RV.Net Open Roads Forum: Class A Motorhomes: Tx Fluid Level ??
TC&Z
Atlanta, GA USA
Posted: 10/24/19 07:01pm Link  |  Quote  |  Print  |  Notify Moderator
We have a 2007 Winn Voyage 38J with 8.1 L Vortec on Workhorse chassis with 6-speed Allison i. I'm trying to check the Tx fluid and am encountering confusion. The owner's manual shows a photo of the Tx dipstick. It shows only a HOT range and that range is close to the dipstick tip. Yet my actual dipstick has both a COLD and HOT range. The COLD range is near the dipstick tip end and the HOT range is 1" plus further up, each range approx 1/4" wide. This does not match the owner's manual.
I have checked Tx fluid level cold and level and was higher than HOT range??? I have checked Tx fluid at gas station after pulling off long highway and it was higher than HOT range.
Does anyone have any observations to help me resolve my confusion? Just trying to properly maintain our MH and am confused.
Thanks in advance....
ScottG
Bothell Wa.
Posted: 10/24/19 07:51pm Link  |  Quote  |  Print  |  Notify Moderator
Deleted.
Scott, Grace and Wesly
2018 Silver Fox 32A.
H0NDA eu2000i
DFord
Near St Louis, MO
Posted: 10/24/19 10:30pm Link  |  Quote  |  Print  |  Notify Moderator
The level is not critical - unless it's not showing on the dipstick. If it's a little high, don't worry about it. If it's way over the mark, it might foam-up on you. The only way to lower it is slip a small tube into the dipstick tube and suck some out. If you do that, don't take out more than a cup at a time before checking the level again.
Don Ford
'09 HHR 2LT or '97 Aerostar MiniVan (Remco driveshaft disconnect) for Towed vehicles
opnspaces
San Diego Ca
Posted: 10/25/19 03:05am Link  |  Quote  |  Print  |  Notify Moderator
I would go with the actual dipstick. The danger with being overfull is if it is too full the fluid can contact the rotating gearsets and foam up. If after a long drive you are above the level, but there is no foam or bubbles on the stick then I would not worry about it.
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
MountainAir05
New Mexico
Posted: 10/25/19 07:52am Link  |  Quote  |  Print  |  Notify Moderator
and Add if too full it can cause the front seal to leak. Assuming you are checking fluid with it hot in Park or what every your manual states. My newer vehicle has no stick and it is important that the correct level be in the pan.
RLS7201
Posted: 10/25/19 10:55am Link  |  Quote  |  Print  |  Notify Moderator
I curious, what is the reason the front seal would leak if too full?
Richard
95 Bounder 32H F53
460/528 stroker
Web Master
MWPSchooners.com
First brake job
1941 Hudson
MountainAir05
New Mexico
Posted: 10/25/19 12:13pm Link  |  Quote  |  Print  |  Notify Moderator
I could not tell you. On my RV V10, it blew out the front seal twice, once when I got it , had around 5000 miles and it started leaking. Ford replace it and stated that it was over filled. I had never add any fluid and it did show just a tad over the full mark. Second time just about out of warranty and again front seal. Got the same statement of over filled. After that time, when it was change I did it every 2/3 years and always fill to the mark and never had leak again. I did notice that when I change it after warranty the whine that I had went away. It seem to be coming from transmission. Was told from the local dealer that it was normal sound. I have a year 99.
I change the fluid on all my other vehicle on a 3/5 year change out. Had no issue with them.
ArchHoagland
Clovis, CA, USA
Posted: 10/29/19 07:51pm Link  |  Quote  |  Print  |  Notify Moderator
Are you checking it with the engine running?
2004 Monaco La Palma 36DBD
Workhorse W22 8.1 Gas Allison 1000, 7.1 mpg
US Gear Brakes
TC&Z
Atlanta, GA USA
Posted: 11/14/19 12:05pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, had driven 25 miles (non-highway), had shifted through all the gears and engine was running when fluid level was checked. All in accordance with the owner's manual instructions.
TC&Z
Atlanta, GA USA
Posted: 11/14/19 12:06pm Link  |  Quote  |  Print  |  Notify Moderator
