RV.Net Open Roads Forum: Beginning RVing: manual
 > manual
bpyaroslaw
Saskatchewan
Posted: 10/27/19 02:46pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 1979 dodge ram 200 360 Class B motor home. My electrical lights for inside of camper have shorted and thus have no dome lights. Connections come from the reserve battery.Tec says they would need to remove all interior wiring to fine the problem, and costly, so need a manual. Or where can I get one?
Lynnmor
Red Lion
Posted: 10/27/19 03:42pm Link  |  Quote  |  Print  |  Notify Moderator
I doubt that you will find a manual, what I do think you need is a technician that doesn't want to gut the wiring and will only fix the problem.
enblethen
Moses Lake, WA
Posted: 10/27/19 03:59pm Link  |  Quote  |  Print  |  Notify Moderator
Going to be hard to find the manual.
I would remove all the light bulbs from the fixtures. I am guessing that one of the lamps is the incorrect configuration for the socket. Look inside the socket to see how many small "dipples" there are. The lamps have to match that configuration.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Mojave, Kern County, California
Posted: 10/27/19 05:17pm Link  |  Quote  |  Print  |  Notify Moderator
Bad news...I don’t think you will locate a manual. FORTY years old.
BarabooBob
Baraboo, WI
Posted: 10/27/19 06:11pm Link  |  Quote  |  Print  |  Notify Moderator
Even if you do find a manual, you will find that it isn't worth the paper it is printed on. You will probably not find a schematic.
Bob & Dawn Married 32 years
2017 Viking 17RD
2011 Ford F150 3.5L Ecoboost 420 lb/ft
Retired
Admin
Channel Islands Harbor, Ca.
Administrator
Posted: 10/27/19 08:25pm Link  |  Quote  |  Print  |  Notify Moderator
Clicky
Not sure if this works for you??
Admin
RV.net
bikendan
Camano Island, Wash.
Posted: 10/28/19 02:33am Link  |  Quote  |  Print  |  Notify Moderator
how is anyone going to help with a manual for the camper part, if you don't even post what brand and model of motorhome?
all you've given is the year and make of chassis and engine.
Dan- Firefighter, Retired">, Shawn- Musician/Entrepreneur">, Zoe- Faithful Golden Retriever(RIP">), 2014 Ford F150 3.5 EcoboostMax Tow pkg, 2016 PrimeTime TracerAIR 255 w/4pt Equalizer and 5 Mtn. bikes and 2 Road bikes
Matt_Colie
Southeast Michigan
Posted: 10/28/19 02:09pm Link  |  Quote  |  Print  |  Notify Moderator
BP,
As a Class B is basically a camper built inside a van shell, the dome lights may OR may not be OE. That much is just a crapshoot. If you can get that manual, it may indicate where the wiring is/was supposed to run. Don't count on it.
If it is shorted, it is blowing fuses. If this is true, I suggest that you connect test leads to a light bulb and watch it as you take apart every bit of the system you can fine. When that light goes out, you located the problem.
I had an issue like this that an owner asked me to look at. The above method was no help at all. So, I got out a wire tracker that puts a signal on the wire and you follow it with a hand held receiver. First I tracked from the power end and put a piece of tape where I lost the signal. Then the same from the nearest fixure....
Between those two was a hook that someone had screwed in. When it was removed, so was the short. They had nailed the wire.
Matt
Matt & Mary Colie
A sailor, his bride and their black dogs going to see some dry places that have Geocaches in a coach made the year we married.
ksg5000
Oregon
Posted: 10/29/19 09:02am Link  |  Quote  |  Print  |  Notify Moderator
Matt_Colie wrote:
BP,
Matt
x2. The old Dodge Van's had pretty simple electrical setup. My tenant had 79 Dodge Camper Van and I think the only electrical stuff was a couple of overhead lights and maybe a battery isolator in the engine compartment.
Kevin
Posted: 10/31/19 02:44pm Link  |  Quote  |  Print  |  Notify Moderator
Bummer dude, but a camper almost as old as I am, I wouldn't know where to find a manual. However, you can find basic 12V electrical schematics and put 2+2 together to apply to your situation.
Get a multimeter and some extra wire, couple alligator clips maybe and start tracing the problem. Lights are either daisy chained from the same switch or from separate switches.
Start at the fuse panel find the light circuit(s). CHeck fuse, check power to the circuit. Go to switch, check power in and out of switch.Go to first light, check same. Find bad leg, check continuity to see which wire.
A manual won't help you out anyway except maybe to identify which fuse is for the lights if that's not marked.
This is basic 12V electrical troubleshooting.
You can do it with some research. And the tech is an idiot. Fishing wires through RV walls is already tricky. Certainly don't want to do more of that than necessary. Plus you'd never know where the problem is, if you havent done the troubleshooting first.
Could be a connection, switch, blown fuse, loose ground, bad light bulb receptacle and not necessarily the wire.
Good luck man!
 > manual
