RV.Net Open Roads Forum: Tow Vehicles: Remanufactured parts rant.....
Search only in Tow Vehicles
 > Remanufactured parts rant.....
Page of 6
Posted: 10/27/19 09:26am Link  |  Quote  |  Print  |  Notify Moderator
First off, I admit knowing better, but sometimes you gotta do what you gotta do.
So yesterday, the alternator on our newly purchased old 2001 Chevy Tahoe starts taking a dump on a roadtrip up to BC. Always fun at 6am when your kid has a hockey game at 9!
It was the voltage regulator taking a dump and it would switch to not charging, then tap on it a bit and she’d work again for a while. Made it to the first game on time though so that’s good.
I go to get a new alternator in the afternoon and figure, not messing with swapping just the voltage reg out on a parking lot repair and chancing that I’m wrong in my diagnosis.
Thing was 19 years old anyway....
I go to Napa rather than Lordco or Princess Auto and spend the extra money in hopes of a quality part. Technically I know better and have seen the same quality (bad) reman stuff from Napa as well.
Well after spending almost $100 more from Napa than the discount joints on an alternator (and passing a private starter and alternator shop about 1/2 mile past the Napa, lol.) I’m reading the box it came in while returning the core.
It says new brushes and bearings, great. Then it says 100% fully tested voltage regulator and rectifier! Seriously?
The only reason I got a new one was for the d@mn new regulator. And now I have another 15+ year old $300 voltage regulator with a warranty?
Piece of shat, cheap azz, low buck, high dollar reman.
Heck, I gave them back a perfectly good alternator. I should have kept the core, tossed a new regulator in it next week and returned the “100% fully tested” one I bought!
They must expect people to do that if they put $30 worth of bearings and brushes in an old alt, clean it up and put it in a new box......and sell it “good as new.”
ShinerBock
SATX
Posted: 10/27/19 09:44am Link  |  Quote  |  Print  |  Notify Moderator
Yeah, not all remans are the same. It depends on their tier. For example, we carry Bosch starters and alternators in many of our locations, but branded under our own label. There are different tiers of products that Bosch offered us in our private label line from a very good quality that very closely meets production specs to lower quality products that did not replace everything and/or did not use as good of parts were used. Being that our private label is our "value" line meant to target price sensitive customers, we opted for a tier closer to the bottom.
We do have a premium private label line that uses tier 1 product meaning that it comes from the same factory and quality that the OE gets it from. It is the exact same part that you would get from the OE for considerably less which tells you how much of a markup the OE puts on these parts.
There is also a difference between a "production" spec part and an "aftermarket" spec part for many parts manufacturers. A production spec'ed part is what is sold to the vehicle manufacturer and an aftermarket spec'ed part is what is sold to the public. Generally, production parts have to meet more stringent quality standards(tighter bell curve) than aftermarket parts even if it is an OE part. This is why the stock OE parts on your vehicle will usually last longer than the very same OE replacement parts.
ScottG
Bothell Wa.
Posted: 10/27/19 10:07am Link  |  Quote  |  Print  |  Notify Moderator
Sadly have to agree. Napa used to be the professional place to go. Parts might cost more but they were the gold standard. Now they're junk like everyone else and the stores are often a mess and poorly stocked.
I guess it's what they had to do to compete with the other cheapo parts stores.
Scott, Grace and Wesly
2018 Silver Fox 32A.
H0NDA eu2000i
blofgren
Surrey, B.C.
Posted: 10/27/19 10:17am Link  |  Quote  |  Print  |  Notify Moderator
I’ve had failures of reman Napa alternators too. I put a new (not reman) Bosch alternator in my wife’s 2005 Acura MDX almost 3 years ago and so far so good. I bought it from Lordco and the guy at the counter said they rarely see those come back but not so for the reman units. I paid about $100 more for it but I really don’t want to change it again.
I think my 2001 GMC Yukon is on the original alternator at 265k kms though........[emoticon]
2013 Ram 3500 Megacab DRW Laramie 4x4, 6.7L Cummins, G56, 3.73, Maximum Steel, black lthr, RAM 20k sliding hitch, Retrax, Linex, and a bunch of options incl. cargo camera
time2roll
Posted: 10/27/19 10:26am Link  |  Quote  |  Print  |  Notify Moderator
Couple years ago alternator in my 2001 Ford gave up 1500 miles from home. Picked up a NEW one at O'Reilly's in Gillette WY with a lifetime warranty. Working fine so far. You can bet they will get it back if I have issues.
675w Solar pictures back up
carringb
Corvallis, OR
Posted: 10/27/19 10:34am Link  |  Quote  |  Print  |  Notify Moderator
Same here. When I was running the shop, I had a ton of remand starter and alternator failures. Remans are fine for getting back on the road, but for my personal cars I just buy new OEM-grade parts. Worst one was the AC compressor on the van. Original got oil started from a tiny pinhole leak where a loose line rubbed the firewall. Went through a couple of remans before finally putting in a new Denso compressor. It's a big jump in price, but since you have to replace the filter/drier each time, the reman gets more expensive fast.
Bryan
2014 ORV really big trailer
2015 Ford Focus ST
ShinerBock
SATX
Posted: 10/27/19 10:40am Link  |  Quote  |  Print  |  Notify Moderator
Here is a another rant of some sorts about another reman part.
Years ago when I was a area sales rep, I was on location at one of my customers that needed a water pump on his Cummins powered 3500 at his shop over an hour away from my dealership. My company is a Cummins distributor and offer Cummins engines in the medium/heavy duty trucks we sell. I had the genuine Cummins pump in stock at my dealership, but it would have to wait for the following day to be delivered. My dealerships cost was around $40 for the pump and we sold it for around $60.
My customer needed it ASAP so I decided to call a local light duty Dodge dealership to see if they had the part. I gave the parts man the Cummins part number based on engine serial number and he crossed it to the Mopar part number. I almost spit out my coffee when he told me it was almost $200. Since this dealership was about 5 minutes away from where I was, I decided to take a look at this $200 water pump. I got there and it was in the same Cummins box with the same Cummins part number that I had on my shelf for $60, but with the Mopar part number sticker over it for $200.
I told him that my dealership can get this pump for around $40 and I assumed that they had to pay more through Mopar which us why they sold it for a much higher cost. Nope, the only got it for about $55. Of course my customer decided to wait for mine to be delivered after telling how much it would cost if I got it from the Dodge dealer.
I was a bit curious and decided to call another Dodge dealer to see if it was just this dealership that was trying to screw people. Nope, another Dodge dealer in the city quoted a slightly higher price than the other small town dealership did for the same exact part.
Posted: 10/27/19 10:48am Link  |  Quote  |  Print  |  Notify Moderator
^Rofl Shiner. Dodge dealer wanted $360 for a 5.9 water pump when I changed mine.
Told the guy I didn’t want it changed and a coolant flush too....He assured me the only labor I was paying for was for him to get off the stool and go get the part!
I know it’s marketing like anything else, for car parts, but I start recalling the movie Tommy Boy every time I have to buy an auto part!
Posted: 10/27/19 10:50am Link  |  Quote  |  Print  |  Notify Moderator
Blofgren, I’m at about 170k clicks. Voltage regulators are cheap and fairly easy to replace. Seem like a common failure point in my recent interwebs searches dealing with this yesterday. Also seen a bunch of accounts of the vr spiking and killing other electrical systems.
Posted: 10/27/19 10:52am Link  |  Quote  |  Print  |  Notify Moderator
Showing my age here, but nowadays, the parts store have to compete with amazon type services and prices. So result? Down goes quality and price to compensate.
Page of 6
