RV.Net Open Roads Forum: Class C Motorhomes: Running generator on a hill
 > Running generator on a hill
camperdave
northern, California
Posted: 10/27/19 05:32pm Link  |  Quote  |  Print  |  Notify Moderator
Home Skillet wrote:
The generator fuel pick up is about 3" off the bottom of the tank.
It is oriented towards the front.
Cool, thanks! So I guessed right with nose down lol.
BruceMc
Oregon - Willamette Valley
Posted: 10/31/19 02:41pm Link  |  Quote  |  Print  |  Notify Moderator
"It's a 2004 Ford e450 with 55 gallon tank"
On our 1999 E350 (2000 Four Winds), which has the same fuel system as a 450 (I'd suspect), the pickup is pretty much centered in the tank:
Maybe slightly forward:
These images are from my fuel pump replacement project in January 2013:
E350 Fuel pump replacement
'16 Forest River Sunseeker 2250SLEC Chevrolet 6.0L
Previously:
'00 Four Winds 26Q Class C (Ford E350 V10)
'96 Kit Sportsmaster 212f Fifth Wheel/'93 GMC Sierra K2500
'91 SunLite poptop truck camper
and the first: a Wildernest flip-top canopy.
BruceMc
Posted: 10/31/19 02:53pm Link  |  Quote  |  Print  |  Notify Moderator
Oh, and one more point: You cannot pull fuel from the generator pickup once the tank is at 1/4. Note the shorter pipe on the left side of the pump/sender assembly:
And a side comment: to those folks who argue about keeping a full tank in winter to keep the tank from rusting, I learned two things when I undertook this project:
1) The tank and associated bits are all stainless - there's nothing to rust.
2) A full tank is about 4ish inches below the top of the tank due to the design of the fill tube. The tank must have head space for expansion.
Dusty R
Charlotte Michigan 48813
Posted: 11/01/19 11:30am Link  |  Quote  |  Print  |  Notify Moderator
I talked to a guy once that had to replace the fuel pump that's in the tank. Their bed was right above the tank, so he used a large enough hole saw and drilled threw the mh floor and replaced the pump without removing the tank.
Dusty
way2roll
Wilmington NC
Posted: 11/01/19 01:33pm Link  |  Quote  |  Print  |  Notify Moderator
Side note - is that a BX1850? If so I had the same tractor. Loved that thing!
BruceMc
Posted: 11/01/19 02:20pm Link  |  Quote  |  Print  |  Notify Moderator
Correct! We've enjoyed every minute of ownership too.
It no longer looks this pretty:
but it still works as well today as it did then.
