RV.Net Open Roads Forum: Travel Trailers: Pig tail propane tank connector hoses.
 > Pig tail propane tank connector hoses.
time2roll
Posted: 10/30/19 10:36am Link  |  Quote  |  Print  |  Notify Moderator
smarty wrote:
Does anyone make these with a metal twist on connector versus plastic?
I have had issues with these plastic fittings when the temps are very cold, even to the point where one cracked in half
I think the plastic is designed to melt and disconnect during a fire. The internal valve on the cylinder would then shut off the flow of propane.
675w Solar pictures back up
smarty
new mexico
Posted: 10/30/19 10:38am Link  |  Quote  |  Print  |  Notify Moderator
Makes perfect sense, thanks!
PaulJ2
Northwest Oregon
Posted: 10/30/19 05:34pm Link  |  Quote  |  Print  |  Notify Moderator
rhagfo wrote:
Take your old ones to your local Propane DEALER with a service department, and have them make you replacements. I have found that the hose they use is higher quality hose that remains flexible with age. The store bought ones seem to get stiff within a year. Cost is about the same as store bought.
Bingo!! I found a local dealer here in town that made up a new set while i waited.
Much better, no swivel joints at all. $10 per hose.
Thanks all.
Rover_Bill
NE. Ohio
Posted: 10/30/19 11:54pm Link  |  Quote  |  Print  |  Notify Moderator
PaulJ2 wrote:
...Both were leaking at the connections where the hoses thread into the regulator...
You may want to try a PTFE thread seal tape specifically formulated for propane something like THIS.
2015 GMC Canyon 3.6L V6 4X4 TowHaul SLE ExtCab Bronze
2016 Keystone Passport GT 2670BH
ReCurve R6 hitch, DirecLink brake controller
2005 Suzuki C50 2006 Suzuki S40
PaulJ2
Northwest Oregon
Posted: 10/31/19 01:19am Link  |  Quote  |  Print  |  Notify Moderator
They were leaking at a swivel joint near the threads but not at the threads themselves. The new ones were wrapped with the yellow tape on the threads when he handed them to me. So he did everything right i guess.
time2roll
Posted: 10/31/19 09:20am Link  |  Quote  |  Print  |  Notify Moderator
Only pipe threads should have tape or dope. No tape on inverted flare, o-ring or other compression seal.
richclover
WY
Posted: 10/31/19 05:15pm Link  |  Quote  |  Print  |  Notify Moderator
+1. !
Rich
2018 Ram 4X4 2500HD Cummins
2020 Chaparral 336TSIK
2019 RAM 1500 Classic 4X4 Hemi
2019 CanAm Maverick Sport 1000
SW WY
trailer_newbe
Tucson
Posted: 10/31/19 08:44pm Link  |  Quote  |  Print  |  Notify Moderator
They leak at the crimp joint where it transitions to the threads. Some designs are better than others, but if they seem to swivel easily, they will be leakers right out of the box.
2018 Jayco White Hawk 28RL
