RV.Net Open Roads Forum: Tech Issues: Macerator pumps
 > Macerator pumps
hedgehopper
Denver
Posted: 10/31/19 11:48am Link  |  Quote  |  Print  |  Notify Moderator
I am considering buying a Flojet 18555000A macerator pump. But many owners say they have had problems.
A 120-volt pump might be better. But they look to be expensive.
A pump that attaches directly to the black-tank outlet looks to be the handiest.
What pump (12 volt or 120 volt) have you used and found satisfactory?
All comments that are based on your experience are welcome.
Old-Biscuit
Verde Valley
Posted: 10/31/19 12:00pm Link  |  Quote  |  Print  |  Notify Moderator
Bought a Flojet portable to pump waste tanks 75' with a 2' rise.
10 minutes pumping/motor very warm...shut down to cool then pumped another 10 minutes. 75' thru 3/4" hose 128 gallons----sure beat alternative of dragging a tote back/forth.
That was in 2008..still have it, still use it and have not had to repair it.
Have dissassembled to clean twice but that is no big deal either
DFord
Near St Louis, MO
Posted: 10/31/19 12:23pm Link  |  Quote  |  Print  |  Notify Moderator
I keep my macerator pump handy for those rare times when I come home without emptying my tanks first. I connect the end of the pump directly to the 3" sewer hose and pump through a 3/4" garden hose into a slop sink in my garage. It's quick and a lot easier than the old bucket method. It keeps up with and even gets ahead of the blasters in the tanks flushing everything toward the drains. If I want the tank to fill, I have to stop the pump. The impeller has a hard time dealing with hair and I'll use my needlenose pliers to untangle and remove it before storing it away for the next time. They're very handy!
Don Ford
'09 HHR 2LT or '97 Aerostar MiniVan (Remco driveshaft disconnect) for Towed vehicles
hedgehopper
Denver
Posted: 10/31/19 12:27pm Link  |  Quote  |  Print  |  Notify Moderator
Do you know the make and model of the pump?
SoundGuy
S Ontario
Posted: 10/31/19 12:41pm Link  |  Quote  |  Print  |  Notify Moderator
I bought a FloJet macerator back in 2006, used it constantly for a dozen years and only rebuilt it once to add a new impeller. I never use campground dump stations, always have serviced the tanks at home using the macerator. A series of pics starts here - click on "i" at the top right of any pic for a text description.
2012 Silverado 1500 Crew Cab
2014 Coachmen Freedom Express 192RBS
2003 Fleetwood Yuma * 2008 K-Z Spree 240BH-LX
2007 TrailCruiser C21RBH * 2000 Fleetwood Santa Fe
1998 Jayco 10UD * 1969 Coleman CT380
DFord
Near St Louis, MO
Posted: 10/31/19 01:46pm Link  |  Quote  |  Print  |  Notify Moderator
Here's a couple of pictures. It's made by Jabsco but the Flojet from Amazon looks exactly like what I started with. I'm thinking the two companies share a common background.
Flojet 18550000A 13 GPM RV Macerator Pump
The Best RV Macerator Pumps for 2019
ependydad
Here and there
Posted: 10/31/19 02:57pm Link  |  Quote  |  Print  |  Notify Moderator
I've used the Flojet 18555-000A pump for hundreds (if not thousands) of gallons of waste water.
https://learntorv.com/flojet-macerator-pump/
2017 Spartan 1245 by Prime Time
2018 Ram 3500 Crew Cab DRW w/ 4.10 gears and 8' bed
FW Hitch: TrailerSaver TS3
Learn to RV- learn about RVing - Towing Planner Calculators - Family Fulltiming FB page
Wherever I happen to park
Posted: 10/31/19 03:03pm Link  |  Quote  |  Print  |  Notify Moderator
I have one.. Do not often use it (only when I have to either push UP hill or a long distance) but it works well There is just one "Gotcha" that got me.. And once you know what it is (next paragraph) it won't get ya ever again.
The impeller sticks if it's not used for a while.... AND they know about it.
So the motor shaft sticks out of what I call the "Bottom" of the motor.
Before you hook it up take a flat tool (IE a quarter or washer) and insert it in the slot in the motor shaft and give it a twist in the direction the outlet suggests you should twist (clockwise I think) then hook up. and power up.
Now I fed mine with 10ga off the main fuse block and anderson powerpoles. that's the other issue lack of proper power feed.. Works great. It is SLOWER than a 3" stinky slinky (Why I don't use it all the time) but when I need it.. WOW it's nice .*I've pumped 75 feet with it and up hill.
Home is where I park it.
navigator2346
texas
Posted: 10/31/19 03:15pm Link  |  Quote  |  Print  |  Notify Moderator
Somewhere on the net is a write up of using a household garbage disposal for a macerator. Here's one example. https://www.youtube.com/watch?v=YsY9WVhnm1c
RobWNY
Jamestown, NY
Posted: 10/31/19 03:36pm Link  |  Quote  |  Print  |  Notify Moderator
I have the flojet macerator as well. It works great although mine tends to overheat because I have a long run of 1" hose and I have to wait for it to cool down to continue. Not a big deal to me. I'd rather take care of things while in the comfort of my yard where I can do it at my leisure and get the tanks as clean as I want.
You can't put a porcupine in a barn, set it on fire, and expect to make licorice.
Life is a lot like a baseball pitch. Sometimes you get a fast ball down the middle of the plate and sometimes you get a curve ball in the dirt.
 > Macerator pumps
