RV.Net Open Roads Forum: Upgraded my tow vehicle, do I still need a WDH?
 > Upgraded my tow vehicle, do I still need a WDH?
Page of 5
TomG2
Central Illinois
Posted: 10/30/19 06:15am Link  |  Quote  |  Print  |  Notify Moderator
Slowmover wrote:
What “Ford says” doesn’t mean much. Never did. Has zero legal or insurance consequences. You own and operate it, you’re the one responsible.
Ford will be happy to hear that they can fire their hundreds of lawyers and engineers based on what some guy on the Internet "thinks" or "feels".
1320Fastback
Vista, Ca
Posted: 10/30/19 09:05pm Link  |  Quote  |  Print  |  Notify Moderator
Try it without and see how she handles. Make sure to get on the highway and do a few bridge transitions and have a few rigs pass you to get a real life indication of if it's needed or not.
My older bigger toy hauler I used a WDH but the new smaller one it's not needed. Have towed over 6,000 miles this year without one single issue in all kinds of weather on all kinds of roads including that pos 285 out of Carlsbad. That road could be used to check the weld integrity of hitches spring perches!
Anyway give it a shot without and make a choice afterwards.
1992 D250 Cummins 5psd
2005 Forest River T26 Toy Hauler
RandACampin
Kathleen, Georgia
Posted: 10/31/19 05:04am Link  |  Quote  |  Print  |  Notify Moderator
You really don't understand the purpose of the WDH.
A WDH has nothing to do with your truck and everything to do with the load carrying capacity of your receiver. Sound like you need to educate yourself on the subject, I suggest going to the manufacturer of your receiver and get the numbers. Then compare to the tongue weight of your trailer.
Most likely you have the standard class III hitch; 5K lbs weight carrying and 10K lbs weight dist. Tongue weight is 500 lbs weight carrying and 1000 lbs weight dist.
Slowmover
Fort Worth, TX
Posted: 12/11/19 06:07pm Link  |  Quote  |  Print  |  Notify Moderator
Some guy, huh? Unlike you, one with commercial experience. Where the law obtains is in regards wheel/axle & tire limits. Payload and tow rating are laughable in regards how to use and set a WDH. They don’t apply.
I used to run a DRW Dodge in the oilfield. GCVWR was 20,000-lbs. My loaded trailer —alone — weighed more than that most of the time. Means I was often above 32,000-lbs.
1). Was this a concern to Commercial Vehicle Enforcement?
2). Was this a concern to the weigh stations in Texas and all surrounding states?
3). Was this a concern for insurers covering commercial liability?
4). Was this a concern to the Dodge dealership?
No. Not once. Not ever. Not to anyone with a lick of sense.
That truck & trailer ran roads I’d never take my own down. And it (and its fleet mates) did it for over 300k on average. Without undue wear rates (given how hard we ran; vacationers we weren’t), still, they were done at about 3-3.5/years.
Are you one of those guys wants a guarantee from someone else for your behavior?
Because that’s your argument. If you screw up, it’s Fords fault. Mighty admirable.
But we’ve covered this with you before. Some random guy on the Internet with a make-believe fear. (Failure to think. To investigate).
1990 35' SILVER STREAK Sterling, 9k GVWR
2004 DODGE RAM 2WD 305/555 ISB, QC SRW LB NV-5600, 9k GVWR
Hensley Arrow; 11-cpm solo, 17-cpm towing fuel cost
Huntindog
Phoenix AZ
Posted: 12/11/19 08:03pm Link  |  Quote  |  Print  |  Notify Moderator
First off as has already been said, using WDH generally increases the reciever rating.
Having said that.. A properly setup WD hitch will always result in a better tow.
I am not talking about a normal non eventfull tow... But one in which murhpys law strikes. We have had a couple of those occur to us...But since I am absolutly anal, spending a lot of time on getting the setup perfect.... Everything worked out fine. Otherwise, I probably would have been one of those posters writing about what went wrong for no reason.
I have what many consider to be an overkill lashup. A one ton dually crew cab diesel towing a 11,500 GVW TT. Burt I can feel the difference in a one hole adjustment in my EQUALIZER WD adjustment.
In one incident at night in a new to us area, I was napping, while DW was driving at night. I awoke to her saying oh F oh F. I saw us in a sweeping turn with a speed limit sign of 25 and a glance at what I could see of the speedometer more than double that. we survived as the setup was perfect, The TV/TT act as one unit. Not jacknifing or any other untoward results. The lashup just howled all of the tires equally. It seems that the GPS road program had put her in the wrong lane and directed her onto a clover leaf turnoff... Yeah I know many will critisize this, but in a strange location... It can happen to anyone.. Whether using GPS or not.
The point is that is that sometimes, things go wrong. That is when a properly set up WD system can save your bacon.
It was gratifying to hear DW tell me afterwards that " You have this setup perfect, it did exactly what it needed to do"
* This post was edited 12/11/19 08:26pm by Huntindog *
Huntindog
100% boondocking
2010 Palomino Sabre 30 BHDS
84 gal. Grey. 84 gal. Black
2 bathrooms, no waiting
2020 Silverado High Country CC DA 4X4 Big Dually.
TomG2
Central Illinois
Posted: 12/12/19 08:17am Link  |  Quote  |  Print  |  Notify Moderator
Slowmover wrote:
Some guy, huh?
You are just another "Internet expert" as far as I can tell. One who brags about running at nearly double his vehicle's ratings but telling others how to behave. That surely makes you an expert?????
I trust, but verify, what manufacturers recommend for their products more than someone who brags about how he ran overloaded and got by with it. I suppose if you had run triple your ratings it would make you even smarter???
deltabravo
Spokane, WA
Posted: 12/12/19 07:43pm Link  |  Quote  |  Print  |  Notify Moderator
Twistedlarch wrote:
Hi all, I just upgraded from a Tacoma to a Tundra.
My question is...Do I still need to use the weight distribution hitch?
I'd still use the WD Hitch. It helps improve the ride and handling.
I tow a Nash 17k TT with my dually and still use a WD Hitch. The ride without the WD Hitch is pretty annoying (rough and bouncy)
2018 Timberridge 24RLS (bought pre-owned 3/12/20)
Posted: 12/13/19 02:48pm Link  |  Quote  |  Print  |  Notify Moderator
No comment. (But if you read "into" my response, my answer is hidden in there....[emoticon])
1320Fastback
Vista, Ca
Posted: 12/14/19 12:04pm Link  |  Quote  |  Print  |  Notify Moderator
Is the 410 tongue weight something you have measured or the factory number?
If it is the factory number it is likely around 600 pounds as they do not include batteries or propane tanks and propane in that figure.
Page of 5
