RV.Net Open Roads Forum: Fifth-Wheels: water heater anode rod
 > water heater anode rod
Rwake901
Central, Illinois
Posted: 10/26/19 01:01pm Link  |  Quote  |  Print  |  Notify Moderator
How often should I replace the water heater anode rod and are they pretty much all the same when it comes to purchasing one? Thanks
garyp4951
TN
Posted: 10/26/19 01:05pm Link  |  Quote  |  Print  |  Notify Moderator
On my last fw I replaced mine with a plastic plug.
Lynnmor
Red Lion
Posted: 10/26/19 01:09pm Link  |  Quote  |  Print  |  Notify Moderator
It all depends on water quality and the quantity used. I replace when it is about half depleted or the wire looks weak near the fitting.
Rwake901
Central, Illinois
Posted: 10/26/19 01:34pm Link  |  Quote  |  Print  |  Notify Moderator
This is the first RV that I’ve had that has an anode rod our other campers/motorhomes just had a plug. I took the anode rod out to drain the water heater and I thought it looked pretty ate up after only one season. Is this normal?
wildtoad
Blythewood, SC
Posted: 10/26/19 01:35pm Link  |  Quote  |  Print  |  Notify Moderator
This is a good method. According to Suburban you should drain the heater when not in use, so plenty of opportunities to check it. The rods are cheap as is teflon tape around the threads, and I suppose Suburban has a good reason for using them in their water heaters.
Tom Wilds
Blythewood, SC
2015 Jeep Wrangler 2dr HT
wildtoad
Blythewood, SC
Posted: 10/26/19 01:39pm Link  |  Quote  |  Print  |  Notify Moderator
Yes. I consider replacing it just a part of annual maintenance. And this is my first MH with a Suburban heater. All the others were Atwood. This will also be my last MH with a Suburban.
cavie
Posted: 10/26/19 01:40pm Link  |  Quote  |  Print  |  Notify Moderator
If you have a suburban WH you MUST have an anode rod. If not your tank will destroy it'self. Anode rod is sacrificial. you wanna spend $15 or $300.00
cavie
Posted: 10/26/19 01:41pm Link  |  Quote  |  Print  |  Notify Moderator
Weak at the fitting is not a problem. When it all looks a think as a pencil it's time to change.
cavie
Posted: 10/26/19 01:44pm Link  |  Quote  |  Print  |  Notify Moderator
Yes. Change if the rod looks like a pencil. Atwood is SS and needs no rod. Suburban is glass line steel and need an anode rod.
cavie
Posted: 10/26/19 01:46pm Link  |  Quote  |  Print  |  Notify Moderator
Atwood is aluminium. needs no rod. Suburban is glass lined steal and must have a rod.You must drain the water in the winter to prevent freezing and breaking the tank.
* This post was edited 10/27/19 03:48am by cavie *
