Lantley
Ellicott City, Maryland
gkainz wrote: I switch back and forth between rv.net and trailerlife portals when "the other one" begins acting up.
x2
2019 Duramax w/hips,2012 Open Range,Titan Disc Brake
H-head TPMS,BD3,RV safepower,17" Blackstone
Ox Bedsaver,RV760 w/BC20,Glow Steps
Correct Trax,Splendide
jplante4
Cape Cod
Looks like the trailer life portal has been repaired.
Jerry & Jeanne
1996 Safari Sahara 3530 - 'White Tiger'
CAT 3126/Allison 6 speed/Magnum Chassis
2014 Equinox AWD / Blue Ox
K Charles
Connecticut
Tripalot wrote: smarty wrote: I have had zero problems...
X2
It works fine here too.
azdryheat
Tucson, AZ
Not sure what the complaint is. I haven't had any issues with rv.net.
2013 Chevy 3500HD CC dually
2014 Voltage 3600 toy hauler
2011 Harley Ultra Limited
2016 RZR 900
Gdetrailer
PA
cavie wrote: I have changed to Good Sams Club Open Roads Forum. This is my 3rd and last change. If this one starts acting up I gone for good.
![rolleyes [emoticon]](http://www.rv.net/sharedcontent/cfb/images/rolleyes.gif)
You DO realize that you CAN login to ALL of the portals and STAY logged into them at all times?
This forum is rather unusual in the fact that there is more than one way into it. Most forums have only one single site and when it goes down or fails you ARE completely unable to access that forum unitl it is repaired.
This forum because of the shared branding portals actually is doing you a favor by allowing you ta work around a server, ISP, DNS or plain software glitch of the forum.
Just login to each portal, do not use the forum log out button, just back out of the forum site or close your browser.
Bookmark each portal.
When you run into an error, simply pick a different portal and try again.
Use the portal that gives you consistently the least issues.
That's it, simple, no pain, no hassle and no whining needed.
Now, be aware, staying logged into each portal requires each site to write a cookie on your PC (site cookie left on your PC is how the site knows you are logged in). IF you are one of those folks that can't stand leftover cookies and deletes all cookies each time you close the browser you will have to re-login every time..
Johnny G1
Clearwater, British Columbia ,Canada
Havent logged out in 15 yrs and no problems but went through a few pc's.
98 Mountain Aire 34' 210 Cummins Puller and 2001 dodge dully with all the toy's, 400 + hp pullin a 28' 5th wheel Travel Aire. Lots of fun.
bucky
Raleigh metro
How nice, they've removed my link and it now kicks back to the sub menu for General RVing issues.
When the rv.net portal started acting up I switched over to the Trailer life portal as suggested. Still had some issues but overall OK.
I tagged it as one of my favorites and removed the favorite for RV.net.
All of a sudden one day when I clicked on my favorite it now said it was RV.Net again instead of Trailer Life. Problems started all over again, some threads would open while others would not.
All of a sudden Wed morning this week when I clicked the favorite for RV.net up popped a login screen for Good Sam. Bright red and yellow like the KOA that isn't there yet in Moyok NC. I then typed in RV.net as though it wasn't a saved link and voila............Rv.net. It was the same way Thursday morning.
I knew that I should have done a screen shot.
My point is that this isn't rocket science and anybody that says they haven't had problems must not visit very often. It would be so easy to take all the portal links and redirect them to ONE web address.
Somebody needs to get fired, or maybe the whole IT group.
Some members ask where all the posts have gone? If you can't get on you can't very well post.
2005 Cummins 2500 2WD LB quad cab pulling a 2007 Jayco 345bhs
