RV.Net Open Roads Forum: Tech Issues: Suburban Hot Water Heater Issue.
 > Suburban Hot Water Heater Issue.
Sgeorge
El Cajon, Calif
Posted: 10/30/19 10:15am Link  |  Quote  |  Print  |  Notify Moderator
So my Suburban hot water heater has malfunctioned after 7 years of faithful service. It will ignite, but the flame is completely yellow and is producing lots of soot. There is no blue flame like it usually has. I have taken the tube off that comes from the regulator/control thing and checked for the spider web obstruction that many have had and it is clean. It acts as if there is not enough gas pressure to burn correctly. My furnace and stove are working fine so I don’t think it is the main LPG regulator. I am very handy and do almost all my RV repairs. Any thoughts on what might be the main culprit. I should be able to fix this myself, but the DW is concerned because it is propane related. They don't seem very complicated.
2013 Springdale 232SRT
2016 F250 XLT, 6.2, 4.30.
RobWNY
Jamestown, NY
Posted: 10/30/19 10:38am Link  |  Quote  |  Print  |  Notify Moderator
It's one of two possible issues. You either have components that have gone bad or it's an adjustment that needs to be made. Here is a link to a video that shows how to adjust the air intake when you get too much yellow flame. Adjustment Video
If God didn't want us to eat cows, he wouldn't have made them out of Steak and Cheese.
Life is a lot like a baseball pitch. Sometimes you get a fast ball down the middle of the plate and sometimes you get a curve ball in the dirt.
Old timer Dave
Quesnel, BC
Posted: 10/30/19 11:14am Link  |  Quote  |  Print  |  Notify Moderator
I would be checking the air intake to make sure that nothing is blocking it. the yellow flame suggests to me that its low on oxygen. Just an idea.
dfhslm@telus.net
Dodge user
Chris Bryant
Arden, North Carolina
Posted: 10/30/19 11:28am Link  |  Quote  |  Print  |  Notify Moderator
Did you actually run a brush through the burner tube? It doesn’t take much at all to disrupt the gas flow.
-- Chris Bryant
opnspaces
San Diego Ca
Posted: 10/30/19 11:32am Link  |  Quote  |  Print  |  Notify Moderator
I still go with a spider web. You need to pull the tube off so you can find the orifice. Do not poke anything through the hole in the orifice, but do firmly wipe it off with something. Then clean off everything downstream of the orifice. Find a way to push and pull a rag through all the chambers for the flame. After that put it back together and I'll bet it fires.
I've also read on here about some kind of oil that can pool in propane lines and cause problems. If cleaning doesn't help I would probably turn off the propane bottles and disconnect the propane line. Then open a bottle slowly to see if you have good gas flow.
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
wildtoad
Blythewood, SC
Posted: 10/30/19 11:34am Link  |  Quote  |  Print  |  Notify Moderator
I’d make sure there is no blockage in the intake tube, burner tube. There’s not really a lot of adjustments on a Surburban like there is on an Atwood.
Tom Wilds
Blythewood, SC
Old-Biscuit
Verde Valley
Posted: 10/30/19 11:51am Link  |  Quote  |  Print  |  Notify Moderator
ORIFICE.......
It is dirty
Soak it in alcohol then air dry (no poking/no high pressure air)
Clean the burner tube using a small bottle brush
Propane flow/pressure pulls air in thru opening in burner tube right after orifice
Air mxiture is determined by propane flow
Propane flow....critical to proper air/fuel ratio for clean combustion BLUE Flame
newman fulltimer
louisiana
Posted: 10/30/19 12:17pm Link  |  Quote  |  Print  |  Notify Moderator
Change the regulator
DFord
Near St Louis, MO
Posted: 10/30/19 12:31pm Link  |  Quote  |  Print  |  Notify Moderator
Take the covers and burner tube off to expose both ends of the large (about 2 inch) tube that carries the flame through the water heater. It's just a big "U" tube that runs through the water and carries the products of combustion back out. It needs cleaning once it a while. The best way I know to do that is to run a rope through it so you can grab both ends. Take a shop towel type rag and tie it in the middle of the rope. Then drag it back and forth through the tube several times making sure it swabs the entire length of the tube. Then put it all back together and your nice blue flame should return. Wasps like to build nests in that tube and block the proper flow of gases. ANYTIME your water heater leaves a black streak up the side of your water heater, this is the thing to do to fix it.
Don Ford
'09 HHR 2LT or '97 Aerostar MiniVan (Remco driveshaft disconnect) for Towed vehicles
Old-Biscuit
Verde Valley
Posted: 10/30/19 02:47pm Link  |  Quote  |  Print  |  Notify Moderator
Sooting will cause combustion chamber to get dirty
Mud dabbers/nests etc will cause flame to blowback out of combustion chamber
Yellow sooting flame is due to RICH Fuel/LEAN Air condition....dirty orifice/burner tube
