RV.Net Open Roads Forum: Tech Issues: Loose tow bar in receiver
 > Loose tow bar in receiver
down home
south
Posted: 11/01/19 01:05am Link  |  Quote  |  Print  |  Notify Moderator
I emailed Roadmaster and got no response.
The Sterling Tow bar where it plugs into the receiver on the Motorhome has an 1/8" to 1/4" clearance top and bottom. It rotates up and down on the pin. 4500 lbs of towd slams it up or down on stopping or starting or braking....and that is not a good thing.
Campign World installed the tow bar years ago.
I have tried to put small rubber washers on top and bottom but of course they didn't stay.
I don't think this was intentionally designed to do this.
Any ideas on how to fix this before it destroys the receiver?
wnjj
Cornelius, Oregon
Posted: 11/01/19 01:26am Link  |  Quote  |  Print  |  Notify Moderator
Have a welding/fabrication shop attach thin plates to the top and bottom or just run weld beads to thicken the bar.
Tom_M
New Hope, MN
Posted: 11/01/19 04:30am Link  |  Quote  |  Print  |  Notify Moderator
Here's a link to to etrailer.com which has several solutions.
Tom
2005 Born Free 24RB
Towing 1978 VW Bug convertible
Minneapolis, MN
Wherever I happen to park
Posted: 11/01/19 04:37am Link  |  Quote  |  Print  |  Notify Moderator
Blue ox makes/made a product one of them is called an "Anti rattle clip" the other Hitch Immobilizer (Same product they changed the name) it's a clamp that locks that hitch solid. Have used one for 14 years now.
Home is where I park it.
MDKMDK
Canada
Posted: 11/01/19 06:26am Link  |  Quote  |  Print  |  Notify Moderator
Go to Walmart and buy a small packet of flat washers, preferably as close in ouside diameter, to the inside diameter of the receiver tube sides you want to shim. Gently (or not?) tap them into the receiver with a screwdriver and hammer, or similar, until they fill the gaps and shim up the hitch/shank. Helps if you (or a helper) can wiggle the shank a bit while you're inserting the flat washers. Then use a couple of cable/zip ties placed close to the receiver opening around the shank to keep them from escaping.
Total cost, less than $5.
Mike.
2018 (2017 Sprinter Cab Chassis) Navion24V + 2016 Wrangler JKU (sold @ ????)
2016 Sunstar 26HE, V10, 3V, 6 Speed (sold @ 4600 miles)
2002 Roadtrek C190P (sold @ 315,000kms)
enblethen
Moses Lake, WA
Posted: 11/01/19 06:29am Link  |  Quote  |  Print  |  Notify Moderator
This is what I used to fix movement in hitch.
Roadmaster Quiet hitch
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
freetime58
Winnipeg
Posted: 11/01/19 07:17am Link  |  Quote  |  Print  |  Notify Moderator
Does it fit more tightly on the sides? If not, and you have a 1/4" play top and bottom and the sides. You don't mention what type or year of motorhome, if you have had it for a while or it's new to you........I suspect you may have a 2" insert in a 2 1/2" receiver???? It's highly unusual that a 2" draw bar have that much play in a 2" receiver. There is some movement in all set ups but I have never seen 1/8 to 1/4 inch play.
DFord
Near St Louis, MO
Posted: 11/01/19 12:48pm Link  |  Quote  |  Print  |  Notify Moderator
You can find these or similar devices on eBay @ 2 for $20. They work great to take out all the movement in your towbar.
Don Ford
'09 HHR 2LT or '97 Aerostar MiniVan (Remco driveshaft disconnect) for Towed vehicles
IAMICHABOD
Sunny So Cal 90713
Posted: 11/01/19 01:53pm Link  |  Quote  |  Print  |  Notify Moderator
You need a good anti rattle device so you don't get so much play in the receiver,thus magnifying the movement and doing more damage to the receiver.
I have tried almost every Anti Rattle device on the market, most have been no good or so complicated and cumbersome that they are useless. Including the Roadmaster type,totally useless,as is all that have been mentioned here.
Until I found the one at Hitch Rider.
Their Hitch Vice is the best and easiest one I have come across and it really works.
Former El Monte RV Rental
Buying A Rental Class C
Chevrolet Based Class C
down home
south
Posted: 11/01/19 02:29pm Link  |  Quote  |  Print  |  Notify Moderator
Clearance side to side is minimal to none.Excessive Clearance is top to bottom. It's an 05 Revolution.
