RV.Net Open Roads Forum: Technology Corner: Using Winegard Satelite Dish Far From Home???
 > Using Winegard Satelite Dish Far From Home???
Bill.Satellite
Full-timer
Posted: 11/01/19 04:11pm Link  |  Quote  |  Print  |  Notify Moderator
Personally, I would select 18" round at that will pull in 101 only. There's nothing available on 119 unless you use some special language programming.
The dome (an R4, not P4) also has 2 outputs. If you (or someone) ran both coax into the coach you can use the 2nd tuner of the DVR as well.
Glad to hear you have it working!
What I post is my 2 cents and nothing more. Please don't read anything into my post that's not there. If you disagree, that's OK.
Can't we all just get along?
BradW
Mayor of Flat Rock
Posted: 11/01/19 04:58pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the info. The reason we selected (18 x 20 “triple-sat-LNB) instead of (18” Round LNB) was when we first called Winegard helpline several months back, that is what they sugested. I will try 18" Round LNB next time we have the receiver out there.
The display showed two 101 satellites and two 119 satellites. It showed a check mark by both 119's, but only one of the 101's. If 119's don't have anything on them I need, then I don't need them.
I'm pretty sure our model number is P4, but I will check it again.
The dome came with our 2019 Lance truck camper and was installed at the factory. It appears they only ran one coax.
Thanks for your help,
bradw
Wake Up America
2019 Lance 1062 and 2018 F-350 CC PSD 4X4 DRW
Tembrens, Rear Roadmaster Sway Bar, Torklift 48" Extention and 30K Superhitch
Our New Lance 1062 Truck Camper Unloading at Dealer Photos
Bill.Satellite
Full-timer
Posted: 11/02/19 06:10am Link  |  Quote  |  Print  |  Notify Moderator
bradw
While I am not familiar with a P4, there is also not an R4, my bad. There is a T4 (watch TV while in motion), D4 Durasat (most meant for truckers) and a G3 (auto dome but works while parked only).
BradW
Mayor of Flat Rock
Posted: 11/02/19 11:41am Link  |  Quote  |  Print  |  Notify Moderator
Winegard P4
Me thinks that P4 may be something they cooked up just for Lance.
bardw
Bill.Satellite
Full-timer
Posted: 11/02/19 05:44pm Link  |  Quote  |  Print  |  Notify Moderator
Certainly might be. I worked for Winegard and I have never heard of it.
BradW
Mayor of Flat Rock
Posted: 11/02/19 06:21pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks again, your info has been very helpful.
bradw
