RV.Net Open Roads Forum: Yes boys and girls, you REALLY need to carry a spare...
 > Yes boys and girls, you REALLY need to carry a spare...
Page of 10
DutchmenSport
Indiana
Posted: 10/27/19 06:11am Link  |  Quote  |  Print  |  Notify Moderator
Good advise. Happened to us also last March. I had a spare, but I did not have the jacks, but Roadside Assistance did. I ended up getting 4 new tires once we reached our destination (Indianapolis to Charlotte NC). We purchased the trailer new only 6 months earlier.
ron.dittmer
North-East Illinois
Posted: 10/27/19 06:22am Link  |  Quote  |  Print  |  Notify Moderator
js218 wrote:
I carry 1 drive, 1 steer for my rig
Hmmm.... drive and steer use the same wheel and tire. One standard steel wheel spare covers both, even if you have alloys. What chassis model and year do you have?
The Toyota chassis from the 70's through to 1986 was the only chassis that had different front and rear wheels. I know because I owned one for 24 years. The DRW axle came years later through a recall, introducing the difference from the front wheels.
2007 Phoenix Cruiser model 2350, with 2006 Jeep Liberty in-tow
jjrbus
FT Myers FL
Posted: 10/27/19 06:35am Link  |  Quote  |  Print  |  Notify Moderator
RV'ers seem to be mislead on proper tire inflation pressure. I have been accused of trying to act like an expert on this. I have found a video by Michlen tires that explains how to weight the rig and use a load and inflation table for PROPER inflation of the rigs tires. So it is no longer my experience and opinion, it is by Michlen who may just be experts on tires.
I do not much care what Randy the RV guru said, I will listen to Michlen. They also have a couple good videos on RV blowouts.
https://www.youtube.com/watch?v=Wb7W-nRAPrk&t=471s
Disclaimer, I do not know if anyone here is named Randy and if so it was not directed towards you, only meant as a pun.
js218
on the road
Posted: 10/27/19 07:07am Link  |  Quote  |  Print  |  Notify Moderator
Chassis is a Volvo tandem drive axels class 8,drive and steer are 2 different tires
2017 Haulmark 45' Super C 600hp, 12 speed I shift transmission, tandem drive axles, 3 stage engine brake, towing 26' trailer with an 08 explorer inside.
Jim
js218
on the road
Posted: 10/27/19 07:28am Link  |  Quote  |  Print  |  Notify Moderator
8 XDN2 all season drive tires, 2 X Line Energy steer tires all Michelins 11R 24.5 Load Range H.
Desert Captain
Tucson
Posted: 10/27/19 07:51am Link  |  Quote  |  Print  |  Notify Moderator
twodownzero wrote:
Glad you got it fixed safely. I don't know what your individual corner weights are, but that doesn't sound like enough air pressure.
I always inflate {and adjust} for the load I will be running as it can vary by almost a thousand pounds depending on whether or not {and what} we are towing/loading. We often run at or very near our max GVWR of 11,500# {I have a 2011 E-350 chassis - the coach is a 2012}. I have 3,800# on the front axle and 7,700# on the rear. Per the Michelin load/psi tables I run at 65 psi front and 75 rear adding in a 10 percent fudge/safety factor. The ride and handling are awesome. I am running HD Bilsteins and tow with my air bags at 50 psi with excellent results.
Running the fronts on most 25' or less Class C's at 80 psi per the door stickers {which are a bad joke}, will reduce the contact patch to the point that it will handle like a pig on skates and be blown all over the road by passing trucks and/or cross winds. Putting 80 in the rears would be serious overkill las at 80 they are rated for 2,640# of load X 4 = 10,560# to carry a 7,700# load. This also creates a very stiff ride that will beat you to death and shorten tire life.
[emoticon]
ppine
Northern Nevada
Posted: 10/27/19 09:23am Link  |  Quote  |  Print  |  Notify Moderator
Miners, chukkar hunters and people driving to Alaska usually carry two spares.
I have had three flats in one day or two different occasions. Sharp basalt is the worst.
LOG
Austin, TX
Posted: 10/27/19 10:05am Link  |  Quote  |  Print  |  Notify Moderator
[emoticon]
Most Michelin tires for a 25' or less Class C would have a load rating of 2,470# in a dual wheel configuration. Please provide the tire size.
LOG
2005 Chinook Glacier
bobndot
Posted: 10/27/19 10:36am Link  |  Quote  |  Print  |  Notify Moderator
Desert Captain, thanks for taking the time to share your story and posting the pics.
When we were class 'c' shopping last year, a spare tire as OEM equipment was a must. We too use CN road service and have been happy the 2x we had to use it.
The way you handled the roadside safety was textbook professional.
I'm glad you are both safe and that's the real bottom line. [emoticon]
ernie1
Sacramento,California,USA
Posted: 10/27/19 12:25pm Link  |  Quote  |  Print  |  Notify Moderator
My rv did not come with a spare and I made sure that I got one along with a carrier at the rear. Friends with a similar rv snickered at the thought of me having a spare tire and having to change it myself. Well I'm 76 years of age and haven't figured out that I'm supposed to be old and feeble yet. When I have to change tires I just deploy the BigFoot jacks and wrestle the tires off and on. Not a problem!
Page of 10
