RV.Net Open Roads Forum: Travel Trailers: Grease gun/ grease recommendations
 > Grease gun/ grease recommendations
Page of 5
JRscooby
Indepmo
Posted: 11/01/19 04:28am Link  |  Quote  |  Print  |  Notify Moderator
If I had a boat trailer I would pack my bearings by hand. Then I would fill the hub as well as I could by hand. (Grease in bucket is cheaper than tube). Then I would use the zerk to fill the hub. But I don't dunk the warm wheels/hubs in cold dirty water.
Lynnmor
Red Lion
Posted: 11/01/19 06:25am Link  |  Quote  |  Print  |  Notify Moderator
trailer_newbe wrote:
I have 1,000 miles on my 2018 trailer with EZ lube Zirks. I think I’ll do it the old fashioned way the first time.
I will always service the brakes and bearings immediately with a new or used trailer. I have seen enough to not trust these things to luck.
trail-explorer
NM
Posted: 11/01/19 07:44am Link  |  Quote  |  Print  |  Notify Moderator
trail-explorer wrote:
There's a video I need to find and post.
Here's on video
Here's another
Bob
Ride S40T
OK
Posted: 11/03/19 07:47pm Link  |  Quote  |  Print  |  Notify Moderator
Huntindog wrote:
Peter2516 wrote:
For EZ lube axle, what brand do you use for the wheel bearing grease.
Thank you -Peter
Do not use a grease gun on your axles.
In order to use this zerk feature, and completely purge the old grease out (maybe) it would take almost 4 tubes of grease at each greasing.... And it would most likely get past the inner seals and onto the brakes.
That creates quite a mess... Just don't do it.
This is what I've read for a while...so I called Dexter and asked their tech dept. They said using the zerk is the preferred method for greasing the bearings each year.
I specifically asked them about grease getting past the rear seal. They had no concern as long as a hand pump is used.
Wonder why they recommend as the zerk as the primary method? It would be a liability for them if they recommended something that could be a safety hazard for their customers.
That said, there is no doubt the hand method provides more piece of mind and ensures all is well with the internals.
2021 Grand Design 268BH
2019 GMC Sierra Denali HD 3500 SRW
Traveling K9s Diesel and Roger
Huntindog
Phoenix AZ
Posted: 11/03/19 11:50pm Link  |  Quote  |  Print  |  Notify Moderator
Ride S40T wrote:
Huntindog wrote:
Thank you -Peter
The printed manual states that annual disassembly and inspection is required maintainence. It is on page 84.
Huntindog
100% boondocking
2021 Grand Design Momentum 398M
2 bathrooms, no waiting
104 gal grey, 104 black,158 fresh
FBP, 3, 8K axles, Disc Brakes
17.5 LRH commercial tires
300 watts solar,
2020 Silverado High Country CC DA 4X4 Big Dually.
MFL
Midwest
Posted: 11/04/19 06:32am Link  |  Quote  |  Print  |  Notify Moderator
Both good thoughts! On a new trailer, from my experience, of many types of new trailers, only one had what I considered to be a good grease pack. As mentioned, a used trailer should be checked/packed soon after purchase.
In either case, disassembly/cleaning, and then packing yourself, you'll know it is done right, and the exact grease used, especially if you plan to use the EZs in the future.
Jerry
deltabravo
Spokane, WA
Posted: 11/04/19 06:56am Link  |  Quote  |  Print  |  Notify Moderator
I have two cargo trailers at the moment. The big one (8.5x20) was is a 2008 model year. I purchased in 2012. The guy I bought it from used it a LOT, for hauling race cars. I asked him if he'd ever repacked the bearings. He said he hadn't, but he pumped grease in the EZ Lube hub periodically.
When I pulled out of his driveway, I manually activated the brakes with my brake controller. I couldn't feel any braking. I kept cranking up the gain setting and ended up all the way at the highest setting where I barely felt any braking action. I knew at that moment there were issues with the brakes.
Once I had time to dig in to the brakes, I found all 4 had blown rear seals. It seems that the "path of least resistance" for the grease it to blow out the rear seal. The place on the axle where the grease exits the spindle when using the zerk, is a small hole partially covered by the inner bearing.
2018 Timber Ridge 24RLS (bought pre-owned 3/12/20)
Mr Faster
06457
Posted: 11/12/19 01:01pm Link  |  Quote  |  Print  |  Notify Moderator
I was an RV service manager for many years. I may be a little old school but I prefer hand or injector packing verses pumping grease through a zerk fitting. I've seen to many hubs over filled with grease, seal blown out and bearings overheated. Just remember it's the path of least resistance. you may be pumping in grease but it might not be going where you want it to. That being said, some grease is better than no grease...lol
My recommendation to my customers is to pull the hub, clean and inspect the spindle, bearings, and brakes if equiped. replace anything that is suspect. If bearings are to be changed. I recommend using Timken or equivalent high quality REM polished bearings. Hand or injector pack the bearings with Daylube or Microlon wheel bearing grease. And ALWAYS replace the seal. Do this yearly. Kits available at negearpolish.com It makes a big difference.
SamanthaNichols
2046 Hillcrest Drive Tacoma, WA 98402
Posted: 10/18/20 02:02am Link  |  Quote  |  Print  |  Notify Moderator
Lucas Oil has a great price as I go through a couple of tubes a year. I do not believe this product is a Synthetic Grease. Have used it for years. Does not leak out like I have had others do. I live in Arizona, at times the temperature in my garage hits 115 degrees F. I have had other greases leak down and liquefy making a huge mess. This green goop stays together. I use it on my front end components, U joints, trailer bearings. I also use it to lube the giant Orings on my pool filter and pool pump, backwash valve. Saves me lots of money over the pool specialty product.
Robert Clark
United State
Posted: 10/18/20 02:03am Link  |  Quote  |  Print  |  Notify Moderator
I think Valvoline grease is the greasiest of the greases. I have greased some things with this grease. Those things have been greased and will continue to have been greased. The container leaked a little though during shipment and some grease was on things that did not necessarily need to be greased. I cleaned it up though. No worries. Grease.
Page of 5
