RV.Net Open Roads Forum: Tech Issues: Portable or Hardwired EMS?
 > Portable or Hardwired EMS?
Powertour
Nevada
Posted: 10/22/19 01:13pm Link  |  Quote  |  Print  |  Notify Moderator
To me it'd be a no-brainer to have a hard wired unit if we were full timers but we're not.
Wondering if it'd make more sense to get an exterior unit considering:
- We're weekenders
- I can see where we might change out rigs sometime within the next 5yrs
Also, I can see benefit in being able to test different pedestals w/out having to move the rig should a fault be found at an initially assigned spot.
Understand a big downside is potential theft of exterior EMS units, just wondering if other than that there's much of a downside to having one.
2015 Itasca 25b Ford E350 V10
Iraqvet05
Greenwood, MO
Posted: 10/22/19 01:39pm Link  |  Quote  |  Print  |  Notify Moderator
One advantage of a hardwired unit is you can't forget it. Also, many hardwired units offer more protection than their portable counterparts: https://www.progressiveindustries.net/portable-hardwired-comparisons
2017 Ford F-250 6.2 gas
2018 Jayco 28BHBE
US Army veteran
rockylarson
Jersey Shore
Posted: 10/22/19 01:47pm Link  |  Quote  |  Print  |  Notify Moderator
I secure mine with a heavy chain and a good lock. They would have to come prepared and/or destroy the pedestal to walk off with it.
You can use it to test before pulling into a site or you can test with a less expensive tool. Mine partially failed under warranty and
was repaired and returned in under a week. Hard wired maybe convenient but its not for me.
Jan and Rocky
Volunteers for USFWS. 25 refuges with 8000 hrs ea since 2006. 2004 Allegro 30DA, Workhorse 8.1, Banks, 2012 Jeep Liberty Jet, Blue Ox Aladdin, Brake Buddy Advantage Select, 300 watts solar, 5 Optima group 31 AGM's, 2000watt Ames PSW inverter.
Near Annett’s Mono Village, Bridgeport, CA
Posted: 10/22/19 01:53pm Link  |  Quote  |  Print  |  Notify Moderator
Rocky's lock suggestion is a good one.
MDKMDK
Canada
Posted: 10/22/19 02:01pm Link  |  Quote  |  Print  |  Notify Moderator
- We're weekenders
Depending on where your 30A/50A shore power cord is stored, you can plug a portable EMS like the PT-30X into your shore cable, keep the portable inside the (lockable?) electrical bay compartment, and buy a second 30A shore power extension cord, and use that between the electrical bay/EMS and the c/g power post. Cheaper to lose an extension cord than the EMS. It's how I do it.
If your portable ever fails for any reason, and you're under warranty, it's easier to send it back, than unistalling the hard wired versions or trying to replace parts in it.
Not sure about "more" protection from hard wired units. Dubious?
Mike.
2018 (2017 Sprinter Cab Chassis) Navion24V + 2016 Wrangler JKU (sold @ ????)
2016 Sunstar 26HE, V10, 3V, 6 Speed (sold @ 4600 miles)
2002 Roadtrek C190P (sold @ 315,000kms)
Powertour
Nevada
Posted: 10/22/19 02:07pm Link  |  Quote  |  Print  |  Notify Moderator
Brilliant!
MDKMDK
Canada
Posted: 10/22/19 02:14pm Link  |  Quote  |  Print  |  Notify Moderator
Powertour wrote:
If your portable ever fails for any reason, and you're under warranty, it's easier to send it back, than uninstalling the hard wired versions or trying to replace parts in it.
Brilliant!
Aw shucks, tweren't nuthin. [emoticon]
CA Traveler
The Western States
Posted: 10/22/19 02:25pm Link  |  Quote  |  Print  |  Notify Moderator
My 2004 hardwired unit is in the second rig. In each case it's installed without cutting/splicing any existing wiring so trivia to remove and restore original wiring. It also has a remote display inside the rig which is a HUGE advantage over a portable. Voltage, amps, error codes are all easy to see. A data wire has to be routed to the remote.
2014 Grand Cherokee Overland
Bob
rk911
DuPage County
Posted: 10/22/19 02:26pm Link  |  Quote  |  Print  |  Notify Moderator
we chose the hard wired unit for convenience (we are nit FT). a bonus was the remote monitor mounted inside the coach.
Rich
Ham Radio, Sport Pilot
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'03 Jeep Wrangler TJ
'10 Jeep Liberty KK
& MaggieThe Wonder Beagle
MDKMDK
Canada
Posted: 10/22/19 02:42pm Link  |  Quote  |  Print  |  Notify Moderator
Ya gotta plug it in, don't you? You can easily see the portable unit's display as well, when you're outside the coach doing that. If it reacts to something and cuts power, you're not likely going to be able to either trouble shoot or resolve it from the comfort of the inside of your coach, you're most likely going to have to exit the vehicle at some point to resolve the problem, so it's really not a huge advantage. Very few shore power issues occur inside your coach.
