RV.Net Open Roads Forum: Travel Trailers: Grease gun/ grease recommendations
 > Grease gun/ grease recommendations
Page of 5
Posted: 10/18/20 10:19am Link  |  Quote  |  Print  |  Notify Moderator
Both camps here.
There is merit to “doing it wrong” and blowing out the seals.
There is merit to disassembly and inspection.
And there is nothing wrong with adding some grease thru an easy lube or bearing buddy IF you know what you’re doing and understand.
Grease? I’m not generally a “this oil, grease , lube is the best” fanboy but I typically use Lucas red n tacky for basically all applications. Bearings, u joints, front end parts etc.
Seems to last the longest. But anecdotal evidence only, I only grease our old commercial mowers once a year. They get used weekly for a couple hours from Apr to Oct. Just homeowner use keeping up 5 acres.
If those blade and spindle bearings survive then it’s good grease.
2017 Heartland Torque T29
Posted: 10/18/20 10:20am Link  |  Quote  |  Print  |  Notify Moderator
Grease guns?
Depends how much you use them or what level of convienence you want.
Manual , air powered or cordless electric. From cheap to expensive
wopachop
Who run bartertown
Posted: 10/18/20 12:04pm Link  |  Quote  |  Print  |  Notify Moderator
Old thread that got bumped but i recently did my truck front tire bearings. Read a lot about greases and settled on the fully synthetic valvoline. Its in the gun i dont have the model number but pretty sure its #4 on the list that was posted above.
I didnt expect to choose that grease. I kinda view Valvoline as midrange, while i view lucas and timkin as high quality. Not sure why maybe the advertisers got me. Have used Lucas products for years.
I forget what the heck i learned, but you need to look into the type of grease. There is lithium, moly, extra virgin olive oil. They all have benefits and negatives. They also dont play nice with each other.
Installed new ball joints and tie rods and also wanted the grease to be compatible with that. I wrote the company (detroit axle...fingers crossed...ive read mixed reviews...sure was cheap in price) and asked what they pumped in there. Again i dont remember what they said. But after all the nonsense i did end up learning the Valvoline fully synthetic would work great for my high speed wheel bearing as well as the low speed ball joints.
Biggest negative was i wanted red grease. Looks clean to me. Not even joking i was bummed that the grease i will never see wasnt red!!!
falconbrother
North Carolina
Posted: 10/20/20 12:35pm Link  |  Quote  |  Print  |  Notify Moderator
I use the EZ Lube feature every year. Never had a problem. I jack up the axle under the "U" bolt. Then I check/adjust the brakes, then I add a few squirts of grease till I see it pushing out of the front, while spinning the tire. Then on to the next axle. All four axles can be done in a half hour easy. I use the grease gun that I inherited from my grandfather. It's probably as old as I am.
Dexter video
Wishin
Grand Rapids, MI
Posted: 10/22/20 09:31pm Link  |  Quote  |  Print  |  Notify Moderator
I think another factor in using the grease zerk (EZ Lube) feature is the temperature of the grease and bearings. If you are doing this on a cold spring day in cold weather to get ready to go on the first trip of the year, the grease is much thicker and harder to work thru the bearings and possibly more likely to push out the axle seal and get into your brakes. Might be better to do it in the middle of the summer on a 90 degree day. Also, make sure the trailer wheel is off the ground and rotating while you do it.
Me, I just do it manually by hand every 2 years or 10k miles. I have had one failure, not sure what caused it but the axle was likely over loaded as well. That is why my 8k lb trailer now has 5200 lb axles instead of 3500 lb axles. The bearings on the bigger axles are HUGE compared to the original bearings. I also monitor my bearings with an infrared heat gun to make sure they are staying cool. No issue the last few years with the bigger axles. Before I just check by hand so it is hard to say. It was also super hot the few days before I had my issue and I was in Arizona near the NM line when I saw smoke from the trailer. Fire extinguisher came in handy!
There are a lot of variables to consider to keep your bearings and brakes happy. Good luck.
2014 Wildwood 26TBSS - Upgraded with 5200lb axles and larger Goodyear ST tires
2003 Chevrolet 2500 4x4 Suburban 8.1L 4.10's
azdryheat
Tucson, AZ
Posted: 10/22/20 09:55pm Link  |  Quote  |  Print  |  Notify Moderator
I've used Lucas Red N Tacky #2 and Mystik Red #2.
* This post was edited 10/22/20 10:04pm by azdryheat *
2013 Chevy 3500HD CC dually
2014 Voltage 3600 toy hauler
2019 RZR 1000XP TRE
Vintage465
Prunedale CA.
Posted: 10/23/20 06:29am Link  |  Quote  |  Print  |  Notify Moderator
bpounds wrote:
Problem with that ^ theory is that there is a rubber boot built into the hub cover cap that expands to relieve any pressure. On hot runs I see those boots bulged outward and cold they are pulled inward.
Well, we all seem to have different thoughts on this subject. It works for some and not for others. One thing for certain, when the pressure builds in the hub the grease is going to take the path of least resistance. In my case it was the seals into the drums, possibly because my coach had between 25 and 30 thousand miles on the seals.
V-465
2013 GMC 2500HD Duramax Denali. 2015 CreekSide 20fq w/450 watts solar and 465 amp/hour of batteries. Retired and living the dream!
campigloo
Baton Rouge, La
Posted: 10/24/20 10:20am Link  |  Quote  |  Print  |  Notify Moderator
The void in the hub is meant to dissipate heat. Don’t fill it with grease. Best to grease and inspect them by hand.
mosseater
Dillsburg, PA
Posted: 10/26/20 06:17pm Link  |  Quote  |  Print  |  Notify Moderator
It didn't take me long to realize packing the hub is not only expensive, but pointless. I use the zerk once a year for a pump or three, then carefully use a grease needle to shoot in between the rollers on the outer bearing. Otherwise, repack by hand or grease packer. Only takes about 2 or 3 pumps to properly pack a bearing that size. You want to fill the hub, be my guest. I repack by hand every 5 years or so. Why would anyone want to force contaminated grease from the inner bearing through the outer bearing???
Sunset Creek 298 BH
wopachop
Who run bartertown
Posted: 10/26/20 06:35pm Link  |  Quote  |  Print  |  Notify Moderator
You seem like the really smart silent type. Thanks for posting i will remember your advice.
Page of 5
