RV.Net Open Roads Forum: Tech Issues: NOISEY GENERATOR
 > NOISEY GENERATOR
SM49
ontario
Posted: 10/30/19 06:51pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 2004 four winds 28a class c with a generac quietpac 40g generator, how can I quiet it down
Mojave, Kern County, California
Posted: 10/30/19 06:55pm Link  |  Quote  |  Print  |  Notify Moderator
Install an adequate solar system.
MDKMDK
Canada
Posted: 10/30/19 06:58pm Link  |  Quote  |  Print  |  Notify Moderator
Stop using it.
Mike.
2018 (2017 Sprinter Cab Chassis) Navion24V + 2016 Wrangler JKU (sold @ ????)
2016 Sunstar 26HE, V10, 3V, 6 Speed (sold @ 4600 miles)
2002 Roadtrek C190P (sold @ 315,000kms)
Posted: 10/30/19 07:08pm Link  |  Quote  |  Print  |  Notify Moderator
MDK, that’s what I was advocating. But directness has its place.
beemerphile1
Ohio
Posted: 10/30/19 07:25pm Link  |  Quote  |  Print  |  Notify Moderator
I've read that a raw potato in the exhaust pipe really quiets them down.
Seriously, what's the issue? Is something wrong with it?
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
pnichols
The Other California
Posted: 10/30/19 08:07pm Link  |  Quote  |  Print  |  Notify Moderator
I would suggest adding (glueing?) sound proofing material onto all of the interior walls of the cabinet in which the generator is installed by the motorhome builder.
The fireproof sound proofing material used by boaters would be best. When you attach any of the material - make sure to not block or decrease the air flow path size - of where cooling air enters and exits the areas around the generator.
Make sure to include the interior cabinet wall right above the generator so as to reduce sound transfer into the coach interior. For the ultimate in any generator vibration isolation from the interior, high performance isolation mounts (they're not expensive) can replace the simple rubber feet that probably are used with the stock installation by the motorhome builder.
IMHO ... you should ignore the smart-alec/wise-guy comments earlier. For what we pay for motorhomes, they better be able to be used just about anywhere anytime to protect and provide for the users comfortably without hookups ... just as a small stick-house does with hookups. A built-in motorhome generator helps do just that.
By the way FWIW, our stick-house in a rural location looses grid power occasionally and our small emergency generator helps sustain us just fine!
Phil, 2005 E450 Itasca Spirit 24V
Posted: 10/30/19 08:36pm Link  |  Quote  |  Print  |  Notify Moderator
“For what we pay for motorhomes,...” we should be able to unnecessarily bother all our close neighbors with generator noise. Heck, solar is new. Once the bugs are worked out...
doxiemom11
Yoakum Texas
Posted: 10/30/19 09:07pm Link  |  Quote  |  Print  |  Notify Moderator
Does it need a new muffler? Our Onan has a muffler on it.
DFord
Near St Louis, MO
Posted: 10/30/19 09:17pm Link  |  Quote  |  Print  |  Notify Moderator
Unfortunately, OEM generators for RVs all operate at a constant speed of 1800 or 3600 RPM in order to produce 60Hz power. So far, Onan and Generac have failed to get up to speed with inverter technology that would allow them to run only as fast as required to meet usage demands. Honda and all the Honda knock-offs have no problem making inverter type generators. My solution was to buy a small inverter generator and set it next to my MH. After it tops off my batteries, it idles down and I can hardly hear it while I watch TV with my lights on. It runs about 5 or 6 hours on a gallon of gas which beats the pants off the gallon an hour the onboard generator uses. Newer models use technology that permits you to start/stop and monitor how much gas is in the tank on your phone.
I few years ago, I corned a rep at the Onan booth at an FMCA rally and raised a fuss with him about their using such ancient technology. He liked what I said and made a video of me complaining on his camera to take back to the factory. I haven't heard anything about upgrades to their products so far but they're way past due!
Don Ford
'09 HHR 2LT or '97 Aerostar MiniVan (Remco driveshaft disconnect) for Towed vehicles
gemsworld
Arizona West Coast
Posted: 10/30/19 09:40pm Link  |  Quote  |  Print  |  Notify Moderator
There's no incentive because there is no competition. Why spend money on innovation when you can still make a mint selling Model A Fords in 2019?
 > NOISEY GENERATOR
