RV.Net Open Roads Forum: Travel Trailers: Grease gun/ grease recommendations
 > Grease gun/ grease recommendations
Peter2516
Washington State
Posted: 10/30/19 01:18pm Link  |  Quote  |  Print  |  Notify Moderator
For EZ lube axle, what brand do you use for the wheel bearing grease.
Thank you -Peter
Huntindog
Phoenix AZ
Posted: 10/30/19 01:26pm Link  |  Quote  |  Print  |  Notify Moderator
Thank you -Peter
Do not use a grease gun on your axles.
In order to use this zerk feature, and completely purge the old grease out (maybe) it would take almost 4 tubes of grease at each greasing.... And it would most likely get past the inner seals and onto the brakes.
That creates quite a mess... Just don't do it.
Huntindog
100% boondocking
2010 Palomino Sabre 30 BHDS
84 gal. Grey. 84 gal. Black
2 bathrooms, no waiting
2020 Silverado High Country CC DA 4X4 Big Dually.
ScottG
Bothell Wa.
Posted: 10/30/19 01:54pm Link  |  Quote  |  Print  |  Notify Moderator
Huntindog wrote:
Thank you -Peter
X2.
That is the voice of experience.
Scott, Grace and Wesly
2018 Silver Fox 32A.
H0NDA eu2000i
ford truck guy
Pennsylvania
Posted: 10/30/19 01:59pm Link  |  Quote  |  Print  |  Notify Moderator
Like stated above,
Do not mess with those zerks, do them the old fashion way.....
BY HAND !
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
bpounds
Sophmore Brain...
Posted: 10/30/19 02:17pm Link  |  Quote  |  Print  |  Notify Moderator
Same old nonsense from those scaredy-cats who won't use their EZ lube feature. Just ignore that.
Follow instructions on how to use the EZ lube axles. You can find a video on it. Most importantly is to raise the wheel and rotate it while you slowly pump the grease. Watch around the spindle nut area, and as soon as you see the slightest movement of the old grease, stop. It is full.
Yes it will use a lot of grease the first time you do it, because the factory did not fill the voids in the hub. After the first time, it will take LESS grease than if you packed by hand. It shouldn't take more than 2 tubes the first time to do all 4 hubs. Buy 3 to be safe. Not a big expense.
I don't worry too much about brand, but Valvoline makes one that I like. Any of the wheel bearing greases will do, but I always pay the extra to get high pressure/temp grease that would normally go in disk brake applications. It will be more temperature stable.
Valvoline Clicky
2006 F250 Diesel
2011 Keystone Cougar 278RKSWE Fiver
Peter2516
Washington State
Posted: 10/30/19 03:34pm Link  |  Quote  |  Print  |  Notify Moderator
Thank you for all the advices and tip I appreciate it. I will watch more in YouTube. Thanks
Lynnmor
Red Lion
Posted: 10/30/19 03:41pm Link  |  Quote  |  Print  |  Notify Moderator
I use Pennzoil wheel bearing grease. Always use a grease that was made specifically for wheel bearings, Dexter has an approved list on page 53. I also will never use the grease fitting for reasons stated above plus the fact that the brakes are inspected annually and that would be a real mess.
JRscooby
Indepmo
Posted: 10/30/19 04:01pm Link  |  Quote  |  Print  |  Notify Moderator
I have never thought re-packing wheel bearings a big job. And when I pull the hub I can look at bearings, shoes, and magnets. YMMV. But lets use a little logic here.
Yes it full. But you have pumped new grease in, mixed it well with the old. Any contamination in the old grease is still in there. Might be good enough for you, or the people that sell axles and parts, but not me. Now if you keep pumping grease in, grease comes out clean, maybe.
Fill the voids in hub is just a waste of grease. As the temp changes the air space in the hub might prevent buildup of pressure on seals. Some think if the bearings get hot that grease will flow into the bearing. Maybe, but long before that grease is warm enough to flow the grease in the bearing will have left the building, taking bearings with it. You just have a lot more contaminated grease to clean out.
But I'm just a dumb truck driver. It's yours, you can do what you want
midnightsadie
ohio
EZ lube while work. but for piece of mind and knowing what it looks like in there I do mine by hand.first time you get grease all over your pads will make you a beleaver. and if your only a 5k mile per year camper ? you don,t need to do them every year.
ScottG
Bothell Wa.
Posted: 10/30/19 06:24pm Link  |  Quote  |  Print  |  Notify Moderator
Those with experience know. Notice that those that have been around the longest suggest not using them?
If you're going to do them, don't be lazy - do it right.
OTOH, there is no need to do them every year.
