RV.Net Open Roads Forum: Toy Haulers: Where to jack
Search only in Toy Haulers
 > Where to jack
ijon1
flint mi.
Posted: 11/02/19 05:52am Link  |  Quote  |  Print  |  Notify Moderator
Blackdiamond wrote:
Drag the trailer to the tire shop and let them deal with it.
Thanks guys.
arhayes
Posted: 11/03/19 01:51pm Link  |  Quote  |  Print  |  Notify Moderator
I use my level system to raise one side, put jack stands on each axle at the u-bolt, then put a 20 ton jack on the frame as additional support in case of hydraulic failure. We're full-timers and I change tires by side so this works out great for me. I just take the wheels to a shop and have them mount and balance the new tires
Alan and Kathleen
2015 Grand Design Momentum 380TH (RVD2)
2014 F350 6.7L Diesel DRW (Stormtrooper)
2012 Honda Goldwing NAVI/ABS (Land Speeder)
Dirtclods
Newport Beach
Posted: 11/04/19 06:57pm Link  |  Quote  |  Print  |  Notify Moderator
I don't jack the axles I jack up the frame or https://www.walmart.com/ip/BISupply-Tand........msclkid=9abbf8e24ba91a1c1ff2a5229dd8d952
https://www.youtube.com/watch?v=6pFs-VSjj8E
lincster
Mesa Az
Posted: 11/05/19 07:07am Link  |  Quote  |  Print  |  Notify Moderator
No thanks.
The kids as discount started jacking mine up by the middle of the axle.
Then they tried to use the rubber portion of my Dexter kit.
I had to school them on how to lift a heavy, triple axle toy hauler.
Always by the frame is how I lift mine.
2019 F350 PSD CC 4X4 Dually to pull 2006 LE3905
Lincsters Truck/Trailer
Lincsters Rail
ijon1
flint mi.
Posted: 11/08/19 06:28am Link  |  Quote  |  Print  |  Notify Moderator
lincster wrote:
No thanks.
With low profile trailer the frame is the place to jack.
JIMNLIN
Oklahoma
Posted: 11/09/19 06:48am Link  |  Quote  |  Print  |  Notify Moderator
hmmm. three different 5th wheel rv trailers...one TT...and maybe 12-13 GN flatedecks.....three cargo trailers and never had a need to jack the whole trailer off the ground. Anywaze.....
I use a shorty hyd jack under the axle tube next to the U bolts when servicing/changing a flat on one wheel. The jack is a truckers special that has a adapter that fits over the top of the jack and cradles the axle tube...no slips in any terrain even with big rigs blasting by at 80 mph.
Std leaf spring suspension axle tubes (1750 lb to 10k lb axles) will not spot crush/dent jacking from a single spot. All this method does is lift one end of the axle.
Now, I have jacked one side from the frame and removed 2 or 3 or 4 wheels on that side depending on tandem/triaxle or tandem duals. If the trailer was long I used two jack next to the farthest spring hangers for a lift on one side. I bent the frame on a fully loaded 40' GN triaxle by lifting from the frame from a single point between the axles while changing a flat tire on the side of the road. Lesson learned. Thats when I found the 12t shorty hyd jack made for jacking from the axle tube.
You need a lot of cribbing to lift all the tires off the surface for removing all the wheels. When its that high be safe and use safety jacks or RR ties placed where they won't roll and drop the trailer. Be safe and don't take chances.
Don't do what my silly bil did and leave the trailer hooked to his truck. After jacking all 4 off the pavement his wife said he was so proud.....until he called me and asked if he could use my truck to run his tires to the tire shop.
ijon1
flint mi.
Posted: 11/10/19 05:19am Link  |  Quote  |  Print  |  Notify Moderator
Ha, good one.[emoticon]
 > Where to jack
