RV.Net Open Roads Forum: Fifth-Wheels: water heater anode rod
 > water heater anode rod
Chris Bryant
Arden, North Carolina
Posted: 10/26/19 02:32pm Link  |  Quote  |  Print  |  Notify Moderator
-- Chris Bryant
wildtoad
Blythewood, SC
Posted: 10/26/19 03:16pm Link  |  Quote  |  Print  |  Notify Moderator
True enough. I have no issue with needing to drain it from time to time, and down here in SC getting a frozen wh is the least of my concerns. What I don’t like most is, this is the first wh I’ve owned that will spew water out of the relief valve. Yeah Yeah, I’ve tried all of the published remedies, and from time to time I’ll go a few heat cycles without it dripping. The manual says it is normal for an RV wh to drip when the air pocket is lost. My take is if they know what causes it, then they can design a solution. They just choose not to. End of rant....
cavie wrote:
wildtoad wrote:
Lynnmor wrote:
It all depends on water quality and the quantity used. I replace when it is about half depleted or the wire looks weak near the fitting.
This is a good method. According to Suburban you should drain the heater when not in use, so plenty of opportunities to check it. The rods are cheap as is teflon tape around the threads, and I suppose Suburban has a good reason for using them in their water heaters.
Atwood is SS. needs no rod. Suburban is glass lined steal and must have a rod.You must drain the water in the winter to prevent freezing and breaking the tank.
Tom Wilds
Blythewood, SC
2015 Jeep Wrangler 2dr HT
fj12ryder
Platte City, MO
Posted: 10/26/19 03:22pm Link  |  Quote  |  Print  |  Notify Moderator
I went to the magnesium anode rod because the aluminum left lots of the aluminum oxide gel in the bottom of the tank. Since I've gone to magnesium I don't have that issue.
Howard and Peggy
"Don't Panic"
MFL
Midwest
Posted: 10/26/19 03:33pm Link  |  Quote  |  Print  |  Notify Moderator
Magnesium is recommended as a first choice. If poor water quality causes the mag anode to deteriorate quickly (less than a year) then you can use the aluminum version. However the aluminum does not give as good of protection for your tank, due to it not being as sacrificial.
Jerry
Lynnmor
Red Lion
Posted: 10/26/19 04:13pm Link  |  Quote  |  Print  |  Notify Moderator
cavie wrote:
Weak at the fitting is not a problem. When it all looks a think as a pencil it's time to change.
The electrolysis action is more aggressive next to the fitting consuming the anode and, to some degree, the supporting core. Look at the illustration posted above and you will see what I mean. If you want to bounce down the road with an anode that is heavy outboard from the mounting point, fine. I just don't want to fish a broken part out the drain hole.
I wonder how often home owners change the anodes in their house water heater. Due to lack of sales, many big box stores quit stocking them and only offer a limited selection online. I think that few have a clue about the need for that maintenance. I need to replace those about every three years.
ScottG
Bothell Wa.
Posted: 10/26/19 05:19pm Link  |  Quote  |  Print  |  Notify Moderator
Atwood water heaters used to be aluminum, not SS.
Are they indeed SS now?
Scott, Grace and Wesly
2018 Silver Fox 32A.
H0NDA eu2000i
Old-Biscuit
Verde Valley
Posted: 10/26/19 05:58pm Link  |  Quote  |  Print  |  Notify Moderator
NO.....
Atwood WH Tanks were and still are ALUMINUM tanks with a zinc cladding
NO Stainless Steel used.
Suburban uses regular old carbon steel hence the need for the glass-lining AND anode rod
Just like the residential WH Tanks
Rarely does any one change the anode rod in residential WHs
Many don't know about them
Many forget/don't care
Besides......get a new one before warranty expires (5, 10, 12 years etc)
cavie
Posted: 10/27/19 03:51am Link  |  Quote  |  Print  |  Notify Moderator
Nope. MY bad, don't know why I said that I know better.
cavie
Posted: 10/27/19 03:54am Link  |  Quote  |  Print  |  Notify Moderator
NO.....
My bad. Don't know why I typed that. I know better.
Chris Bryant
Posted: 10/27/19 05:23am Link  |  Quote  |  Print  |  Notify Moderator
There is a fix for that- simply remove the upper dip tube from the outlet, this gives a much larger air cushion, at the expense of about a half gallon of capacity. Alternatively, you can remove and shorten the dip tube and reinstall.
