RV.Net Open Roads Forum: Class A Motorhomes: Class A. Wheel size
 > Class A. Wheel size
azdryheat
Tucson, AZ
Posted: 10/28/19 08:52pm Link  |  Quote  |  Print  |  Notify Moderator
I like the feel and handling of the 22.5 tire
2013 Chevy 3500HD CC dually
2014 Voltage 3600 toy hauler
2011 Harley Ultra Limited
2016 RZR 900
GeeWillakers
Wet Coast
Posted: 10/28/19 11:35pm Link  |  Quote  |  Print  |  Notify Moderator
We have a 2007 32’ with 22.5s. I think my neighbours’ 30 and 31 foot Newmar’s do too.
2007 Triple-E Commander A3202fB W22 8.1 6spd Banks Power
2014 Jeep Wrangler JK toad, a Boston and a Frenchie
crawford
Dandridge Tenn.
Posted: 10/29/19 03:26pm Link  |  Quote  |  Print  |  Notify Moderator
wrong post sorry
* This post was edited 10/29/19 03:33pm by crawford *
Change from a c class to a A class Georgetown 07 triple slide
crawford
Dandridge Tenn.
Posted: 10/29/19 03:31pm Link  |  Quote  |  Print  |  Notify Moderator
grldst wrote:
Some of the larger 19.5's will carry as much or more weight then a smaller 22.5. I have driven Class A's with both sizes, and the difference in ride in my opinion was insignificant.
Please explain I have never seen a tractor trailer with a 19.5 in rim all I ever seen was 22.5 with heavy load. Rv were the only thing I ever thing Ive seen have this weird size tire rim.
Big Katuna
Deland, FL
Posted: 10/29/19 03:44pm Link  |  Quote  |  Print  |  Notify Moderator
The 90’s F53s had 16”. My Honda toad had 17”.
My Kharma ran over my Dogma.
timmac
Las Vegas
Posted: 10/29/19 10:42pm Link  |  Quote  |  Print  |  Notify Moderator
seedhay wrote:
I don’t know if this is the place for this question. I am a year away from upgrading from class C Ford 29 ft to 31 to 35 foot class A. The new Ford A chassis should be out by then with the bigger engine and 10 speed trans. My first question is the bigger engine going to be a V 10? Second is opinion from current owners that have had both 19.5 and 22.5 tires. I am excavating contractor and have always gone with biggest wheels possible. Problem I have is most 32 footers are 19.5 rubber ( but is my preferred size for coach. Or the 35’s with the 22.5
Thanks in advance for you opinions
Seedhay
I have 19.5 tires on a 33 foot motorhome with 2 slide outs and never a issue with the tires, as to weight carrying also no issue, my 6 tires carry more weight than the 20,500 lb chassis does.
Also a plus for 19.5 is you can carry a full mounted spare and they cost less..
Wherever I happen to park
Posted: 10/30/19 06:02am Link  |  Quote  |  Print  |  Notify Moderator
If you are buying a new RV.. well then there is this tool you have that can get you most anything you want (Provided it is possible) including 22.5" tires.
It's called your rear end...... Exiting the door... while the bottom line looks like this: Buyer's Signature: ____________________
(notice that it's blank)
If it means getting a signature on that line.. They will find a way to give you 22.5's.. For to a salesman there is one and only one problem.. that blank line.
Home is where I park it.
grldst
Dallas, GA
Posted: 10/30/19 08:05am Link  |  Quote  |  Print  |  Notify Moderator
A 285x70Rx19.5 has a load rating of 6610 lbs
A 10Rx 22.5 has a load rating of 5675 lbs
I am not trying to say a 19.5 will or can carry more weight then a 22.5 tire. I am stating that on many gas chassis the option of going with a 22.5 or 19.5 tire does not have anything to do with weight carrying capacity. A 19.5 tire can safely carry the weight.
scbwr
North Ridgeville, OH
Posted: 10/31/19 05:58am Link  |  Quote  |  Print  |  Notify Moderator
My preference would be to buy a slightly used motor home, so I wouldn't waiting to buy the new Ford model. I ended up buying a used one with the 19" tires and haven't had a problem and it works well for our traveling i.e. we're not full timers. I can see trying to get one with the 22" tires if possible, but I'd be more concerned about floor plan, quality, and cargo capacity if looking for a used unit. If buying new, I'd go for the 22" tire as long as the cargo capacity was is adequate, based upon the reputation for better ride quality with the larger tire.
2012 Newmar Bay Star 3302
Blue Ox Avail
BrakeBuddy Advantage
2015 Malibu
"Get busy living, or get busy dying."
Andy Dufresne, The Shawshank Redemption
timmac
Las Vegas
Posted: 11/01/19 11:10am Link  |  Quote  |  Print  |  Notify Moderator
X2
