RV.Net Open Roads Forum: Class A Motorhomes: SPARE TIRE
 > SPARE TIRE
HBJBIRD
ORANGE
Posted: 11/01/19 07:38am Link  |  Quote  |  Print  |  Notify Moderator
Just switched from a C Class to a A Class. 2015 Thor Hurricane 34J.
Looking to add a spare. What size Wheel do I need ? Currently running
245 x 70R 19.5
Also has anyone tried this. And would it work on the new coach ?
https://www.ebay.com/itm/RV-Camper-Hide-Spare-Tire-Storage-Carrier-Underslung-Easy-to-Mount-Wheel-Holder/113643323460?epid=18024658891&hash=item1a75ab8044:g:y0kAAOSw3qRbvO~c
Thanks.
2bzy2c
California
Posted: 11/01/19 09:04am Link  |  Quote  |  Print  |  Notify Moderator
Clicky
My advice is worth exactly what you paid for it.
George3037
Central Square, NY
Posted: 11/01/19 09:18am Link  |  Quote  |  Print  |  Notify Moderator
My spare is on the back but about 3' off the ground. That's quite high to lift a 150lb. spare wheel and tire. Requires 2 people. I like the mount you posted but I don't have space under the Class A to mount it. That would fit on my TT but not under the MH. Have you checked to see if you can mount it under yours?
Sam Spade
North Central Florida
Posted: 11/01/19 09:19am Link  |  Quote  |  Print  |  Notify Moderator
Visit a truck tire dealer, let them look at what you have and tell what you need to order......and maybe sell you one too.
The front rims and the back ones might not be the same.
Because of that, I carry a spare "tire" only without a rim.
If you do that, you need to specify that the truck they dispatch needs to be capable of putting your spare on the rim at the side of the road......OR be able to tow the entire rig to a place that can.
'07 Damon Outlaw 3611
CanAm Spyder in the "trunk"
HBJBIRD
ORANGE
Posted: 11/01/19 09:27am Link  |  Quote  |  Print  |  Notify Moderator
It looks like it would ? I need to look into more. Was wondering if anyone has tried it with an A Class like mine.?
Thanks.
js218
on the road
Posted: 11/01/19 10:27am Link  |  Quote  |  Print  |  Notify Moderator
I carry 2 spares but they are in my trailer with the Explorer.
2017 Haulmark 45' Super C 600hp, 12 speed I shift transmission, tandem drive axles, 3 stage engine brake, towing 26' trailer with an 08 explorer inside.
Jim
Executive
Posted: 11/01/19 10:40am Link  |  Quote  |  Print  |  Notify Moderator
I carry a Visa card. Lot less weight and less stress. A 19.5 tire can be purchased and mounted anywhere. In over 50 years of RVing I've only had 2 flats. Don't overthink this...JMHO.....Dennis
A Simple Act of Caring Creates an Endless Ripple
Dennis and Debi Eleven Years Full Timing
2014 Chevrolet Equinox LTZ W/ ReadyBrute
CLICK HERE TO VIEW OUR TRAVEL BLOG
grldst
Dallas, GA
Posted: 11/01/19 11:13am Link  |  Quote  |  Print  |  Notify Moderator
A spare tire is just not worth the bother. I have been RVing since the mid 80's and have logged over 200,000 miles, have RVed to Alaska and Mexico and only had one blowout, and that was due to a 20 yr old tire an unscrupulous dealer stuck on the inside dual.
Check your tires before every trip, replace them around the 7 yr mark and your odds of needing a spare are nil. If the odds are against you and you have a problem, due as mentioned above, make a phone call.
Think about it....I can't remember even using a spare on any of my other vehicles.
HBJBIRD
ORANGE
Posted: 11/01/19 11:34am Link  |  Quote  |  Print  |  Notify Moderator
I like the confidence you have with your tires and road side service. I have been stuck on the side of the road for 7 plus hours with wife and kids. Not much fun. I travel in areas that has no cell phone service ? What if your wheel is damaged ? What's the cost of tire being brought to you to be mounted vs buying a spare to have for the scenarios mention above. Glad you've been so lucky. I'd rather be prepared. Thanks for the replies though.
emiddleb
Michigan
Posted: 11/01/19 11:59am Link  |  Quote  |  Print  |  Notify Moderator
I'd suggest you do some more researching. The BAL website (maker of the gadget) shows about 4 models, all of which only discuss mounting under trailers. A thread on the Forest River site discusses the mounts, one mentions it having a 100 lb capacity. Could be that this works fine for trailer-size wheels but might have a problem with our 22.5" heavy boys. You might want to contact the manufacturer directly with some questions before you dive in based on an Ebay listing (which also appears to be overpriced.)
BAL web site
2004 Winnebago Vectra 40KD
Roadmaster Tow Dolly
 > SPARE TIRE
