclosed and the furnace "wastes" some of the heat into the underbelly giving you a much lower risk of freezing. Others have the tanks fully exposed, so much easier to get freeze issues.
Then if you have access to electricity, there are heating pads and other options to mitigate, so it is possible.
In our last 5er, we were down to -5F for a couple of days. Lost the stinky slinky hose as it froze solid and I tore it trying to get it disconnected without waiting for it to melt...but otherwise no damage.
Tammy & Mike
Ford F250 V10
2008 Copper Canyon 5er
Catalac Catamaran 34'
Full Time spliting time between boat and 5er
lane hog
Tucson, AZ & NW Chicago Burbs, IL
Posted: 10/22/19 04:16am Link  |  Quote  |  Print  |  Notify Moderator
In a holding tank, there's usually more than enough room for expansion as the fluids freeze. Pink is relatively cheap -- dump a couple gallons in the tank, and you might be OK.
  • 2005 Winnebago "Minnie" 31C (was a three-time Jayco owner)
  • 2012 MasterTow Dolly pulling a 2003 Jeep Liberty (had Ram 2500 CTD, Dodge Durango, Honda Odyssey...)
  • Onan Microquiet 4000, plus 130W solar and Honda EU2000i twins for backup
IB853347201
Eastern Ontario
Posted: 10/22/19 07:49am Link  |  Quote  |  Print  |  Notify Moderator
Wow Sudbury in December? I wouldn't advise it unless you have a MH and all your water lines and tanks are enclosed in a heated basement. Forecast right now for end of November is 15F or -9C. That'll definately freeze any exposed water lines....
Touring in our 2010 Suncruiser, beaches, site seeing, national parks, chillaxing..
JaxDad
Greater Toronto Area
Posted: 10/22/19 08:06am Link  |  Quote  |  Print  |  Notify Moderator
A friend found out the hard way, the first part of the grey black tanks is the very exposed pipes / dump valves. Even with an RV with heated tanks these parts are not heated.
Provided it does all work, how are you going to winterize it at the end of the hunt?
DrewE
Vermont
Posted: 10/22/19 08:37am Link  |  Quote  |  Print  |  Notify Moderator
Different RVs have differing provisions for heating tanks and such. On my motorhome, the dump valves are in a (nominally) heated compartment along with the tanks, and so protected from freezing.
It gets winterized after use in freezing weather the same as at any other time--drain out the water and sewage, and either blow out the lines or pump in antifreeze. The only difference is that I have to do it fairly expeditiously after I'm done camping, rather than waiting a week for a convenient time.
swimmer_spe
Posted: 10/22/19 09:09am Link  |  Quote  |  Print  |  Notify Moderator
OP here.
Trailer is an ultralight. No heated tanks. No heated or insulated dump valves.
Sounds like I might be ok, but most likely will have my holding tanks getting slushy. Not sure if it's worth the risk.
As far as winterizing, I would pump in plumbing antifreeze like it is recommended around here.
time2roll
Posted: 10/22/19 09:35am Link  |  Quote  |  Print  |  Notify Moderator
As long as you have a place to plug in you can certainly prepare your RV to operate into the cold by adding the necessary pipe and tank heaters.
www.ultraheat.com
675w Solar pictures back up
Jayco-noslide
Galesburg,Il., USA
Posted: 10/22/19 02:19pm Link  |  Quote  |  Print  |  Notify Moderator
If you just use water from your tank is 1 thing but if you hook to a city water, the hose will freeze upper 20s or less. Also, the valves to drain the tanks will freeze up. If it just get a few degrees below freezing for an hour or 2 might work but colder and longer is a problem.
Jayco-noslide
maillemaker
office
Posted: 10/22/19 02:30pm Link  |  Quote  |  Print  |  Notify Moderator
I'm in Alabama, and I've had my waste gate valves get frozen in our relatively weak winters. No damage, but I could not dump the tanks until they thawed out.
In my old RV the grey and black water tanks are exposed to the elements, and the waste gate valve is hanging out there, too.
Maybe you can stop your tanks from freezing up by dumping some RV antifreeze into your black and grey tanks. Say a gallon in each?
1990 Winnebago Warrior. "She may not look like much but she's got it where it counts!"
