RV.Net Open Roads Forum: Tech Issues: Brake fluid change?
 > Brake fluid change?
Page of 8
Westcoasting
westcoast
Posted: 12/15/19 12:09am Link  |  Print  |  Notify Moderator
Wow every two years... I've seen it all now!!
babock
Los Angeles, CA
Posted: 12/20/19 12:53am Link  |  Print  |  Notify Moderator
Mercedes says replace every two, Lexus every 3, Honda every 3. If you know more than the auto manufacturers...then don't replace it! Your vehicle!
GDS-3950BH
DC
Posted: 12/20/19 03:25am Link  |  Print  |  Notify Moderator
I've had so many different vehicles I've lost count since @ 1984 between personal and company provided ones. I never changed brake fluid on any except one. It was a 2001 GMC 1500 that all the lines rotted out @2013 at 260,000 miles. They did not rot from the inside out. I can't remember even adding fluid unless due to changing pads. I'll stick with the roll the dice method.
otrfun
Desert SW
Posted: 12/20/19 04:17am Link  |  Print  |  Notify Moderator
babock wrote:
otrfun wrote:
Most would agree a total brake bleed/flush is the most effective maintenance approach. However, to say anything short of a total brake bleed/flush is "ridiculous", well, that sounds like someone who may have the luxury of excess time and/or money on their hands. For the rest of us, I think common sense says maintenance doesn't have to be all or nothing to be effective.
Yes..a total brake fluid bleed/flush is the most effective maintenance approach.
Glad you agree with me!
Glad to see selective reading, bold quotes, and taking comments out of context, gives you so much joy and pleasure—lol!
Dave H M
IL
Posted: 12/20/19 06:39am Link  |  Print  |  Notify Moderator
you guys just keep it up. I have never changed brake fluid and never will. [emoticon]
T18skyguy
Eugene, OR
Posted: 12/20/19 08:30am Link  |  Print  |  Notify Moderator
If your the kind of person who trades a vehicle regularly, say every 5 or even 8 years, sure you can ignore it and the vehicle will still stop. If you like to keep your vehicles, like my dad use to say, "until the wheels fall off", then flushing on a regular basis is a good idea. I think it's an especially good idea for more heavy duty vehicles like motor homes, because of their weight plus folks tend to keep them a long time. Another issue is if you never crack open the bleed screw, it has a tendency to rust and then break off, especially in salted road country. Most people don't do it cause it such a PIA. I use a Branick pro brake bleeder which makes it much easier, but you need to buy a master cylinder adapter kit to go with it. I can't say for sure why this RV lost it's brakes, but there was a similar accident up there where a husband and wife we're killed after overheating their brakes coming down a mountain. Warning, the video is a bit graphic.
* This post was edited 12/20/19 08:42am by T18skyguy *
Retired Anesthetist. LTP. Pilot with mechanic/inspection ratings. 2017 Jayco Greyhawk 31FS. Wife and daughter. Three cats which we must obey.
babock
Los Angeles, CA
Posted: 12/20/19 09:29am Link  |  Print  |  Notify Moderator
Sure does! And again...glad you agree with me!
babock
Los Angeles, CA
Posted: 12/20/19 09:38am Link  |  Print  |  Notify Moderator
Until you have a newer vehicle where the $1500 ABS unit fails on you. It takes less than an hour and $20 worth of brake fluid to do it.
There are people that never go to the doctor, never get vaccinated, smoke, never exercise are over weight and say they roll the dice and are fine! Doesn't mean what works for one person should work for everyone. If the manufacturer recommends doing this maintenance, why ignore the people that designed the vehicle?
GDS-3950BH
DC
Posted: 12/20/19 10:19am Link  |  Print  |  Notify Moderator
I have had more than a few different trucks since the 90's that had ABS,at least 10 without thinking too hard, and despite not ever changing brake fluid I have never replaced an ABS unit. I have also never had to replace a caliper, wheel cylinder or master cylinder. I never lost my brakes while driving down the road other than when the 2001 popped a line at 260,000 miles. I still was able to stop. I guess I'm living dangerously and will continue doing so, maybe its just blind luck.
babock
Los Angeles, CA
Posted: 12/20/19 11:01am Link  |  Print  |  Notify Moderator
I have electric over hydraulic brakes on one of my trailers. I let it go 5 years and never changed the fluid. One day before a trip I was checking the brakes and the pump unit stopped working. Low and behold, after taking the unit apart, the fluid had gotten moisture in it and seized the pump. $800 later, had to buy a new unit. All it would have taken was around 30 minutes to flush the fluid and it would have saved me $800!
My Lexus GS300 has an ABS unit with a pump. Replacements are over $2K. I follow Lexus's recommendation to change the fluid every 3 years.
Interesting hearing people that brag about skipping recommended maintenance! Seems like a weird thing to brag about!
Page of 8
