RV.Net Open Roads Forum: Tech Issues: NOISEY GENERATOR
 > NOISEY GENERATOR
pnichols
The Other California
Posted: 10/30/19 09:56pm Link  |  Quote  |  Print  |  Notify Moderator
Just as some clarification comments:
1. Our built-in Onan RV generator changes loudness level with the instantaneous amperage load on it - even though it's running at a constant 3600 RPM. i.e. It's not as loud when running the microwave or electric heater as it is when running the air conditioner. BTW, wlhenever the inverter generators are called upon to deliver their full loads - they spin at above 4000 RPM ... which indeed makes them "loud" then.
2. Our built-in 4000 watt built-in RV generator only consumes about 0.4 gallons per hour when delivering it's full load. As comparison, our 4400 watt stick house emergency generator averages at least 12 hours runtime on 5 gallons of regular E10 gas.
3. However as full discloser, for long battery charging runs when RV drycamping we carry along one of the quietest portable suitcase generators ever offered ... and it runs at a constant 3600 RPM up to it's maximum power output level at a constant hum level of only 54 dBA. That little genny is the long discontinued (but still available used) Honda EX650.
Phil, 2005 E450 Itasca Spirit 24V
DrewE
Vermont
Posted: 10/30/19 10:07pm Link  |  Quote  |  Print  |  Notify Moderator
DFord wrote:
Unfortunately, OEM generators for RVs all operate at a constant speed of 1800 or 3600 RPM in order to produce 60Hz power. So far, Onan and Generac have failed to get up to speed with inverter technology that would allow them to run only as fast as required to meet usage demands.
I few years ago, I corned a rep at the Onan booth at an FMCA rally and raised a fuss with him about their using such ancient technology. He liked what I said and made a video of me complaining on his camera to take back to the factory. I haven't heard anything about upgrades to their products so far but they're way past due!
The (diesel fueled) Onan QD 6000 and QD 8000 RV generators are inverter generators that vary their engine speed with changes in the load.
time2roll
Posted: 10/30/19 10:26pm Link  |  Quote  |  Print  |  Notify Moderator
Do you run the air conditioner a lot when off grid? Otherwise 200+ watts of solar and a Honda 2200 might help.
675w Solar pictures back up
maillemaker
office
Posted: 10/31/19 09:28am Link  |  Quote  |  Print  |  Notify Moderator
There is not much you can do. Sound deadener can help, but as was said make sure it's fireproof and make sure you don't intrude into the airspace around the generator.
In my RV the generator compartment is totally open on the bottom. So parking over pavement makes it seem a lot louder than parking over grass.
I have considered buying some sort of "egg crate foam" to lay on the ground under the generator. But there's always the risk of it getting blown around or sucked up into the generator area blocking airflow. I've also considered building some kind of foldable "dog house" that you could set up next to the RV to block in some of the sound. But that would be a pain to stow.
1990 Winnebago Warrior. "She may not look like much but she's got it where it counts!"
pnichols
Posted: 10/31/19 10:44am Link  |  Quote  |  Print  |  Notify Moderator
How about a piece of heavy carpet (that is easy to store) and that you just lay on the ground under the generator compartment? I've also noticed that the outside sound is reduced when parked on grass or dirt, so a piece of heavy carpet there should work pretty good.
* This post was edited 10/31/19 08:05pm by pnichols *
ksg5000
Oregon
Posted: 10/31/19 11:10am Link  |  Quote  |  Print  |  Notify Moderator
Lots of threads about how to mitigate noise of RV generators - use the forum search feature. Std's include isolating the generator box with sound dampening material etc. Noise is relative - I hate the air conditioner far more than my Onan 4000.
Kevin
maillemaker
office
Posted: 10/31/19 12:17pm Link  |  Quote  |  Print  |  Notify Moderator
How about a piece of heavy carpet (that is easy to store) and that you just lay on the ground under the generator compartment? I've also noticed that the outside sound is reduced when parked or grass or dirt, so a piece of heavy carpet there should work pretty good.
Might work.
Steve
Mojave, Kern County, California
Posted: 10/31/19 07:29pm Link  |  Quote  |  Print  |  Notify Moderator
“for long battery charging runs when RV drycamping...”
For long battery charging runs (absorption), solar is the better answer.
Veebyes
Posted: 10/31/19 08:09pm Link  |  Quote  |  Print  |  Notify Moderator
The comedians aside, what pnichols said will reduce it. I have a soft paneled sound shield for my boats 6kw diesel genny. There is no getting rid of the hum. The best to be hoped for is a reduction.
2007 Alpenlite 34RLR
jjrbus
FT Myers FL
Posted: 11/01/19 07:41am Link  |  Quote  |  Print  |  Notify Moderator
When doing bus conversions we built sound box's for the generators, they can be quieted down, same as boats. What the RV manufactures sell is unconscionable!
Google generator sound box to get some ideas but there is unlikely enough room to do much.
Then they duct the AC units and put a hole in the ceiling directly under the motor and blower fan. Yep that makes a lot of sense!
For some people no amount of noise is an issue, wish I was one of them. I am sensitive to noise and firing up the genny and turning on the AC is like running a shop vac in the RV 24/7. I use a Honda 2000 and an 8k window unit.
 > NOISEY GENERATOR
