RV.Net Open Roads Forum: Toy Haulers: Where to jack
Search only in Toy Haulers
 > Where to jack
ijon1
flint mi.
Posted: 11/01/19 07:33am Link  |  Quote  |  Print  |  Notify Moderator
Hi, I am going to change all four tires on my Fury 2910 toy hauler. My question is where should I place the jack and jack stands?
12th Man Fan
Flower Mound , Texas
Posted: 11/01/19 07:50am Link  |  Quote  |  Print  |  Notify Moderator
According to the axle mfg you should use the frame in front and behind the wheels.
I use a jack under the axle where the springs are bolted to the axle. I also use a board between the jack and the axles.
If your axles are on top of the spring pack you don't need the board.
2014 GMC Duramax 4X4 DRW Crew
2015 DRV Tradition
nayther
Burbank, CA
Posted: 11/01/19 08:03am Link  |  Quote  |  Print  |  Notify Moderator
Same here. But if you're pulling all 4 at once you may just want to raise the entire rig up on stands, just place the properly rated jack stands under the frame at the front and rear spring hangers. I'd drop my levelers or jacks as well. This always made me nervous, only did one side at a time.
DIRT BIKES RULE
'12 Duramax CC short bed
2019 Wildcat Maxx 285RKX
ependydad
Here and there
Posted: 11/01/19 10:59am Link  |  Quote  |  Print  |  Notify Moderator
I've only lifted the whole camper a few times (each day for a week while we dealt with frame damage). If I recall, we put jack stands behind the axles and then had the front of the camper supported by the landing gear.
If I recall correctly, put put the jack stands behind the axles and then raised the front of the camper until there was weight on the jack stands.
Then I proceeded to remove each wheel.
To remove a wheel, I'm not lifting the whole camper, I'm just lifting the tire. Rightly or wrongly, I do that by putting a jack on the axle between/next to where the U-Bolts connect to it.
(And yes, I know there's debate over the safety of putting the bottle jack on LynxLevelers like that.)
2017 Spartan 1245 by Prime Time
2018 Ram 3500 Crew Cab DRW w/ 4.10 gears and 8' bed
FW Hitch: TrailerSaver TS3
Learn to RV- learn about RVing - Towing Planner Calculators - Family Fulltiming FB page
twodownzero
NM
Posted: 11/01/19 12:21pm Link  |  Quote  |  Print  |  Notify Moderator
I put the jack directly under the axle.
Monterey, CA
Posted: 11/01/19 12:47pm Link  |  Quote  |  Print  |  Notify Moderator
Why use a jack? Build a wooden ramp. Loosen lugs, run "good" tire up the ramp. Change the tire. Run "good" tire down the ramp.
mapguy
Puget Sound
Posted: 11/01/19 12:49pm Link  |  Quote  |  Print  |  Notify Moderator
Need to be real careful jacking directly on the axle tube. It can dent/deform fairly easily from the point load.
I use a piece steel angle to protect the axle tube if doing a single tire or one side of trailer when jacking.
12th Man Fan
Posted: 11/01/19 01:45pm Link  |  Quote  |  Print  |  Notify Moderator
If you are lifting by the frame or with hydraylic levelers, do not lift all four wheels off the ground at one time. You could flip the shackles and that is a pain in the %%%%% to fix.
I would not jack a wheel up like in the pictures unless I had a jack with a large enough head to fit over both U bolts or some other type of pad. There is too much weight on a very small area the way the picture shows. I suspect that is why the axle mfg recommends using the frame.
Terryallan
Foothills NC
Posted: 11/01/19 02:12pm Link  |  Quote  |  Print  |  Notify Moderator
You can bend the axle that way. Especially if you get away from the wheel.
Terry & Shay
Coachman Apex 288BH.
2013 F150 XLT Off Road
5.0, 3.73
Lazy Campers
Blackdiamond
So. Cal
Posted: 11/01/19 02:56pm Link  |  Quote  |  Print  |  Notify Moderator
Drag the trailer to the tire shop and let them deal with it.
03' Fleetwood Southwind 32VS
Enclosed Trailer hauling the toys
05 525 EXC KTM
15' FE350s Husqvarna/KTM
07 Rhino, long travel, 4 seater
 > Where to jack
