RV.Net Open Roads Forum: Class A Motorhomes: mystery switch
 > mystery switch
JOERVDREAM
quincy, ca
Posted: 10/23/19 09:07am Link  |  Quote  |  Print  |  Notify Moderator
I have a 2005 Winnebago sightseer 29r. In the cabinet on the right of the tv in the cab area is a button that when you push down a green light comes on and when you push it again the light goes off? Also the outlet plates in the cabinets next to the tv and also in the cabinet in the bedroom where that tv would be are black? There's one across from the refrigerator also? All the rest of the outlet covers are white and are in everyday use areas? An inverter was an option that the previous owner did not get. are these outlets pre-wired for a inverter?
Thanks
Dave in TN
Middle Tennessee
Posted: 10/23/19 09:10am Link  |  Quote  |  Print  |  Notify Moderator
Might be antenna booster?
mleekamp
Washington, IL
Posted: 10/23/19 09:22am Link  |  Quote  |  Print  |  Notify Moderator
That should be the antenna booster as Dave stated. When ON (green light) you are able to pick up channels farther away. I've forgot to turn ours on once or twice, but could still pick up a couple channels. Once, in the SW, left it off and found no channels (far away from town). When back on, I got a few.
2019 Jayco Redhawk 29XK Class C, Ford V10 E450 chassis
2000 Jeep Wrangler for a Dinghy w/ Invisibrake & Curt Tow Bar
RLS7201
Posted: 10/23/19 09:59am Link  |  Quote  |  Print  |  Notify Moderator
The outlets by the TV are switch off when the ignition key is turned on, so the driver can not watch TV while driving. That might be the reason the covers are black.
Richard
95 Bounder 32H F53
460/528 stroker
Web Master
MWPSchooners.com
First brake job
1941 Hudson
Old-Biscuit
Verde Valley
Posted: 10/23/19 11:52am Link  |  Quote  |  Print  |  Notify Moderator
Are these standard outlets (3 prong 120VAC)
OR
Coax Cable connectors
2005 Sightseer 29R wiring
Wherever I happen to park
Posted: 10/23/19 03:49pm Link  |  Quote  |  Print  |  Notify Moderator
IS there anything else on the wall plate where that button is?
Antenna connetion + 12 volt outlet + Antenna booster
Word: Winegard. or Jack or King controls likewise.
Other option:
SOme RV's have an automatic Satellite antenna. and such a switch may power it as well. These make noise. usually 2-5 seconds after power on. (noise usually goes away after a couple minutes or faster)
Home is where I park it.
JOERVDREAM
quincy, ca
Posted: 10/23/19 04:00pm Link  |  Quote  |  Print  |  Notify Moderator
Yes it does say winegard on it. As far as the black outlet plates go they are 120 looking. There is also one in the compartment with the outside stereo radio. It is next to a cig lighter type 12 volt outlet and also a white 120 plate is right above it? None of the manuals I have say anything about them. Thanks Old-Biscuit for the wiring diagram.
time2roll
Posted: 10/23/19 04:01pm Link  |  Quote  |  Print  |  Notify Moderator
My guess the switch is for an inverter to power those black outlets while in transit or camped without utility power.
675w Solar pictures back up
Old-Biscuit
Verde Valley
Posted: 10/23/19 06:47pm Link  |  Quote  |  Print  |  Notify Moderator
My guess also....
No Coax cable connection BUT small on/off button with Winegard on the outlet
Inverter fed outlets/black plates to distingusih them from standard AC Power Outlets AND on/off button for antenna booster
Horsedoc
Dixie --- N. Georgia
Posted: 10/23/19 07:12pm Link  |  Quote  |  Print  |  Notify Moderator
Antenna booster switch. Turn off when cable connected?
 > mystery switch
