RV.Net Open Roads Forum: Tech Issues: Progressive Dynamics 9180, 9180A, 9180AV
 > Progressive Dynamics 9180, 9180A, 9180AV
RLS7201
Posted: 10/25/19 11:23am Link  |  Quote  |  Print  |  Notify Moderator
I see 3 listings for the PD 9180. What is the difference between the 9180, 9180A & 9180AV.
My 9180 died. I purchased a 9180AV that is 0.40 volts short of the advertised ratings with the charge wizard attached. The output is 14 volts 13.2 & 12.8. THe batteries are good and I tried 2 different charge wizards. My solar charge controller works correctly with the batteries.
Richard
95 Bounder 32H F53
460/528 stroker
Web Master
MWPSchooners.com
First brake job
1941 Hudson
RKW
Four Corners, New Mexico
Posted: 10/25/19 01:52pm Link  |  Quote  |  Print  |  Notify Moderator
The "A" is a newer version of the PD9180. The "AV" is the latest version.
Ryan
  • 2015 Ford F250
  • 2015 Rockwood Signature Ultralite 8280 WS
  • Dual Honda EU2000i Generators
    The wages of sin are death; but after they're done taking out taxes, it's just a tired feeling.
  • wa8yxm
    Wherever I happen to park
    Posted: 10/25/19 03:27pm Link  |  Quote  |  Print  |  Notify Moderator
    Now that... is priceless.
    Home is where I park it.
    ScottG
    Bothell Wa.
    Posted: 10/25/19 04:36pm Link  |  Quote  |  Print  |  Notify Moderator
    Best giggle I've had all day!
    Scott, Grace and Wesly
    2018 Silver Fox 32A.
    H0NDA eu2000i
    ScottG
    Bothell Wa.
    Posted: 10/25/19 05:14pm Link  |  Quote  |  Print  |  Notify Moderator
    The V at the end of the P/N simply means "retail packaging" and doesn't have anything to do with it's capability or revision.
    rrupert
    NW PA
    Posted: 10/26/19 07:28am Link  |  Quote  |  Print  |  Notify Moderator
    Is there an adjustment pot that you can access? Some converters have that.
    Check with Best Converter and see what they say. Best Converter
    * This post was edited 10/26/19 10:05am by rrupert *
    Rich and Joyce
    2018 Jayco Jay Flight 21QB
    2012 Ford F150 4X4 Supercrew EcoBoost
    Reese Strait-Line Dual Cam Hitch
    Amateur Radio K3EXU
    RLS7201
    Posted: 10/26/19 10:39am Link  |  Quote  |  Print  |  Notify Moderator
    Thanks everyone, just as I suspected my new AV is bad. No advustment pot. Supplier see no problem. I have a question in a Best Converter. Looks like Randy is just going to have to sell me a new converter.
    Lets call the thread closed
    Thanks
    Richard
    Hurricaner
    Hurricane Utah
    Posted: 10/27/19 10:01am Link  |  Quote  |  Print  |  Notify Moderator
    Are you sure your meter is accurate? I was an electrical trouble shooter for years and I can't tell you how many times bad meters screwed me and most of the time they where fluke meters. Took me a long time to learn to always double check my test gear.
    Sam
    Sam & Kari
    Hurricane, Utah
    2019 Winnebago Sightseer 33C
    RLS7201
    Posted: 10/27/19 12:17pm Link  |  Quote  |  Print  |  Notify Moderator
    Sam
    Thanks for your thoughts. I had to learn to be a control circuit electrician while working in industrial maintenance. So yes I have redundant equipment. None of it is Harbor Freight lack of Quality. Actually my favorite meter is a Radio Shack branded Fluke.
    Richard
    road-runner
    Oregon
    Posted: 10/27/19 02:29pm Link  |  Quote  |  Print  |  Notify Moderator
    Blasphemy![emoticon]
    2009 Fleetwood Icon
