RV.Net Open Roads Forum: Tech Issues: Pop goes the water heater!
 > Pop goes the water heater!
RobG
Mesa, AZ
Posted: 11/01/19 09:08am Link  |  Quote  |  Print  |  Notify Moderator
I had a new water heater installed back in 2014. It popped two nights ago. I got up to the sound of water -- I actually thought it was raining. Upon closer inspection, it was water pouring out of my water heater. It made quite the flood outside.
I shut off the water to it, and got a flashlight. The "tunnel" where the burner goes is all rusted out and collapsed. Despite ensuring a good anode rod, it appears that corrosion did the thing in.
So now I have two choices: Replace it with another one, or go with an on-demand system. Cost is similar: About $500 for either. The on-demand system that people seem to be recommending is the Girard 2GWHAM. The water heater I'd use is a Suburban 10- or 12-gal unit. The trailer came with a 12-gal, but it got replaced with a 10 in 2014 (which I didn't know until yesterday; I thought it was another 12).
In the meantime, I'm showering in my camper. Thankfully I have that as an option.
Any suggestions? Any other (cheaper hopefully) on-demand units I can consider?
Thanks.
Rob
2019 Arctic Fox 992 Truck Camper
2006 Keystone Raptor 3814SS 5th Wheel Toyhauler (live in it fulltime)
2005 Dodge RAM 3500 Quad Cab Dually 4x4 SLT 6sp
A quad, a few motorcycles, and a dog.
ScottG
Bothell Wa.
Posted: 11/01/19 09:54am Link  |  Quote  |  Print  |  Notify Moderator
Read through the reviews on Amazon. Co. has a record of very poor assistance when they don't work - which is often.
I'd really like one but they aren't good enough yet.
Scott
* This post was edited 11/01/19 10:04am by ScottG *
Scott, Grace and Wesly
2018 Silver Fox 32A.
H0NDA eu2000i
schlep1967
Harrisburg, PA
Posted: 11/01/19 10:13am Link  |  Quote  |  Print  |  Notify Moderator
You must have a very acidic water supply where you are for it to eat through the burner tube. Either that or the water heater manufacturer had a run of poor tubing they installed. I would think that tube would be twice the thickness of the tank material.
2008 Dodge Ram 2500 Diesel
2009 Open Range 385RLS
Pull-Rite Super Glide
RobG
Mesa, AZ
Posted: 11/01/19 10:42am Link  |  Quote  |  Print  |  Notify Moderator
They say we have a lot of minerals in the water... fwiw the anode rod never did degrade over time like with my last water heater. It always looked like-new when I'd remove it.
enblethen
Moses Lake, WA
Posted: 11/01/19 10:56am Link  |  Quote  |  Print  |  Notify Moderator
If it is rusted out, it must be a glass-lined Suburban water heater.
I would opt for an aluminum Atwood replacement.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Lynnmor
Red Lion
Posted: 11/01/19 11:11am Link  |  Quote  |  Print  |  Notify Moderator
If the anode rod is aluminum instead of magnesium, that may be some of the problem. You should have seen some rust when doing your regular flushing and that would alert you to a pending failure before a flood.
ksg5000
Oregon
Posted: 11/01/19 11:16am Link  |  Quote  |  Print  |  Notify Moderator
That seems odd - thought the primary purpose of anode rod was to prevent the problem your had. Removing an old anode rod which looks like new may indicate your anode rod was defective or something else is amiss.
Kevin
Chum lee
Albuquerque, NM
Posted: 11/01/19 11:46am Link  |  Quote  |  Print  |  Notify Moderator
So you say that you full time in your fiver. Does that mean that you keep the water heater hot 24/7/365?
If you have high mineral content in your water AND the anode rod still looks like new, AND the new water heater rusted out in 5 years, I'd guess you have something else going on that you need to figure out before you destroy another water heater. Did you test the pressure relief valve? Is the water heater grounded properly?
Chum lee
Chris Bryant
Arden, North Carolina
Posted: 11/01/19 11:48am Link  |  Quote  |  Print  |  Notify Moderator
I bet it was fired empty at some point- the only way I can see that failure on a 5 year old heater.
-- Chris Bryant
ernie1
Sacramento,California,USA
Posted: 11/01/19 12:39pm Link  |  Quote  |  Print  |  Notify Moderator
fwiw:
I have a Truma tankless water heater and it works great. I've heard really bad things about the Girard units. PleasureWay rvs were at one time equipped with Girard units until they received so many complaints about problems that they switched to Trumas.
