RV.Net Open Roads Forum: Questions about pulling a fifth-wheel with a half ton TV
 > Questions about pulling a fifth-wheel with a half ton TV
Terryallan
Foothills NC
Posted: 10/26/19 02:22pm Link  |  Quote  |  Print  |  Notify Moderator
Edd505 wrote:
Pull that with the 1/2 ton and find a buddy has a 3/4 of 1 ton and tow it. You won't want to go back to the 1/2 ton city truck.
Pull that with a 3/4 or 1 ton, and find a buddy with a F650, or MTD, you will never go back to the 3/4 ton city truck.
Terry & Shay
Coachman Apex 288BH.
2013 F150 XLT Off Road
5.0, 3.73
Lazy Campers
sayoung
Tx
Posted: 10/26/19 03:52pm Link  |  Quote  |  Print  |  Notify Moderator
MFL wrote:
Your short 5.5 bed truck may work with the right fifth wheel trailer, and a sidewinder type pinbox. I think some of the 1/2 ton towables come with this pinbox. Your sig page mentions max tow pkg on truck, which adds payload, and a bit more RAWR.
Jerry
A friend pulls a Grand Design for a 1/2t & uses a Ford with the 5 1/2 ft box. The 5er came with pinbox like this that pivots at the rv & not the pin. He has a wedge thing that bolts on the pinbox & this keeps the pin from turning.
time2roll
Posted: 10/26/19 04:24pm Link  |  Quote  |  Print  |  Notify Moderator
https://www.pullrite.com/3100_HIW
675w Solar pictures back up
wing_zealot
East of the Mississippi
Posted: 10/26/19 06:54pm Link  |  Quote  |  Print  |  Notify Moderator
theoldwizard1 wrote:
The option list for towing on the F150 is long and complicated. Maximum towing can only be achieved with the right combination. Because you have a Supercrew you need to know your LOADED vehicle weight and rear axle ratio.
Refer to page 15 of the Ford 2013 Towing Guide
complicated? All you have to say is you want the " heavy duty payload package". And while your at it, get the towing mirrors also.
keymastr
S.E. Washington
Posted: 10/27/19 09:47am Link  |  Quote  |  Print  |  Notify Moderator
You can tow a much larger, heavier travel trailer than 5th wheel. If just towing with a half ton it makes no sense to get a 5th wheel.
goducks10
There
Posted: 10/27/19 09:53am Link  |  Quote  |  Print  |  Notify Moderator
Pin weight vs Tongue weight yes.A TT will not overload a 1/2 as bad.
For me I would rather be maxed out with a 1/2 to towing a 5th wheel than be under payload while towing a bigger longer TT.
A 5th wheel is going to handle so much better. No sway to worry about.
Edd505
Elephant Butte, NM
Posted: 10/27/19 11:36am Link  |  Quote  |  Print  |  Notify Moderator
Baby trucks,
Yep my names on the side.
MTD too small
[image] [emoticon]
* This post was edited 10/27/19 11:49am by Edd505 *
2015 F350 FX4 SRW 6.7 Crew, longbed - 2017 Durango Gold 353RKT
2006 F350 SRW 6.0 crew longbed sold
2000 F250 SRW 7.3 extended longbed airbags sold
2001 Western Star 4900EX sold
Jayco Eagle 30.5BHLT sold, Layton 24.5LT sold
Terryallan
Foothills NC
Posted: 10/27/19 12:38pm Link  |  Quote  |  Print  |  Notify Moderator
I had one. only it was a Cabover, CLT 9000 double wide air ride. Back in the day weren't many Conventional trucks
* This post was edited 10/27/19 02:33pm by an administrator/moderator *
DSteiner51
Wooster, Oh
Posted: 10/27/19 01:12pm Link  |  Quote  |  Print  |  Notify Moderator
This is the kind of advice I don’t understand.
1. Hitch weight is extremely ft aft of factory Recommended CG for ANY truck, 1/2, 3/4, or a ton making it inherently unstable but load it down, hook it up then bandaid it with WDH.
2. Being it is unstable add another type bandaid, an anti sway bar although some are built into the WDH.
I would MUCH more be slightly over Trucks GVWR and have an inherently STABLE rig, not relying on bandaids which I don’t have to ‘dial it in’ to make it tow safely. Some of the travel trailer setups I’ve seen on the road are ridiculous and no way I’d tow. I love my half ton 5th wheel behind my half ton and enjoy the tow. Towing is, and should be, half the fun of going camping.
* This post was edited 10/27/19 02:35pm by an administrator/moderator *
D. Steiner
The sooner I fall behind, the more time I have to catch up.
Michelle.S
Western NY till fall, then Sebring, FL
Posted: 10/27/19 03:41pm Link  |  Quote  |  Print  |  Notify Moderator
D. Steiner, I agree. Watched some folks pull out from the CG we're at with a Cadillac Escalade EXT Pickup. Fairly large TT, no Equalizer Bars or Sway Control, rear bumper of TV almost dragging the ground and headlights pointed at the stars. Would not want to be anywhere near that on the highway.
2018 Chevy 3500HD High Country Crew Cab DRW, D/A, 2016 Redwood 39MB, Dual AC, Fireplace, Sleep #Bed, Auto Sat Dish, Stack Washer/Dryer, Auto Level Sys, Disk Brakes, Onan Gen, 17.5" "H" tires, MORryde Pin & IS, Comfort Ride, Dual Awnings, Full Body Paint
