RV.Net Open Roads Forum: Class C Motorhomes: Running generator on a hill
 > Running generator on a hill
camperdave
northern, California
Posted: 10/27/19 09:41am Link  |  Quote  |  Print  |  Notify Moderator
I need to run my generator for a few days and am parked on a hill (using as backup power for our house). Should I be nose up or nose down to maximize the amount of fuel I can pull from the tank with the pickup?
It's a 2004 Ford e450 with 55 gallon tank.
2004 Fleetwood Tioga 29v
pianotuna
Regina, SK, Canada
Posted: 10/27/19 10:35am Link  |  Quote  |  Print  |  Notify Moderator
Seeing as the oil may be a "splash" system I'd want to be level.
Regards, Don
bobndot
Posted: 10/27/19 10:53am Link  |  Quote  |  Print  |  Notify Moderator
At least eyeball level.
I really don't know the 100% answer but I would agree with being as close to level as possible, especially long term running. I guess its also possible to run out of gas sooner if the rv gas tank is off level.
Morro Bay, CA
Posted: 10/27/19 11:14am Link  |  Quote  |  Print  |  Notify Moderator
Isn’t this a question about removing fuel from a Ford on unlevel ground?
ItsyRV
Desert SW
Posted: 10/27/19 12:06pm Link  |  Quote  |  Print  |  Notify Moderator
Where is the pickup located in the tank? If it's towards the front, nose up would further reduce the level at the pickup resulting in premature sucking of air. So, you need to know where the pickup is coming from and use that as you guide. But as others mentioned, how will the angle effect your oil?
1994 Itasca SunDancer 21RB - Chevy G-30 chassis.
DrewE
Vermont
Posted: 10/27/19 12:14pm Link  |  Quote  |  Print  |  Notify Moderator
It depens where the pickup is in the tank, and that I don't know offhand. I would guess it's probably reasonably close to being centered in the tank, so it shouldn't make a whole lot of difference nose up vs. nose down; in any case, 40+/- gallons is a good bit and should mean a few days of continuous runtime before needing to get more fuel.
Being not too extremely out of level is a very good idea for the generator's happiness. It's not at all necessary to be super precise, breaking out the plumb bob and machinist's level, but if it feels unnatural to walk around in the RV it might be wise to get it somewhat closer to level.
suprz
rhode island
Posted: 10/27/19 02:40pm Link  |  Quote  |  Print  |  Notify Moderator
Maybe google your vehicles tank?
Proud father of a US Marine
VA-Apraisr
glen allen, VA
Posted: 10/27/19 03:12pm Link  |  Quote  |  Print  |  Notify Moderator
I've got the same year unit and pickup is top center on the rear tank. As mentioned, reasonably level for comfort as well as proper oil circulation within the generator. Gas will get to the unit in either case unless you're talking about a serious downhill/uphill location. Use your leveling blocks and/or improvise some boards to keep it semi-level just to avoid a costly mistake. I park on farms and beaches and always try to get it as level as possible since I run the generator all night when needed.
Home Skillet
Pearland Texas
Posted: 10/27/19 05:16pm Link  |  Quote  |  Print  |  Notify Moderator
The generator fuel pick up is about 3" off the bottom of the tank.
It is oriented towards the front.
2005 Gulf Stream Conquest 31ft
BigFoot Levelers,TST in tire TPMS,Bilstein Shocks,Trans temp guage,Lowrace iWAY
camperdave
Posted: 10/27/19 05:31pm Link  |  Quote  |  Print  |  Notify Moderator
I'm unlevel enough that I would not run the fridge. I cannot find any reference from Onan regarding a max amount of unlevel. I'm nose down at the moment, running fine so far. (20 hours and rising).
